Results 1 to 2 of 2
    Veteran Member Three Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    2008 A8 no start, no ignition
    Have a 2008 A8 that won't switch on the ignition, only thing I get is the date and mileage that shows up on the instrument cluster. Key functions like unlocking and locking are working. Jumped terminal 15 and terminal 75 and was able to get a scan from the vehicle and seems like many faults relating to no communication with kessy, although I can see and scan the kessy module. Plugged in a used kessy module from the junkyard and the ignition switched on briefly with all lights on instrument cluster but now cannot get it to happen again which I'm assuming is most likely because immobilizer is now active. So I had a few questions if anyone knows:
    1) I've read conflicting results whether it's possible to read the SKC pin from the kessy using carprog on this model year, some say you can and some say you can't because they switched over to a rolling code. Anyone know for sure? Either way I will be attempting it this weekend when the carprog tool arrives.
    2) Also seeing information that the steering column lock (ELV/ESL) could be defective as well. I also this a used from the junkyard that is from the same vehicle as the kessy (and I have the key for this set also). Is the used steering lock reprogrammable to my original keys or no? I've read that once the steering lock is programmed it cannot be changed unless you have a brand new key.
    If I have a bad ELV and I cannot program to existing keys, am I better off replacing the ELV + kessy and then programming the cluster and ECM to that set? Second option would be to clone the new kessy with my old one, replacing the ELV and order a new key?
    Quote:
    Chassis Type: 4E (4L0)
    Address 01: Engine Labels:. 079-907-560-BVJ.clb
    Part No SW: 4E1 910 560 D HW: 4E1 907 560
    Component: 4.2l V8/4V 0010
    Revision: 71H21--- Serial number: AUX3Z0H1743207
    Coding: 01060009190F0120
    Shop #: WSC 02313 785 00200
    VCID: 2306FB0DE2794789FE-8076
    VINID: 9D195C989115208780042103101B17ACA3
    5 Faults Found:
    005634 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    049441 - No Communication with ABS Brake Control Module
    U0121 - 008 -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 36
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 3.0°C
    Temperature: 7.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 11.938 V
    049446 - No Communications with Steering Angle Sender (G85)
    U0126 - 008 -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 3.0°C
    Temperature: 6.0°C
    Voltage: 12.192 V
    053250 - Please Check Fault Codes in Comfort System Control Module (J393)
    U1002 - 008 -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 31
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 3.0°C
    Temperature: 7.0°C
    Voltage: 12.192 V
    001393 - Brake Switch (F)
    P0571 - 008 - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:05:17
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 3.0°C
    Temperature: 7.0°C
    Voltage: 12.065 V
    Readiness: 0110 1101
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E1 910 156 C HW: 09L 927 156 A
    Component: AG6 09L 4,2lFSI USA 0030
    Revision: --H01--- Serial number: 4426175
    Coding: 0000002
    3 Faults Found:
    049448 - No Communications with Parking Brake Control Module
    U0128 - 000 -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 24.0
    Temperature: 12.0°C
    T.B. Angle: 0.0°
    U0126 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    049442 - No Communication with ESP (Vehicle Dynamics) Control Module
    U0122 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:56
    Address 03: ABS Brakes
    Cannot be reached
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 907 181 C
    Component: FBS AUDID3 H12 0200
    Revision: 02005112 Serial number: AUX3Z0H1743207
    Coding: 0262144
    Shop #: WSC 01123 444 109216
    VCID: 58FC9CE1EBBFD451DB-800C
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00576 - Terminal 15
    006 - Short to Plus
    Freeze Frame:
    Fault Status: 01100110
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 237
    Mileage: 245952 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:09:00
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 951 K HW: 4E0 920 951 K
    Component: KOMBIINSTR. VDO H84 0620
    Revision: D03 Serial number: AUDID3H1100300
    Coding: 0016210
    Shop #: WSC 18790 002 104857
    VCID: 2D121D35B4BD81F958-8078
    2 Faults Found:
    01704 - Terminal 58 (Dimming)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 01:19:10
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:01:40
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B08211804E
    Coding: F5DFFF7F707A0E00
    Shop #: WSC 47494 006 1048576
    14 Faults Found:
    02874 - Control Module 2 for Central Convenience (J773)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:04:27
    01207 - Control Module for Auxiliary Heater (J364)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:04:28
