Hybrid View
    Dec 25 2016
    Austin, TX
    P003300 Turbocharger bypass valve control circuit
    Hi Everyone, I’m looking at an RS7 for sale and hoping someone can help me out. I scanned it with OBD11 and it has a soft code - P003300 Turbocharger bypass valve control circuit. The car had the turbo screen recall performed recently, it’s for sale at a non-Audi dealership (dealership took it to Audi for the recall / service before putting it on the lot, 55k service and charge air coolant pump was also replaced).
    Is this something to be concerned about or could it be from the recall work?
    Junior Member Two Rings
    Feb 24 2023
    Ohio
    Check you connections that are near the intercooler on top of the engine I'll send a pic when i can. I had the same issue after my recall and the stealeship broke the clips and left them unplugged
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by Skyflier2 View Post
    So go see if it's disco... get the dealer to take off a couple $k for the drama you'll have to fix and then before you drive off the lot, go plug it back in!!
    Beat them at their own game!
    Cheers,
    KS
    Feb 24 2023
    Ohio
    https://www.audiworld.com/forums/s6-...ation-2902152/
    Look at the fifth post. Mine had come undone on the diverter valves(in blue)
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Thats diverter valve bro. make sure its plugged in and wires are good. if it is then change them. Cheap and easy fix. and I mean so easy a caveman can do it
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
