Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
  1. #41
    Oct 09 2014
    Welch, MN
    Wonder where Jackal went?
    I posted here, sent a PM and even sent these questions on their website with there "contact us" portion. I've got no reply from any of this. HMMMM? Wonder if they'd answer the phone that I need to call to get some answers?
  2. #42
    Junior Member One Ring
    Nov 20 2023
    Ottawa, Ontario
    Hi Tony and fellow 4M Q7 enthusiasts!
    I am just about ready to pull the trigger on purchasing this promising tuning software, and have acquired all the hardware bolt-on's required to go all the way up to Stage 2+... I look forward to working my way up through the tunes and feeling the incremental boost in power at each stage. However, I do have a question which I hope can be answered before I make my purchase:
    Do all stages offer both 91 and 93 octane options? I have read that some folks are running this software on 91 octane, but it is not clear if 91 is available for all stages? Can anyone confirm?
    Many thanks and safe driving all!
  3. #43
    Nov 20 2023
    Ottawa, Ontario
    Quote Originally Posted by nicholas_b90 View Post
    Anyone..?
  4. #44
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    Anyone..?
    Hi, if my memory serves me right it has two tunes for 91 and 93. It's raining cats and dogs outside today but when it stops I can hookup laptop and check for you. I'm running 93tune with supercharger pulley, it runs very good.
  5. #45
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    I suggest reaching out to Matt at Jackal via their website. He's pretty responsive (at least from my interactions) and can get you a definitive answer.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
  6. #46
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    Anyone..?
    Here you go
    Sent from my iPhone using Tapatalk Pro
  7. #47
    Nov 20 2023
    Ottawa, Ontario
    Thanks gents - your responses are much appreciated! Well noted about communicating with Jackal directly through their website if needed.
  8. #48
    Established Member Two Rings DKo5's Avatar
    Aug 25 2014
    Flashed my wife's 2017 Q7, 91 stage 1 ECU and the TCU, back in May. Haven't been super happy with the TCU tune, you gotta gotta give it the beans to get it to downshift at all - and using cruise control it'll lose speed just cruising. Just checked and there's an updated ECU tune from 8/26 that I'm going to throw on there today, and go back to stock on the TCU to see if it behaves better. If I have the time I might try the updated TCU tune, dated 8/18.
    I've got new plugs and the BMC filter in the garage I've been too lazy to swap. Deciding if I want to get an upper pulley at some point and then go full stage 2 and hopefully that'll allow the TCU tune to perform as expected. Ran a DP EPL stage 2 ECU/TCU tune on my '15 S4 and really loved it, would be rad to have similar levels of torque on tap with this heavy beast...
    Reading back on the E85 talk, and its something I'd love to do if there was a flex option. Having to manually switch tunes won't fly for what is essentially a daily family hauler. Trying to keep this thing from going to empty on corn would be quite the challenge, so it would just be for fun weekend romps whenever I'm near a pump.
  9. #49
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by DKo5 View Post
    True flex on a non flex car would not work without a sensor talking to the ECU to initiate the map switch.
  10. #50
    Established Member Two Rings josh_avant's Avatar
    Mar 07 2013
    2012 TTRS, 2017 Q7, 2002 WRX
    Chicago, IL
    Are you in 'S' mode or only in 'D'? I've been running stage 1 for a couple months now and it shifts noticeably better and more aggressively in 'S' than it did stock. It's still pretty slow to downshift in 'D', but I just don't use that.
