For those running non-oem intake box setups, have you guys noticed a difference in fuel trim readings based on a filter size change? I've been chasing maxed out MAF readings after 7k miles of my rebuild / reseal of my vehicle. I've exhausted every option aside from replacing the intake tract which has remained the same. I have my doubts that an intake tract can be causing these issues, but I haven't ruled that one out. There is no flow straightener in place, but I feel like the MAF is located a decent amount away from the end of the tube.
Since my knowledge on fluid flow is quite limited I hope there are some of you guys here that are experienced and can chime in. Will the larger filter size induce more turbulent flow in the intake tract? the MAF sensor location itself has physically not changed between the two setups.
I had limited knowledge before I started the tear down, so I cannot comment on how the fuel trims were before the work was done. I can however confirm that the current base file flashed to the ECU is scaled (MLHFM tables) appropriately for the MAF on the car.
Any input / personal experience with this? Should I source an OEM intake setup and plop a 85mm MAF housing in place? Would like to not keep blindly tossing $ at things if possible.
