Results 1 to 21 of 21
    Junior Member Two Rings parthpmp's Avatar
    Jun 04 2021
    2023 Range Rover P400, 2018 Tesla Model 3
    Illinois
    Lightbulb I finally Disabled Start Stop
    Did this on my 2020 S7. As you know coding can’t disable start stop as it’s built into the lower screen. In my search. I found sellers on AliExpress advertising for roughly $30, a plug n play module to disable it. Well it works! Took 30min to install.
    Where to buy:
    Here’s the link, but any one will work if you search up this “audi c8 start stop” https://a.aliexpress.com/_ms3m6x0
    Features of it:
    When starting car it defaults start/stop off. That’s it lol. Start stop still works if you press the button. But it will always default off after ignition cycle.
    FYI there are risks to installing random things off the internet. So be vigilant lol. In my case. This hasn’t affected any other functions of the car other than the intended. So far so good.
    Here’s how to install it. It gets installed under the backseat:
    1. Remove the back seat. Here’s a link to instructions https://imgur.com/a/Ixv1riI
    2. Find the black module. Under some clear plastic in the center.
    3. Remove the two hex nuts, it comes with the tool.
    4. Remove the black connector harnesses. Along with the white clip that locks it in place. As that will interfere with the new module.
    5. Take the oem black harness and plug it into the new module. NOW. It can go in both ways. So insert it in the direction with the least resistance. As mine had no label. If you insert it in wrongly. It is so hard to take apart. If you insert it correctly you will hear a click.
    6. Plug the new module into the oem module and lock it in place.
    7. Put it all back in reverse order. There is no good place to place the extra harness wires. So just let it rest on top the factory module. If you sit in the middle seat you can barely feel the extra wires. But that seat is uncomfortable as is. So who cares.
    If you want pictures of certain steps lmk.
    Established Member Two Rings Daytona RS5's Avatar
    Jul 18 2017
    Upstate NY
    Lol, I wish you would posted this two days ago. I looked online and I couldn't find anything other than what someone had done in their newer model SUV. I had bought an extra harness from someone on here so I went and unbalted the front seat and took the carpet in the trim all apart only to find there was no module in there. I did further research on Alibaba Express and found the video showing is under the back seat. I will be doing it later this week, and it should be much easier than the mess that I got into
    Sent from my SM-S928U1 using Tapatalk
    Current: 2022 CT5-V Blackwing 6sp manual
    Former Audis: 2021 RS6 Daytona Grey, 2018 Daytona R8 RWS, 2015 Daytona RS7, 2013 Daytona RS5, 2000 Silver S4
    Jul 18 2017
    Upstate NY
    https://www.aliexpress.com/i/1005005346568850.html
    This is the video
    Stage 2 Banner Advertiser Four Rings Sean@TAG's Avatar
    Jun 27 2014
    Seafox Boat, Jetta, F150, Travel trailer
    San Diego
    We don't blame you!! lol
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    Jul 15 2015
    2000 Z51 Corvette 427, 1987 AM General M998, 2013 A6 Prestige APR Stage 1 (RIP)
    Boston MA
    Why not go the VCDS route? I haven't done it but I saw the functionality to disable as I was disabling my seat belt warning.
    Jul 18 2017
    Upstate NY
    Quote Originally Posted by Havok View Post
    Doesn't work after 2019
    Jan 29 2024
    2019 Audi A7 Prestige S-Line, 2017 Mazda MX-5
    NE Ohio
    That will only work on cars up to 2018 as far as I'm aware, and maybe not even all of those. There isn't any coding change that works for the newer cars to defeat the auto start/stop, only the cable-thing.