    B7 Phantom Black S4 Avant
    JHM headers | JHM LWFW / Stage 3 Clutch | Stasis Exhaust | Stasis SL Coilovers | JHM Tune | BC Forged RS43 | PSS 255/35/18
  11. #51
    Feb 21 2019
    Sacramento
    I flashed the car in June, stage 2 with upper pulley did fresh plugs ,BMC filter and Rock euro intake all at the same time , very happy with the tune , enjoying added torque in lower rpm and that supercharger engaugement jerk is gone , I just drove from Florida to California and big issue i have is that car refuses to downshift when using cruise control going uphills , i had it set at 80 mph and the car just lugs and looses speed all the way down to 70 in D or S setting ,i tried Uuto/Dynamic/comfort made no difference , i had to always manually downshift it for it to return to my set CC speed , its very annoying and bad for the engine , i dint experience it untill this road trip because we have zero hills in Floridas, was told by Jackal to flash to latest tune wich i did right before road trip or to flash back to stock, anyone else have issies with TCU tune where car just doesnt downshit going uphill while using CC ? And another note I flashed the car to 91 octane from 93 but the car feels like i got stage 3+ lol ,Q7 just loves this cool non humid air and drives so much better than nin Florida it feels like i adeed 70-80hp worth of mods when all it is is better weather , i had same experience with my f90 m5 , fastest i did 100-200 run in florida was low7s but i California with worse 91 fuel was 5.9 seconds , all because of cool dry air.
  12. #52
    Nov 11 2024
    New York
    Quote Originally Posted by sid33 View Post
    Just flashed my '17 Q7 last night to Stage 1 93 octane. It pulls better and the shifting is much improved. I'll probably go to Stage2/2+ in the next couple weeks. I couldn't get the AMAX launch to work, or at least not like my Q5.
    How you doing AMAX launch on 2017 q7?
  13. #53
    Nov 11 2024
    New York
    2017 Q7 3.0t Prestige. Second month on Jackal stage 2/93, GAS gripped single pulley, BMC filter. Car is flying, tranny so smooth, incredible acceleration. No regrets at all. Would do it again, again and again if asked.
    Thinking about putting GAS titanium intake. Is it worthy? Any one can see advantage in acceleration? Car is making more noise? Any info would be appreciated. Thanks in advance.
  14. #54
    Stage 3 Forum Advertiser Two Rings Bill@GAS's Avatar
    Nov 29 2022
    Stage 2+ B8.5 S4, billet hybrid C7 S7, built B4 S2 Coupe, big turbo B8.5 S4, B9 S5 coupe
    Ontario, Canada
    Quote Originally Posted by Wnyku View Post
    Our intake is the only full 3.5" option on the market, and is a full intake, not just a muffler delete. The titanium construction means more supercharger noise, without being intrusive. The big reason that we went with a full 3.5" construction is that when paired with our 84mm CREC throttle body upgrade, you have the highest flowing intake setup physically possible (which is also supported by Jackal of course). Our 4M intake is a great option for stock TB setups, and especially for people who will be wanting to upgrade in the future! Lots of members on here who are already running this setup can hopefully chime in with their own personal experiences
    https://garageautosports.com/pages/4m-q7
    Owner/Director of Development @ GAS // Garage Auto Sports
    Support performance made locally! -> https://garageautosports.com/
  15. #55
    Nov 20 2023
    Ottawa, Ontario
    I installed the GAS intake a few weeks before dropping in a BMC filter, and just the intake alone unlocked a good amount of supercharger whine. The BMC added a little bit more, and then when I Jackal tuned my rig up to Stage 2+ dual-pulley, this made another big jump in supercharger whine. If noise is what you're after, the GAS intake does a good job, but I went ahead with it primarily for eventual power gains when I muscle up the funds to pair it with an 84mm throttle body upgrade as explained above by Bill from Garage Auto Sports. Jackal has a tune tailored for this extra airflow, which I believe is really only when you'd see the performance benefits of this intake.
    Overall, I highly recommend it!
  16. #56
    Senior Member Two Rings seattlematt's Avatar
    Oct 10 2009
    1981 Fiat Spider, Sprinter, e46 vert
    Is this thread still going? I'm thinking of flashing my 2018 for e85 here in SoCal.
  17. #57
    Nov 29 2022
    Ontario, Canada
    Quote Originally Posted by seattlematt View Post
    Yes, you can run E85 now, reach out to Matt through their site or DM me for details
  18. #58
    Aug 25 2014
    Any plans for a flex fuel tune? Would love to throw some E85 in the tank from time to time
    '18 TT-RS Unitronic Stage 2 E85
    '18 A4 JB4 Map 1 91
    '17 Q7 Jackal Stage 1 91
    '00 Ver6 STI
