So a while ago the intake side balance shaft seized on my b8 a4. I tore it down and fixed it and installed a new timing chain at the same time.
Car started up and ran with no codes but after a few minutes the low oil pressure light came on. I shit it off and after some research realized that I got sold fake balance shafts which are known for causing low oil pressure due to bad tolerances.
Now, I’ve ordered new Oem shafts and gonna swap them and hope all is well. My main concern though, is that the old seized shaft was missing two of the plastic strainers when I pulled it. I’m thinking the probably melted but no idea where the pieces went. Was hoping for some advice on how to possibly clean the oil passages to make sure the new shaft won’t starve of oil. Any thoughts?
