The problem were 2 separate issues:
1) Battery voltage drop
2) State of battery was at 74%
Lets break it down. The voltage drop caused the car to not start at all and it triggered all the safety systems. I was able to just put a battery charger at 12 Amps for 10 seconds to satisfy the voltage drop until I read 12.70 volts on my DMM. That is when I told my son to go ahead and crank the engine to start it(it started). The safety lights remained on and I will explain why.
Apparently even though I satisfied the voltage and I was able to start the car the state of charge was at 74%. I found that out trough the dealer. The dealer could not even run a full diagnosis until the state of charge was at least at 80%.
The dealer performed a full diagnosis and although I gave them reference to the latest TSB 2069999/4 my car did not generate a fault code needed for the TSB (the fault code needed for the TSB is DTC B114815), however, the dealer was able to address the safety lights triggered by the battery voltage drop and the battery state of charge.
What have I learned from this and what I would like to warn you about? well, apparently this is the summary:
1) A voltage drop will cause the car to not start due to sensitive voltage threshold on the electronics
2) A jump start will satisfy that voltage and perhaps will allow you to start the car but will not turn off the safety lights
3) Your battery will need to be at 80% and above state of charge at all the times no matter what and can't run full diagnosis until is at least at 80% otherwise you will generate more codes
4) The TSB (Technical service bulletin) was not applicable due to not generating a crucial fault code needed
There you have it folks. Why my brand new car went below 80% charge despite using it 5 days a week 2 hours /day plus weekends? I don't know but those of you living in the north and East coast where it gets cold you might want to invest on a trickle charger. Last, I was advised to unplug my radar detector when I am not using the car as a precautionary step.
I know that this is a common occurrence across the automotive industry (battery weak/low) but if I can save you the time from having to go to the dealer or have your car down for a day or at least be informed ahead of your service scheduling I think is worth writing this post. Best of luck and now we know.
