Results 1 to 11 of 11
    Junior Member Two Rings
    Nov 27 2015
    Bellevue, WA
    Random faults popping up in unison
    For the past year or two, I will occasionally get a series of faults pop on the instrument cluster of my 2013 S6 ranging from air suspension faults, headlight faults, active cruise control faults, rear differential faults, etc that all come up together.
    There is no real pattern to when these come on other than when the car is being driven. As soon as it happens, you can feel the air suspension lock into a very stiff setting (stiffer than Dynamic).
    I have always been able to clear the warning messages by restarting the car.
    Sometimes the faults don't come back for 6-8 months and other times they reappear in a few weeks. Again, no real pattern.
    I have taken it to my local Audi dealer twice for this and they have had no luck tracing the issue.
    Any ideas?
    See fault download below from the most recent occurrence on 10/7/2023:
    Nov 27 2015
    Bellevue, WA
    Saturday,07,October,2023,08:58:58:61870
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 23.3.1.0 (x64)
    Data version: 20230421 DS346.2
    www.Ross-Tech.com
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
    46 47 52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90 A9 BA
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    82-Head Up Display -- Status: OK 0000
    84-Night Vision -- Status: Malfunction 0010
    85-On Board Cam. -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8E-Image Processing -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 906 014 B HW: 4H0 906 014
    Component: 4.0l V8TFSI / H61 0009
    Revision: NCH61--- CVN: 48B27F8E
    Coding: 0A2500326546000E1000
    Shop #: WSC 47990 001 1048576
    ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
    ROD: EV_ECM40TFS0114G0906014B.rod
    VCID: 21431CF33038449BE4-8074
    VINID: 9D195A0925930947801051C504F603938C
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G1 927 156 S HW: 0B5 927 156 K
    Component: 0B5 40TFSINAR H08 0014
    Revision: --H08--- CVN: 0000EEEE
    Coding: 000001
    Shop #: WSC 11699 005 1048576
    ASAM Dataset: EV_TCMDL501021 001025
    ROD: EV_TCMDL501021.rod
    VCID: 3D7BC083AC80007BE0-8068
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
    Component: ESP PREMIUM H09 0361
    Revision: -------- Serial number: --------------
    Coding: 65B64F01A66DF2804B00
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ESPPremiAU57X 004028
    ROD: EV_ESPPremiAU57X_004_AU57.rod
    VCID: 3875D19783A2255333-806C
    3 Faults Found:
    0055 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:42:14
    VzRef: 1E
    Bit Info 1: 00
    Bit Info 2: 40
    Bit Info 3: 26
    Bit Info 4: 1F
    F-Path: 00
    F-Type: B9
    Uz: B8
    0657 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:43:21
    VzRef: 00
    Bit Info 1: 00
    Bit Info 2: 40
    Bit Info 3: 06
    Bit Info 4: 1F
    F-Path: 00
    F-Type: BC
    Uz: B8
    0081 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:44:57
    VzRef: 00
    Bit Info 1: 80
    Bit Info 2: 40
    Bit Info 3: 06
    Bit Info 4: 1F
    F-Path: 01
    F-Type: 01
    Uz: B8
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 FR HW: 4H0 907 064 CR
    Component: BCM2 2.0 H32 0560
    Revision: 00002001
    Coding: 0D882006000000000000
    VCID: 7EF9078FE906DB63B9-802A
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 2312000168266006
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
    Component: KLIMA 4 ZONEN H13 0076
    Serial number: 04081200040188
    Coding: 688120B85D
    ASAM Dataset: EV_AirCondiComfoUDS 002036
    ROD: EV_AirCondiComfoUDS_002.rod
    VCID: 62C153FF75BE1F83BD-8036
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CG HW: 4H0 907 063
    Component: BCM1 2.0 H12 0130
    Revision: 11012002 Serial number: 00000001397094
    Coding: 09072091073C9FE2A90008C7A0003800CF9CD308A208022180 01085C7B00
    VCID: 6FE72ACBBE6CA2EB22-803A
    Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
    Component: WWS57X 120717 H36 0080
    Serial number: 120725152559
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 20481838
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
    Component: E1 - LDS H07 0044
    Serial number: 03 08 2012 00001119
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 0000002274555R2GBR02
    Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
    Component: A31 LED Mod1L H03 0006
    Serial number: 00000024071200010433
    Coding: 110000
    Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
    Component: A27 LED Mod1R H03 0006
    Serial number: 00000030071200010351
