hello all
2013 a6 quatro prestige
120,xxx kms
a week ago or so i got a message on the dash, I i checked all lights, all signals they were fine, i thought it was weird. it then reappeared a second time a few days later
RIGHT TURN SIGNAL/BRAKE LIGHT/REAR LIGHT - all signals and lights still intact and warning has not returned
then i got this for the esc about 2 days after that second brake light warning
STABILATION CONTROL (ESC) FAULT - CONSULT OWNERS MANUAL.
i checked all fuses in the trunk and the side panels they are good. the battery is new one year old.
i tried holding the esc control button down for 6-10 seocnds, in park, nuetral, gear etc. the esc warning squiggly burn out on teh dash stays lit, the esc control button does not illuminate.
using VCDS i have the follwoing report. any input greatly appreciated
thanks
Saturday,06,April,2024,13:06:11:25342
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
www.Ross-Tech.com
VIN: WAUFGCFC8DN105626 License Plate:
Mileage: 122431km-76075mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
56 5F 62 72 8F 90
VIN: WAUFGCFC8DN105626 Mileage: 122431km-76075miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTUA) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0006
Revision: --H07--- CVN: 4C7FB7FB
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A0D0E227C7906BA517-807E
VINID: 9D19565D359321478100518218E63938B4
3 Faults Found:
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [01101000] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Engine RPM: 1744.00 /min
Normed load value: 32.9 %
Vehicle speed: 58 km/h
Coolant temperature: 97 C
Intake air temperature: 42 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.319 V
Unlearning counter according OBD: 40
Engine speed: actual: 2336 /min
MAF_ENVD: 315.92940 mg/stroke
Coolant temperature (unfiltered): 80.25 C
Engine: operating status: PL
Engine load: 39.453125 %
Vehicle speed: actual: 29 km/h
6134 - Function Restriction due to Faults in Other Modules
U1113 00 [01101101] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Engine RPM: 1745.00 /min
Normed load value: 33.3 %
Engine speed: actual: 2304 /min
MAF_ENVD: 321.37646 mg/stroke
Engine load: 40.234375 %
20136 - PCV Valve Malfunction
P052E 00 [01101101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Mileage: 113166 km
Date: 2023.09.14
Time: 11:47:44
Engine RPM: 705.00 /min
Normed load value: 17.6 %
Vehicle speed: 0 km/h
Intake air temperature: 27 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.726 V
Engine speed: actual: 672 /min
MAF_ENVD: 163.41176 mg/stroke
Coolant temperature (unfiltered): 99.00 C
Engine: operating status: IS
Engine load: 17.968750 %
Vehicle speed: actual: 0 km/h
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16--- CVN: 06AF4385
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 2D07053E4D971182B45-8078
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A78F0122E5F1805B00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 36352A52B8C1525AC5F-8062
2 Faults Found:
0156 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[NET_SAS_SteeringAngleFaultValue]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:08
VzRef: 3A
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: BA
0167 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
[NET_SAS_SubInfoInitializationFailure]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:08
VzRef: 3A
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 37
Uz: BA
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CC HW: 4H0 907 064 CC
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 09A83046000000000000
VCID: 6C81C83AB68DD88AE3B-8038
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000280499006
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0076
Serial number: 23011300110707
Coding: 6681201849
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 6099AC0A4AC58CEA4F3-8034
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001501714
Coding: 0600A096473C9FE08100088780003908CF9CD308A609022180 0004406000
VCID: 6FBBDF36879B2392C69-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 130107 H36 0080
Serial number: 130121163520
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20911102
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 23 01 2013 00001162
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R4KTP02
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA120043000011409134
Coding: 020300
Subsystem 6 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 85480C86000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061302900750
Coding: 88C305
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD94E912F3562D0D-8024
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002P7HW Dataset Number: 4G0909602E 0007
Coding: 30323437313130303035554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 33331346ABB34772E21-8066
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40531PU942GPR
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB400E4UPA0I8P%
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB401050D62696.
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400E50D627P6P
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400E4UPLCL125
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400E4UPLCEH2F
1 Fault Found:
1050117 - Databus
U1123 00 [00001000] - Received Error Message
[CAN: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MAO001KO
Coding: 000434
VCID: 3829246AB255A42AD73-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 11 10 2012 11235152
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 24
Reset counter: 100
Mileage: 121981 km
Time Indication: 0
Date: 2024.03.26
Time: 14:38:07
Freeze Frame:
(no units): 36.0
Text: 24A142027B001D0001
Bin. Bits: 01000010 00000010
Oil Pr. 1 OK
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 932 B HW: 4G8 920 932 B
Component: TBenRdw H79 0515
Revision: 28460208 Serial number: 658210113596044
Coding: 0BAF09040B410008020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 2E05023240916A9A8DF-807A
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000805361 Dataset Number: 4G0909515C 0064
Coding: 00CD073000
GVL: FDA1E80CDE60600D0000
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 9168329101
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1210170000000000002E
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000049712745
Coding: 0058130000006001000001010101102030303232203232
VCID: 77ABE756FFCB6B521E9-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA82029KC4 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 30391C4A56257C6A9F3-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0050
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F25.01.1300H03000AMS16116
Subsystem 4 - Serial number: S16116
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17005E00628002000012
VCID: 47CB5796CFABDBD2AE9-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0004155433 Dataset Number: 4G0909852H 0026
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D164254A94E7AE97-8066
1 Fault Found:
4215044 - Function Restriction due to Faults in Other Modules
[Fehlerwert "Lenkradwinkel"]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 100
Mileage: 121994 km
Date: 2024.03.26
Time: 21:21:50
Write only channel
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0188134438
Coding: 0106023A00FA408480B0080402050E07000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000126234
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1979319D
Coding: 101F00
3 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 181
Mileage: 112568 km
Time Indication: 0
Date: 2023.08.30
Time: 16:36:39
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 184
Mileage: 112568 km
Time Indication: 0
Date: 2023.08.31
Time: 16:13:32
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 88
Mileage: 121473 km
Time Indication: 0
Date: 2024.03.19
Time: 14:23:24
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46D55A92C8A1C2DA55F-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000577556 Dataset Number: 4G0909522C 0005
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B030B2673831FB2AA1-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130130-0002-210
Coding: 1221A6101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156A%0D7685392
Coding: 020007020100000001
VCID: 221DE60204C9DEFA197-8076
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 664 D HW: 4G0 035 664 B
Component: H-BN-NA H50 0622
Revision: -------- Serial number: 193AU0D7505019
Coding: 050200000003E0ED55128B0E00000003F00001020000000000
VCID: 270BF7166FEB3BD24E9-8072
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDCD000EA8G
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MAU000GR
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F17004000628002000002
VCID: 49CF51AED9BF2DA2B8D-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F194E51AF756290D-8064
1 Fault Found:
12584197 - Function Restriction due to Faults in Other Modules
[Function limitation due to received error]
Freeze Frame:
Fault Priority: 6
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 100
Mileage: 121981 km
Date: 2024.03.26
Time: 14:38:07
End----(Elapsed Time: 02:16, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
