Results 1 to 3 of 3
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    DENSO A/C Compressor Comes Filled with PAG Oil
    EDIT: The Denso compressor does come with oil. I initially opened the wrong drain plug to check. Some of the new oil drain is the clear fluid in the cup in the image below.
    Rs4 Denso AC Compressor Oil
    DEBSO AC Compressor No Oil
    IMG_7896
    RS4 DENSO AC Compressor
    RS4 A/C AC Compressor
    RS4 A/C Orifice Tube
    B7 RS4 Front End
    07 RS4 | 03 M5 | 24 RS6p
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    Just dealt with this, Compressor I ordered had oil in it but it wasn't enough so I just refilled it with the proper amount.
    https://www.audizine.com/forum/showt...-A-C-oil-level
    May 20 2010
    Yep. When I replaced my B7's compressor back in 2015, I had to add PAG oil. Thankfully the kit I bought also included it. But I still had to add a bit, turn, add a bit, turn, etc.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