    Coding: 110000
    Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
    Component: EVLS-SG H08 0300
    Serial number: WA103816000001673764
    Coding: 020300
    Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: C8388046000000000001
    2 Faults Found:
    00471 - Control Module for Elect. Regulated Dampers (J250)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 226
    Mileage: 144070 km
    Time Indication: 0
    Date: 2023.10.07
    Time: 08:42:00
    01324 - Control Module for All Wheel Drive (J492)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 226
    Mileage: 144070 km
    Time Indication: 0
    Date: 2023.10.07
    Time: 08:45:00
    Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
    Component: PARKHILFE ACC H01 0072
    Revision: 11001001 Serial number: 61061221400749
    Coding: A8E90A
    ASAM Dataset: EV_EPHVA18AU57X0000 003008
    ROD: EV_EPHVA18AU57X0000_003.rod
    VCID: 77F712ABCE3CEA2BFA-8022
    Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 561 A HW: 4G0 907 561
    Component: ACC3 H17 0400
    Serial number: 00000000000000 Dataset Number: 4G0909863C 0034
    Coding: 7601010102
    ASAM Dataset: EV_AdaptCruisContrAU57X 002010
    ROD: EV_AdaptCruisContrAU57X_002.rod
    VCID: 285501D75302B5D3A3-807C
    3 Faults Found:
    10240 - Sensor for Automatic Distance Control
    C110B F0 [008] - Limited Visibility
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 143617 km
    Date: 2023.09.29
    Time: 07:41:22
    Control Module temperature: 19 °C
    Voltage terminal 15: 14.305 V
    Velocity_vehicle_reference: 38.18 m/s
    Longitudinal_acceleration_vehicle_reference: -0.10 m/s²
    140032 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:50:16
    Control Module temperature: 32 °C
    Voltage terminal 15: 14.375 V
    Velocity_vehicle_reference: -0.02 m/s
    Longitudinal_acceleration_vehicle_reference: 0.58 m/s²
    93440 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 15
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:42:41
    Control Module temperature: 20 °C
    Voltage terminal 15: 14.373 V
    Velocity_vehicle_reference: -0.01 m/s
    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
    Component: Airbag10.43 H32 0032
    Revision: -------- Serial number: 003D8002A0PI Dataset Number: 4G0909602E 0007
    Coding: 303234373131303030344A55304C34473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 336FE6BB9AC4C60B06-8066
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H15 0046
    Serial number: 6940000Y120000KV3X0E
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB404R1G1DOB1TY
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 3585HRB40631G0QMFH9N
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 3515JRB40691D2ASG9VS
    Passenger side rear thorax airbag crash sensor:
    Serial number: 3525JRB40671DKASAGV3
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB40044UJ4O9H5Y
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB40044UJ4OIPHL
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
    Component: Lenks.Modul H03 0005
    Revision: -------- Serial number: 90372LH5001JB
    Coding: 0004FC
    VCID: 3875D1978BA2255333-806C
    Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
    Component: E221 - MFL H08 0010
    Serial number: 27 04 2018 E0040222
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G0 920 981 M HW: 4G0 920 981 M
    Component: TBenUsaAccNv H76 0515
    Revision: 28460207 Serial number: 658090812596024
    Coding: 0BCF09059F51D705020200
    ASAM Dataset: EV_RBD4K 004046
    ROD: EV_RBD4K_AU57.rod
    VCID: 356BD8A394B0D83B28-8060
    2 Faults Found:
    16776966 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 29
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:41:55
    16776972 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 20
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:45:14
    Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
    Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
    Component: J533--Gateway H11 0035
    Revision: -------- Serial number: 00000000637511 Dataset Number: 4G0909515C 0062
    Coding: 00E1034800
    GVL: FDAFE8CCFEE26C0D5100
    ASAM Dataset: EV_GatewPkoUDS 001016
    ROD: EV_GatewPkoUDS_001_AU57.rod
    VCID: 71E32CB3A058B41B34-8024
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0141
    Serial number: 00000000003790042919
    2 Faults Found:
    5014 - Ride Level Control Module
    U0132 00 [008] - No Communications
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 30
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:41:55
    Voltage terminal 30: 14.2 V
    Voltage terminal 15: 14.3 V
