Results 1 to 16 of 16
    Junior Member Two Rings Ptravaglini's Avatar
    Oct 12 2023
    New york
    IE stage 2 emissions scan question
    Hey Everyone,
    I couldn’t find anything on this specifically so I’m hoping someone may have an answer. I put in the IE HFC DP and went stage 2 (great btw) and currently have no cel. Before flashing to stage 2 I looked in the emissions part of the app and all were ready except “catalyst heater” which said “not equipped”. Since going stage 2 the “catalyst” also says the same thing. There are green circles that are illuminated for everything else except 1 that is still takes a few cycles from my understanding but it just is not green. My question is obviously it’s from the coding but what does “not equipped” do in terms of passing inspection being that it seems it’s different that something that isn’t ready. Thanks for any help
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    IE fucks with emissions. I believe they do the old, N/A flag aka the test will never run when tuned and therefore never throw a code. Now, depending on ur state, if you go for an inspection, the new systems when they plug in cross reference the factory tests/flags with what your car is displaying. If there are inconsistencies, they will know ur ECU has been tuned and then if your in MA, you have to go to a special inspection center to get ur car cleared aka not fucking fun. Ur in NY, dont know how detailed or the processes are for inspections.
    End of day, stay away from IE tunes in general. Their hardware is great, their software is not. They pull back the knock protections real fucking far to get those big numbers which can be and basically is dangerous for your motor. They also don't tell you they fuck with emissions, but they 100% do on stage 1 and 2 tunes.
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Feb 22 2023
    Quote Originally Posted by Gberg888 View Post
    Read the same thing about IE tunes. Do you have a tuner you would recommend instead?
    Dec 25 2004
    Earth
    Quote Originally Posted by kev0 View Post
    The fuel injectors on these cars go bad! No CEL to say 'Bad injector'! You realize it when the DSG doesn't shift or the engine isn't running right.
    Correct fueling in these motors is critical especially under high sustained boost!
    Bad fuel injector(s) can destroy these engines in seconds! Cause most people keep pushing boost...thinking it will correct itself!
    All Audi A3/S3 tunes are the same...cause they are all 'tuning' the same motors and same ECUs!
    Some people are mad cause they blame IE for their engine failure...with nothing but speculation as proof!
    https://www.audizine.com/forum/showt...1#post14623381
    I have United Motor Sports on my 2015 S3. Love it! DSG and Haldex too! Replaced injectors twice on that motor and finally replaced the entire motor for excessive oil consumption.
    https://www.audizine.com/forum/showt...lacement-motor
    Upon disassembly of this motor I found leaking exhaust valve guide oil seals and 1 bad injector...
    Audi went to a improved piston oil control ring on later built motors.
    I have APR on my 2018 S3. Its typical smooth APR tune! DSG too.
    Get whats available near you and fits your needs!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Feb 22 2023
    Quote Originally Posted by MikTip View Post
    thx for the info. Is there a preferred set of fuel injectors for this car then or will it have to be OEM every time I get them replaced? What brand of injectors did you go with?
    Oct 12 2023
    New york
    Thanks for Info MikTip always helping out lol. Any recommendations on when to service/check these? And which you use
    Oct 12 2023
    New york
    Also do you have any input on the IE tunes? I have seen a lot of good things which is why I chose them however Gberg is also all over with his experience
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Ptravaglini View Post
    Their tunes are garbage, blowing B9 S4's left and right, and f with emissions, even stage 1 tunes, avoid at all costs. IE hard parts however are very very nice products.
    Stage 1 more than you RS3
    Junior Member One Ring HmanS3's Avatar
    Sep 29 2018
    '16 S3
    Chicago, IL
    I have a '16 S3 that I picked up in the fall of 2018 with 38K miles on it. Currently has 105k miles. Was IE stage 2 93 for most of those miles. Switched to EQT for their E30 tune from 90k-100k. I then made the switch back to IE for their stage 3 Trueflex tune for the GT2260S. No issues or complaints. I log from time to time and have no concerns with the tuning. Car runs like a top. Couldn't be happier.
    Gberg is the only one I've heard of that popped an engine while running an IE tune on the MQB platform. Not saying it hasn't happened to anyone else but I've not come across it on here or any of the facebook groups.
    '16 S3 - GT2260S, IE stg 3 Trueflex, IE IC & DP, Autotech HPFP, AMS Intake & Bilstein B16s
    Jul 20 2019
    Quote Originally Posted by HmanS3 View Post
    Guess you missed their original RAL release....
    Jun 16 2011
    996tt
    MA
    For those who are interested:
    https://www.reddit.com/r/GolfGTI/com...h_ie_and_just/
    IE makes great hardware... There software is shit though.
    Garage:
    Established Member Two Rings srb_brah's Avatar
    Sep 27 2024
    St. John, Indiana
    bumping an old thread, northwest indiana here, just got an s6 with stage 1 ECU/TCU from IE, however I did the readiness check on their app, all green circles, no CEL, plugged in my own OBD reader and no faults at all, should I still be worried about passing emissions?
    edit: I still have my cats as well
    2017 S6 Premium Plus - Ibis White | Arras Red & Black Optics | Stage 1 IE | Borla Catback Exhaust | RocEuro CAI | 034 Trans Insert | 32K Miles
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    Quote Originally Posted by srb_brah View Post
    I live in SE Wisconsin and do an obd emissions test. I had IE stage 2 on my b8.5 a4 with a hfc and passed without issues, I also currently am stage 2 on my b8.5 s4. In my state they will show up as not supported and don’t throw a cel.
    2013 S4 Imola Yellow / IE Stage 2 / ECS Supercharger Pulley / IE Intake / ECS HX / AWE Non Resonated Downpipes / AWE Touring Exhaust / Vogtland Coilovers / Rs4 Grill / Eurocode SS / Black Forest Shift Knob / BBS LM-R / Alcon BBK / S6 Rear Brakes
    1996 Golf Harlequin #10
    Sep 27 2024
    St. John, Indiana
    Quote Originally Posted by eurojunkjon View Post
    Thanks Euro, this seems like what the majority of my friends said as well, I think it all comes down to the particular state regulations and how each area handles their emissions, I should be more than fine then :)
    Like Wisconsin we do the OBD emissions test here as well...
    The only section where it's not in a READY state on the IE app is the fuel system, I think I just have to drive it more (not my daily) and it's always been on a full tank normally too. The good news is my EVAP says ready so I think that's all they care about, I'm not sure what exactly northwest Indiana looks for but my buddy with a stage 1 APR tune says he passes with flying colors
    Mar 12 2017
    2013 S4
    Burlington, wi
    In Wisconsin I’m also allowed to have 1 parameter that is “not ready” to pass
    Sep 27 2024
    St. John, Indiana
    got it, appreciate the help!
