Results 1 to 10 of 10
    Junior Member One Ring
    Jul 07 2022
    Selden, NY
    Popping noise at 7mph from stop
    Hey all, I have this subtle pop/knock noise that I hear when I hit 7 mph starting from a stop.
    If I accelerate hard from a stop, I don't hear it.
    It doesn't matter how slowly I accelerate, it always happens at 7mph.
    No popping or clicking when turning (unless hitting 7mph).
    I was told it was my ball joint from 2 mechanics and got all new front control arms (all 8) and it's still there.
    My other mechanic just told me my front left CV axle had a little play. Could this be the culprit?
    Also, I have tire noise and slight vibration above 70mph. Could this be the CV axle?
    Sent from my Pixel 7 using Tapatalk
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Now, take this from the guy who’s turned three wrenches in his life and now thinks he’s a mechanic… But my wheel bearings are going bad and at low speeds I hear clicks which is what I’m hoping are the issue
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    could it be the doors automatically locking?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Jul 07 2022
    Selden, NY
    Quote Originally Posted by IHave2Turbos View Post
    I wish!
    Jul 07 2022
    Selden, NY
    Quote Originally Posted by AudiInMyA7 View Post
    Sounds like CV axles to me
    Dec 14 2017
    Get it on a hoist and spin the wheels up. Do you hear a growling or humming noise? if so thats a wheel bearing. I do know of a TSB that states a 'clunk' when braking at lower speeds may pronounce itself. It says to lubricate where the bearing meets the steering knuckle housing.
    If you have aftermarket brake pads that can also be the cause of a clunk from a stop. CV axles will have some play in them. Probably not enough to cause a clunk. Unless you are hearing a clicking noise when turning at full lock or on hard acceleration i wouldn't bother with the CV axles. They already got it wrong with the control arms, good chance they are wrong about the CV axle.
    Jul 07 2022
    Selden, NY
    As of the 5/6/2024 update stage 1 Jackal tune, the clunk is gone!
    Apr 05 2007
    Quote Originally Posted by Psycade View Post
    99% certain if you're 2016+ (CREC engine) the clunk was your magnetic supercharger clutch engaging/disengaging. The Jackal tune locked it so it's not activating on/off anymore.
    today: 2016 A6 Jackal Stg1 E85
    yesterday: 1990 Audi 90 Quattro, 2x B5S4, 2 x B5A4, 1xB7A4, 1x C5A6
    Nov 03 2019
    San Francisco
    I had this too. Freaked me out because I thought something was knocking in the suspension or subframe. Went away once I was tuned.
    Jul 07 2022
    Selden, NY
    I don't have the CREC engine, I have the 2013 - I think it has something to do with the motor mount solenoids.
