Originally Posted by
Avantly
I have 3x 2.7T and 3x 4.2 allroads (have sold off several other 2.7T allroads). I have a 2004 4.2 which is literally identical to yours, painted fender flares and everything... I wonder how far apart they were on the production line. It is definitely my favorite allroad. I also have atlas gray, brilliant black, cobalt blue, and highland green but something about the light silver metallic with painted flares and tinted windows is just fantastic. Really nice looking car you have there.
Tip: Buy a spare crankshaft sensor and store it in the spare wheel well. You can change it with a single hex bit from under the hood if you're willing to sacrifice just a bit of skin on your wrist and/or arm. I've had the crank sensor fail in every single one of my chain driven 4.2 AR's. Mainfests as a sudden stall at warm/hot with no codes (and no restart until it cools) and develops into a no-start at any temperature usually with no codes. I'd also keep a spare hella or other OEM brand ECT with it(causes warm/hot difficult start or no start which gets worse and worse). IMO these are the only two things that have the possibility of stranding you if you do all of the regular/scheduled maintenance other than fuel pump if your fuel filter has been neglected since new (but you can replace the fuel pump under the rear seat cushion!). Other than that, pay attention to the transmission and if you get the hard shift issue (if it hasn't been corrected before) put a TransGO PR shift correction kit in it. Absolutely fantastic car. I loved my 2.7T allroads for many years... Then I got a 4.2 allroad... Now all the 2.7T allroads need to be sold (including the atlas gray with painfully low odometer reading) :'(
FYI, you can get new cylinders for the air pumps on eBay from some chinesium company if your piston bore is fooked and they seem to work decent, I use the eBay repair kits for the air pumps which are identical to the Andy kits but usually include a few more parts. Never buy a new pump, always rebuild!
Oh, and one more thing, all of my 4.2 AR's had stuck flaps in the intake when I got them, causes some interesting behavior and fuel trim codes. You can fix without removing the intake, you have to remove the fastener on the front of the flap actuator and carefully weedle that actuator arm out of there, clean the area out, lube with silicone grease and reinstall. Have only had to do it once on each car. If you get fuel trim/random misfire codes always check this first. Mine were all stuck solid, even the one that had a 45k mile engine installed in it.
Dang, I wanna hangout! Hahaha, I dream of that many Allroads. You have (had) quite the fleet!
I appreciate the kind words. I am finding it pretty eye catching the more I own it. I’ve never been a silver guy, but I couldn’t agree more. I hope to keep her around and going for many years to come.
Noted! Sounds a bit like the 2.7 crank no start issues one may face. I assume ECT is engine coolant temp sensor. I’ve got carni hands and can usually fit into small spots alright. Ha!
At 200,000 miles what maintenance would you recommend? I can only assuming timing maintenance has been done. I hear none-1 second of rattle on start up and nothing else. I wish I knew if they went plastic or metal on the guides, but maybe there’s a way to tell? Do I need to worry about anything outside of the timing chains and guides? Camshaft adjusters?
I have loose plans to address:
-Oil and filter
-Oil filter housing o-rings
-Spark plugs
-Air filter
-Cabin filter
-Fuel filter
-Air compressor rebuild
-Intake manifold clean and inspect
-Valve cover gaskets
-Valley pan gasket
-Oil check valves
-Rear diff fluid
-Brake fluid flush and 4 corner brake job
-PCV refresh and SAI refresh ( if needed )
-CV axles? ( Are they the same between 2.7 and 4.2 autos? )
-Crank position sensor ( on standby )
-Coolant temp sensor ( on standby )
So far the transmission seems ok, but I’m afraid to jinx it or put bad vibes out into the universe 🥹 Part of me wants to service it, and part of me wants to leave well enough alone until there’s a reason to take action. I’ve never worked on an automatic transmission before and I know the filling procedure can be a bother.