    Jun 04 2021
    Illinois
    Quote Originally Posted by Daytona RS5 View Post
    Yeah. I kept getting annoyed by it especially whenever the screen is slow to load and the button isn’t highlighted to click
    Here’s my Reddit post on it with some pics of the piggy back module
    https://www.reddit.com/r/Audi/s/bSbkZrXtIW
    Jun 04 2021
    Illinois
    Quote Originally Posted by BoredOhio View Post
    Exactly. I tried the OBD11 route. Went deep into the modules and found a switch that indicates auto start stop disable/enabled. But if you do that code. It throws a CEL and reverts back to enabled. So this was the only way I could actually disable it.
    Aug 10 2018
    2023 Q7
    **Update per next post made valid point - When installed, car begins to unlock/lock and then gives a ton of codes. Others appear to have success, thus could just be a bad unit. 2023 RS7 is my experience.
    Feb 02 2013
    It works just fine on 2023 rs and 2024 s
    Oct 22 2022
    Andover, MA
    as a potential alternative (just FYI) I had success in my 2019 A6 (C8) 55 Premium + with this --- CMT Plug Play Start/Stop Memory Module for Audi A7 S7 RS7 C8 Always Turn On/Off from Seller - AA Auto Parts on eBay (seller is in Australia) but price is a bit higher at approx. USD $95.00..install is straightforward as described by OP (don't recall it being able to be installed "both ways" but that could be my fading memory....)
    Jun 04 2021
    Illinois
    Quote Originally Posted by DutchK23 View Post
    I trust eBay more than AliExpress. But $30 was just too good of a deal to pass up lol
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Sorry to revive an old thread, but I wanted to thank the OP and others for the link to Ali Express. Just received and installed the module on my 2019 A7. Start-stop disabled!! :)
    Established Member Two Rings amolinaro's Avatar
    Sep 24 2024
    2024 Audi RS7, 2018 Jeep Trackhawk, 2021 Chevy Tahoe
    Kansas
    Quote Originally Posted by mksap11 View Post
    Seems like a lot of work when you can just press a button on start up every time. Or like me, always in RS2 mode and it's not enabled.
    Apr 06 2005
    Boston, MA
    $30 and 10 minutes of my time to install is worth not having to push the button every time like a peasant. lol.
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    My APR stage 1 also disabled start/stop on my S7. Became second nature to disable it every time I turned the car on
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Established Member Two Rings Mister Mike's Avatar
    Dec 05 2023
    Oregon
    Planned on doing this today. After plenty of effort, got 2 of the 3 clips to pop up from back seat bench, way harder than I thought it would be. Got the third one (passenger side) most of the way loose but just can’t seem to get it to release. I feel like I’m so close to breaking the seat bench where the metal rod loop is that’s still hanging on, or hurting myself trying to pull and pull. It’s awkward and an uncomfortable area to work back there, but I am wondering if I’m doing something wrong. Anybody else struggle big time removing the rear bench? This has drove me crazy half of the day! I don’t want to give up but getting close.
    Jan 25 2025
    Central, NJ
    I installed mine on my 25 a few weeks back, took about 15-20 minutes start to finish. The clips on the back of the seat were the most annoying part, but I used a screwdriver with a microfiber over it and wedged it in and popped them out fairly easily. Then pulled up on the front of the rear seat using my hand and some force to move the lower rear seat out of the way.
    I will say the module (at least the one I received from Ali) seems to be able to be installed backwards, which I did at first causing a CEL and random clicking inside the car when attempting to start the car after installation. I then went back and installed the plug from the module the opposite way and the CEL went away and everything has been working well since. Make sure to test before you reinstall the back seat!
    Dec 05 2023
    Oregon
    Thanks Boosting. This confirms something goofy is going on with my setup. Those 3 that have to pop up on the front…..did the black plastic clip come out all the way along with the metal rod loop thing when you removed? I’m applying so much force but still stuck on this last one!
    Dec 05 2023
    Oregon
    Finally got the last one to pop out, ended up using a rope wrapped around the steel rod loop to force it up. The black plastic grommet clip broke and fell down so I hope it doesn’t rattle around. Need to get a new grommet to wrap up the little project that was way more difficult than it should have been!
