Results 1 to 3 of 3
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Audi Q3 2015 Ignition upgrade
    So guys starting working on some of the mods for the Q3 and I'm starting with the ignition. I did one step colder plugs and APR ignition coils. I also loaded up the stage 1 tune from IE. Will post videos when done but here are some pictures. If you want to follow along on the upgrades will be post videos up on my YouTube page ProjectzGarage.
    https://youtu.be/DXHBlIWjtMw?si=hx0rJ9FRGvU0umU3
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
    Nov 13 2009
    the OC, SOCAL
    i was waiting to see when someone will do power and or suspension mods on this car. i have started doing some small stuff. brakes and subframe bushings. nothing on power.
    Feb 27 2013
    New York
    So far all i have is the coils, intake and tune. you can do a stage 1 tune with stock setup and you will feel a good jump in power.
    Audi Q3 8U-White
