Results 1 to 4 of 4
    Registered Member Three Rings VtAudi's Avatar
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    Wheelbearing or CV joint or neither?
    So I had some cliking a while back, (front right) So I replaced my whole front right cv assembly, joints and shaft.... Cliking still there, was kind of hard to duplicate UNTIL today!!!
    If I crank the wheel left (probably the same w/ right) and drive in circles I get a clik.... clik.... clik, border line clunk.....
    Could that be my wheel bearing? Fronts have 160k on them, so.... w/ the new cv assembly I would think that rules that out, anyone have something similar?
    TIA
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 98 XK8, Tahoe, XC90
    Columbia, SC
    whered you get the axle from?
    ive seen many new/bad axles
    Veteran Member Four Rings AudiMV's Avatar
    Nov 01 2004
    2001 A4 1.8T
    So Cal
    i replaced my cv joint and 5,000 miles later it tore...i ended up replacing both my axles with raxles...so i could be your cv boot again....check for gross ass grease in the wheel well
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    CV assembly came from the dealer, so I think I'm going to bring it back to them and have them check it out, I'm thinking it may be my driver side? Though the noise is from the right.......
