Be appreciated vehicle runs fine but idles very rough and has low oil pressure when started
Code:
Connection profile: Audi CAEB 2.0 TSI/TFSIDate: 2/15/2024 11:20:58 ============================ OBD-IIOBD-II DTCs: 10 ---------------------------- P0341 [0x0341] Camshaft position (CMP) sensor A, bank 1 - range/performance problem Camshaft Position (CMP) Sensor Performance Status: Confirmed ---------------------------- P0299 [0x0299] Turbocharger (TC)/supercharger (SC) - low boost Status: Confirmed ---------------------------- P2188 [0x2188] System too rich at idle, bank 1 Status: Confirmed ---------------------------- - [ ] P0016 [0x0016] Crankshaft position/camshaft position, bank 1 sensor A - correlation Status: Confirmed ---------------------------- [0x0506] Idle speed control (ISC) system - rpm lower than expected Idle Speed Low Status: Confirmed ---------------------------- P0300 [0x0300] Random/multiple cylinder(s) - misfire detected Engine Misfire Detected Status: Confirmed ---------------------------- P0301 [0x0301] Cylinder 1 - misfire detected Cylinder 1 Misfire Detected Status: Confirmed ---------------------------- P0303 [0x0303] Cylinder 3 - misfire detected Cylinder 3 Misfire Detected Status: Confirmed ---------------------------- P0304 [0x0304] Cylinder 4 - misfire detected Cylinder 4 Misfire Detected Status: Confirmed ---------------------------- P0302 [0x0302] Cylinder 2 - misfire detected Cylinder 2 Misfire Detected Status: Confirmed ============================ 19. CAN Gateway No DTC found. ============================ 09. Onboard supply control unit No DTC found. ============================ 02. Transmission control unit No DTC found. ============================ 03. ABS control unit03. ABS control unit DTCs: 1 ---------------------------- 00473 [0x01D9] Electromechanical parking brake control unit-J540; Electric parking / handbrake control unit-J540 Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request ============================ 01. Engine control unit01. Engine control unit DTCs: 13 ---------------------------- 05580 [0x0015CC] Archive (inactive) P164B00: Oil pressure switch, Malfunction P055F00: Engine Oil Pressure Out of Range Status bits: 1 Priority: 2 Frequency: 38 Unlearning index: 255 Odometer: 235482 km Date, time: 2011.10.06 22:59:03 Engine RPM: 3758 rpm Calculated engine load value: 27.84 % Vehicle speed: 59.0302632625467 mph Engine coolant temperature: 167 ℉ Engine oil temperature: 53.6 ℉ Barometric pressure: 99 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 26 Status: Confirmed, Test failed since last DTC clear ---------------------------- 05582 [0x0015CE] P164D00: Reduced oil pressure switch, Malfunction Oil pressure switch for reduced oil pressure, Malfunction P052400: Engine Oil Pressure Too Low Status bits: 1 Priority: 2 Frequency: 254 Unlearning index: 255 Odometer: 234418 km Date, time: 2011.09.05 20:14:30 Engine RPM: 874 rpm Calculated engine load value: 8.63 % Vehicle speed: 0 mph Engine coolant temperature: 188.6 ℉ Engine oil temperature: 87.8 ℉ Barometric pressure: 99 kPa Klemme 30 voltage: 13 Paramteric values: 20 96 28 Status: Pending, Confirmed, Test failed since last DTC clear ---------------------------- 04113 [0x001011] P034100: Camshaft Pos.Sensor Circ., Range/Performance Status bits: 1 Priority: 2 Frequency: 19 Unlearning index: 255 Odometer: 236268 km Date, time: 2011.10.26 02:37:29 Engine RPM: 1455 rpm Calculated engine load value: 21.18 % Vehicle speed: 44.1173546488507 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 78.8 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 13 Paramteric values: 20 96 28 Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04096 [0x001000] P001600: Crankshaft Position-Camshaft Position, Correlation Bank 1 Sensor A Status bits: 1 Priority: 2 Frequency: 3 Unlearning index: 255 Odometer: 236273 km Date, time: 2011.10.26 03:47:18 Engine RPM: 1006 rpm Calculated engine load value: 7.84 % Vehicle speed: 13.6701662292213 mph Engine coolant temperature: 172.4 ℉ Engine oil temperature: 118.4 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 13 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 05671 [0x001627] P029900: Turbo/Super Charger Underboost Status bits: 1 Priority: 2 Frequency: 14 Unlearning index: 255 Odometer: 235480 km Date, time: 2011.10.06 22:57:45 Engine RPM: 3784 rpm Calculated engine load value: 88.24 % Vehicle speed: 42.874612264376 mph Engine coolant temperature: 150.8 ℉ Engine oil temperature: 57.2 ℉ Barometric pressure: 99 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04010 [0x000FAA] P050600: Idle Control System, RPM Lower than Expected Status bits: 1 Priority: 2 Frequency: 3 Unlearning index: 255 Odometer: 236282 km Date, time: 2011.10.26 03:55:32 Engine RPM: 600 rpm Calculated engine load value: 21.18 % Vehicle speed: 0 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 96.8 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 13 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04054 [0x000FD6] P030100: Cyl.1, Misfire Detected Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 236294 km Date, time: 2011.10.29 17:46:55 Engine RPM: 1829 rpm Calculated engine load value: 25.49 % Vehicle speed: 35.418157957528 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 57.2 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04060 [0x000FDC] P030300: Cyl.3, Misfire Detected Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 236294 km Date, time: 2011.10.29 17:46:55 Engine RPM: 1829 rpm Calculated engine load value: 25.49 % Vehicle speed: 35.418157957528 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 57.2 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04063 [0x000FDF] P030400: Cyl.4, Misfire Detected Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 236294 km Date, time: 2011.10.29 17:46:55 Engine RPM: 1829 rpm Calculated engine load value: 25.49 % Vehicle speed: 35.418157957528 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 57.2 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04057 [0x000FD9] P030200: Cyl.2, Misfire Detected Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 236294 km Date, time: 2011.10.29 17:46:55 Engine RPM: 1829 rpm Calculated engine load value: 25.49 % Vehicle speed: 35.418157957528 mph Engine coolant temperature: 168.8 ℉ Engine oil temperature: 57.2 ℉ Barometric pressure: 98 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04051 [0x000FD3] P030000: Random/Multiple Cylinder, Misfire Detected Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 236294 km Date, time: 2011.10.29 17:46:35 Engine RPM: 630 rpm Calculated engine load value: 23.92 % Vehicle speed: 0 mph Engine coolant temperature: 172.4 ℉ Engine oil temperature: 86 ℉ Barometric pressure: 99 kPa Klemme 30 voltage: 14 Paramteric values: 20 96 28 Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04106 [0x00100A] P218800: System too rich at idle, Bank 1 Status bits: 1 Priority: 2 Frequency: 7 Unlearning index: 255 Odometer: 235681 km Date, time: 2011.10.12 02:39:12 Engine RPM: 824 rpm Calculated engine load value: 18.04 % Vehicle speed: 0 mph Engine coolant temperature: 167 ℉ Engine oil temperature: 71.6 ℉ Barometric pressure: 97 kPa Klemme 30 voltage: 13 Paramteric values: 20 96 28 Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ---------------------------- 04201 [0x001069] P125000: Fuel level, too low Status: Test failed, Test failed since last DTC clear, Test not completed during this operation cycle ============================ 05. Authorization system for access and starting the engine05. Authorization system for access and starting the engine DTCs: 1 ---------------------------- 00956 [0x03BC] Key 2 Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory ============================ 06. Front passenger seat No DTC found. ============================ 08. Heater and climate08. Heater and climate DTCs: 1 ---------------------------- 02244 [0x08C4] Archive (inactive) Control Panel Key Jamming; The button in the control unit is stuck Status: Validated and stored in non volatile memory ============================ 0D. Slide Door Left (VW TP2.0) No DTC found. ============================ 15. SRS15. SRS DTCs: 1 ---------------------------- 9443859 [0x901A13] B101A15: Crash sensor for front airbag, driver side, Open circuit/short circuit to B crashsensor for driverside (G283) frontal interruption/short to plus Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 229101 km Date, time: 2023.04.06 15:43:38 Status: Confirmed, Warning indicator requested ============================ 16. Steering column No DTC found. ============================ 17. Dashboard No DTC found. ============================ 36. Driver seat adjustment36. Driver seat adjustment DTCs: 1 ---------------------------- 16347 [0x3FDB] Control block; Control unit Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory ============================ 42. Driver door electronic equipment42. Driver door electronic equipment DTCs: 1 ---------------------------- 00920 [0x0398] Exterior Mirror Heating Elements (Z4 / Z5); heated exterior mirrors (Z4 / Z5) Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory ============================ 46. Central comfort systems module (VW TP2.0)46. Central comfort systems module (VW TP2.0) DTCs: 1 ---------------------------- 01504 [0x05E0] License Plate Light-X; License plate light-X Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle ============================ 52. Front passenger door electronics52. Front passenger door electronics DTCs: 2 ---------------------------- 00920 [0x0398] Exterior Mirror Heating Elements (Z4 / Z5); heated exterior mirrors (Z4 / Z5) Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory ---------------------------- 00110 [0x006E] Indicator repeater lamp in the exterior mirror housing on the front passenger side-L132; Front passenger side mirror indicator lamp-L132 Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request ============================ 53. Parking brake53. Parking brake DTCs: 1 ---------------------------- 01321 [0x0529] Airbag Control Unit-J234; Airbag control unit J234 Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle ============================ 55. Headlights corrector No DTC found. ============================ 56. Head unit (MMI) (VW TP2.0) No DTC found. ============================ 5F. Electronic Information System 1 No DTC found. ============================ 62. Rear left door electoronics (VW TP2.0) No DTC found. ============================ 72. Rear right door electronics (VW TP2.0) No DTC found. ============================ 78. Slide Door Right (VW TP2.0) No DTC found.
