Results 1 to 9 of 9
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Modified Polyurethane Exhaust Hangers C7/7.5 S6
    Just finished up the plunge modifying the 4 exhaust hangers under the car and replacing them with the GRIMMSPEED TWO POSITION EXHAUST HANGER - 12MM, POLYURETHANE, SET OF 4
    in my infamous way of describing mods
    You vs the Guy she told you not to worry about
    This is NOT a Drop in for 3 of the 4 hangers. The passenger side center is a double slide post you can slip on and off like other hangers on other vehicles.
    I had to drill out the drivers side center hanger as its a pressed in fitting. (Ill have to come back to this and show deconstructed photos later...this was done on my first S6, and I swapped it straight over with the exhaust on this S6)
    These photos of the center setup are all I have right now
    I started this because the AWE Track CBE was rubbing on my cross brace after the center muffler section. Not because the AWE is heavier, or improper install, but because the OE hangers are prone to stretch, and they have lots of lateral play. The entire outer band is actually aluminum, but the center is SOFT rubber
    you can slightly make it out here:
    The quick and dirty for the rears
    Youll need the following:
    x2 1.5" or longer exhaust hangers with 12mm ports for the posts
    x2 exhaust hanger bracket
    aluminum cutting blade mini hacksaw
    x2 12mmx60mm 1.75 pitch threaded bolt
    x8 12mm washers
    x2 12mm 1.75 pitch locking nut
    assorted drill bits (I used only 3....a pilot bit, a light bore, and finally a 1/2" to make the full hole)
    light sanding paper to deburr anything after drilling and cutting
    Drill
    Pliers (Dealers choice)
    I had a tabletop vice to help hold while I cut, but its not needed if you just want to ugga dugga it
    You'll start with this:
    You will need to break it down any way you see fit to get it to the base aluminum housing with no posts. I cut the OE hanger off, then worked on the center post by getting the mini hacksaw between the body and the hanger.
    like this:
    once its free you'll have to brake the small side tabs off...I used a basic linesman pliers to snap them off.
    sand it flat so the washers can lay flat and to give you a working area that you can drill into.
    I didn't center punch....I just sent it with a small pilot drill bit and made it work on hopes and dreams following the full send: FAFO method.
    once you drill up to 1/2" you'll want to sand everything down to deburr and make smooth surfaces. Its aluminum, so its going to be VERY fast sanding and takedown, so be mindful of your grit. I used 350 grit and it was a bit tedious, but it worked out.
    should look like this:
    Take your bolt, 4 washers, and the polyurethane hanger and the locking nut. Place on washer on the bolt head, slide it into the first assembly drilled port, then slide another washer. Then put the poly hanger and another washer. Slide it through, then the final washer and then the nut. So its bolt, washer, housing, washer, hanger, washer, housing, washer, nut.
    resembles this:
    Tighten down, and you should be able to free rotate the hanger because of the washers.
    slide it onto the hanger post on the exhaust section then push the entire assembly lined up to the single 13mm post that mounts the housing to the car. I have AWE locking clamps on the bar ends to help keep it from slipping out.
    looks like this:
    if you are with an aftermarket exhaust with slip pipes and clamps, you will want to adjust everything to make sure you have final position and tighten everything down.
    (1.5" is nearly the same as the stock before its stretched)
    Here is the before from the rear:
    Here is the after from the rear:
    slightly tighter in the pocket, but I wont have any lateral movement anymore with the tighter poly hangers.
    and the full specs for the nerds in the back:
    (should I have used a caliper...yes. I just couldn't find it.)
    full hosted photos....https://imgur.com/a/TRrgsMH I didnt include them all, as I think I got the jist covered here
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
    Nov 12 2015
    Oregon
    We written. Thank you!
    Sent from my SM-N960U1 using Tapatalk
    My build log
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Pic heavy
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 16 2020
    West Michigan
    Those brackets would be way faster if they were red. Just saying.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by TexasDfwS4 View Post
    Pic heavy
    Not sure if a good or bad thing? 😂
    - - - Updated - - -
    Quote Originally Posted by sepheroth86 View Post
    They'll be road grime brown in a week...
    Sep 10 2012
    DFW
    Just saying, my older phone could hardly keep up with all those photos.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 16 2020
    West Michigan
    Quote Originally Posted by THCarpenter View Post
    - - - Updated - - -
    But you will know that they are truly red. So faster.
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    It's FastaR
    Get with it
    - - - Updated - - -
    Sorry.... Not sorry?
    Sep 10 2012
    DFW
    Third world problems lol
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
