Ok, so the two codes are direct. The P2261 one, you still have that non-stock recirc valve installed? You'll need to take up that code with GFB; it's not a "stock issue" that we can evaluate against a normal car.
And then the P0420, I see no reason to relate it to the P2261 fault. So standalone issue. So start with logging and capture the event of the cat test, as I did here:
https://www.audizine.com/forum/showt...1#post14500925
You did a log before, but it lacked necessary things and had unnecessary things. The things I logged for that graph were:
IDE00021 > Engine RPM
IDE00083 > Throttle valve position (absolute)
IDE00559 > pre-cat lambda sensor lambda + current [the lambda is the value you care about, you can dump the current part using Excel]
IDE00560-MAS04121 > post-cat jump sensor voltage
IDE00592 Status of oxygen sensor control > should be closed loop / using O2 sensors, or the fuel trims are not being managed by the lambda at that time
IDE01873 > Test of catalytic converter: measured value
IDE01874 > Test of catalytic converter: result
So for the last two, somewhere along in the log, you'll see it change from 0 / Test off to 0 / Test on and then to X / whatever. For me, whatever is CatB1 Ok, and X is some value like 1.4
The point of the test, which is what trips the P0420, is to eval the cat's OSC (oxygen storage capacity). Anything that's throwing off the assessment of that, such as stray O2 in the space or errant sensors or such, will create a depressed test result.
This is a stock cat?
In that same thread,
https://www.audizine.com/forum/showt...1#post14537165 , we see the resolution to the P0420 for wilmar was realizing he had air leaks in the PCV system and fixed them. They were new as he said "car never had P0420 that I know of until I installed the new turbo". So likely the turbo process trashed that metal flex pipe that runs down to the turbo from the PCV. You might need to check yours for no leak and good seal.
