Results 1 to 4 of 4
Thread: Tre
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    Tre
    I can not get my TRE's out of the housing, do i need to align that groove any certain way or should it just pop out? i have a ball joint seperator kit but it still wont budge. Im More then feed up with this CA, TRE and coilover install so any help would be useful
    ::2002 S6
    Account Terminated Four Rings Neo1130's Avatar
    Aug 12 2004
    Audi A4, Audi TT
    Oklahoma City
    What you have to do is get a special tool or a screw driver you don't care about, and hammer it into the little slot on the side, then you put the bolt in back up top and hammer that down a bit... Work the bolt out more and hammer a little more... Do this until you can get the TRE out of the knuckle...
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    So, you took out the pinch bolt right?
    Removed the 8mm bolt from the top (I think its 8, if not, its a 10mm) and tried to pound down on the TRE to bang it out?
    The only part I've ever had a problem with was the pinch bolt, I've had to drill them out before...
    1998 A41.8tqms
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    wait what pinch bolt? i think that was suppost to stay in there, that could be my problem
    ::2002 S6
