Originally Posted by
LJS
Can you display BOOST and AFR at the same time mimicking a duplex display such as the Innovate PSB-1 ...I couldn't ascertain that from their web site
Yes.
On the FIS, you can have multiple preset screens. They refer to it as pages. On my car, I have 8 different pages setup. All can be scrolled through with the turn signal stalk.
My page 1 preset is Boost/Vacuum (via an external map sensor), Wideband AFR, and Oil Pressure.
Here is a picture (not the preview pic below, click the link to my build thread).
https://www.audizine.com/forum/showt...1#post15007912
My page 6 preset, which is what I use most of the time, is Boost/Vacuum in the upper field, then the standard FIS in the lower 2 cells (outside temp and miles to empty is what I use, but that bottom cell you can scroll the same different points as you can on the regular FIS (avg speed, miles per gallon, etc).
I chose the FISControl unit because I wanted things integrated into the stock cluster, and didn't want a color display. Wanted it all to match.
The CAN is more modern, but also ultimately more capable and easier to setup than the FISControl is. It also has it's own standalone touchscreen. The MFD28 can be ordered with a mount for the center pod, so there is no modding needed. I have several clients/friends with it.