    00317 - Rear Lid Control Module (J605)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:04:28
    00384 - Optical Databus
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:05:07
    01333 - Door Control Module; Rear Left (J388)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:22:18
    01964 - Control Module for Seat & Steering Column Memory (J136)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:05:08
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:22:22
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:22:22
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:22:22
    00456 - Control Module for Access and Start Control (J518)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:12:54
    01310 - Level Control System Control Module (J197)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:02:58
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:02:58
    01315 - Transmission Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:02:58
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:02:58
    Address 46: Central Conv. Labels:. 4E0-910-289.lbl
    Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
    Component: Komfortgeraet H10 0030
    Revision: 00300010 Serial number: W040802150319
    Coding: 0048686
    VCID: 2B16132D8AA98FC946-807E
    Subsystem 1 - Part No: 4E0 910 853
    Component: Heckdeckel P27H08 0090
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 02:22:23
    01134 - Alarm Horn (H12)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 237
    Mileage: 174176 km
    Time Indication: 0
    Date: 2018.11.16
    Time: 20:47:26
    00576 - Terminal 15
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 47
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:22:23
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 35
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:23:13
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 21
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:12:59
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 52
    Reset counter: 237
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:33:58
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
    Component: ILM Beifahrer H11 0070
    Revision: Serial number: 00000000018759
    Coding: 0010111
    VCID: 1E70CAF9C91B6A61D1-804A
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 22
    Mileage: 0 km
    Time Indication: 0
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 237
    Mileage: 245964 km
    Time Indication: 0
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: J0644 BEM H12 0550
    Revision: 00000000 Serial number: 00000000022596
    VCID: 200CF401F36F5C91E3-8074
    Subsystem 1 - Part No: 000 915 105 DL
    Component: von VA0 310914E1S4
    Coding: 303030393135313035444C56413033313039313445315334
    5 Faults Found:
    02277 - Quiescent Current Stage 6
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 10
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 01:14:12
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 15
    Reset counter: 255
    Time Indication: 0
    Date: 2023.10.05
    Time: 023904
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:03:56
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:06:48
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 22
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:03:48
    Address 65: Tire Pressure Labels: 4E0-910-273.lbl
    Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
    Component: Reifendruck 3 H05
    Revision: 00050340 Serial number: 00000600055462
    Coding: 0232125
    2 Faults Found:
    004 - No Signal/Communication - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100100
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 22
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:13:03
    Freeze Frame:
    (no units): 0.0
    Voltage: 0.00 V
    (no units): 33.0
    Temperature: 0.0°C
    Temperature: 0.0°C
    Temperature: 0.0°C
    Temperature: 0.0°C
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 245966 km
    Time Indication: 0
    Date: 2023.10.05
    Time: 00:21:51
    Freeze Frame:
    (no units): 0.0
    Voltage: 0.00 V
    (no units): 30.0
    Temperature: 0.0°C
    Temperature: 0.0°C
    Temperature: 0.0°C
    Temperature: 0.0°C
    || Instagram @SAMM9690 ||
    Active Member One Ring myjettasbetta's Avatar
    May 14 2024
    2002 Jetta TDI
    Victoria/British Columbia/Cana
    Hey Sam, from what I'm seeing, I hate to say it looks like it could be to do with the Access/Start Authorization control module under the driver's side carpet... I had a phaeton with similar issues recently and ended up needing that module, water ingress as usual... also found a little forum post on ross tech about the same issue in a Touareg, our cars share some similarities electronically.
    https://forums.ross-tech.com/index.php?threads/23499/
    If it were my car, I'd check fuses, pull up that carpet and make damn sure its dry down there where the module and wiring are, inspect and repair as needed! Hopefully it's only a LITTLE bit of a nightmare