    Control Module temperature: 31 °C
    System status: Terminal 15 on
    IN ESP_standstill flag: no standstill detected
    Engine running: On
    IN ZAS_Te_X: On
    Terminal 15 status via CAN: On
    Terminal 15 status: On
    Datenfeld: 0
    5001 - Control Module for All Wheel Drive Clutch
    U0114 00 [008] - No Communication
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 17
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:45:15
    Voltage terminal 30: 14.1 V
    Voltage terminal 15: 14.2 V
    IN ESP_standstill flag: standstill detected
    Engine running: On
    IN ZAS_Te_X: On
    Datenfeld: 0
    Address 22: AWD (J492) Labels: 4H0-907-163.clb
    Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
    Component: 4 Wheel Drive H15 0013
    Serial number: 003107120001011 Dataset Number: 4G0909104A 0017
    ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
    ROD: EV_AllWheelDiffeQSPFR.rod
    VCID: 275702EB5E1CBAABAA-8072
    1 Fault Found:
    0305 - Function Restriction due to Faults in Other Modules
    U1113 00 [137] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:44:57
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
    Component: KLIMA FOND H07 0076
    Serial number: 06081200040422
    Coding: 20
    ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
    ROD: EV_ClimaContrUnitRearUDS_002.rod
    VCID: 3777D2AB8EBC2A2B3A-8062
    Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
    Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
    Component: LUFE-DAEMPFER H18 0782
    Dataset Number: 4G0909553F 0034
    Coding: 008002
    ASAM Dataset: EV_AirSuspe 003024
    ROD: EV_AirSuspe_VW51.rod
    VCID: 2E59F7CF71E6EBE369-807A
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4G8 959 760 HW: 4G8 959 760
    Component: MEM-FS H03 0154
    Revision: AA000000 Serial number: 00000035266023
    Coding: 00581B0000002001000001010101102030303232203232
    VCID: 77F712ABC63CEA2BFA-8022
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
    Component: SARA 6D red H02 0053
    Revision: -------- Serial number: EJ1BPA7E003TFJ Dataset Number: 4G0909573C 0006
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA2 005011
    ROD: EV_SARA2.rod
    Address 3C: Lane Change Labels: Redir Fail!
    Part No SW: 4G0 907 566 D HW: 4G0 907 566
    Component: J769 SWA MasterH01 0050
    Revision: 00H01000 Serial number: 6PZ 010 287-03
    Coding: 0000001
    Shop #: WSC 23499 444 123918
    VCID: 3065E9B7A3D2FD137B-8064
    Subsystem 1 - Part No: 4G0 907 568 D
    Component: J770 SWA Slave H01 0050
    Subsystem 2 - Serial number: 6PZ 010 287-23
    Subsystem 3 - Serial number: 5F13.08.1200H010003CF20223ÿ
    Subsystem 4 - Serial number: F20223ÿ
    Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
    Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
    Component: TSG FA H04 0506
    Coding: 011F17005E00628002000013
    VCID: 458BA863CC5048BBB8-8010
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
    Component: RCEPS H36 0010
    Revision: 00001000 Serial number: 0027754933 Dataset Number: 4G0909852H 0027
    Coding: 101001010000
    ASAM Dataset: EV_RCEPS 009008
    ROD: EV_RCEPS_009.rod
    VCID: 3261E3BF65DECF030D-8066
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0181694786
    Coding: 0106063A00FA408580B0088002050300000000000000000000 0000000000
    Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
    Component: GTO BF H01 0080
    Serial number: 00000000000000100761
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
    Component: J245 PS40.039 H01 0008
    Serial number: WOO1756486B
    Coding: 101F00
    Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00001756553
    Coding: 010000
    Address 47: Sound System (J525) Labels: None
    Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
    Component: BOSE-G3C7-ANC H02 0540
    Revision: CJ002700 Serial number: 00000000003396
    Coding: 030000
    VCID: 1C3D2D071F5A697337-8048
    Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
    Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
    Component: TSG BF H04 0511
    Coding: 011F17005E00628002000002
    Shop #: WSC 39453 004 1048576
    VCID: 448DB567C76A71B3AF-8010
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
    Component: EPB-4 H03 0013
    Revision: -------- Serial number: 00000000431453 Dataset Number: 4G0909522B 0002
    ASAM Dataset: EV_ParkiBrake 001027
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2B5FFEDB42F49ECB4E-807E
    2 Faults Found:
    459264 - Function Restriction due to Faults in Other Modules
    U1113 00 [000] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    463616 - Function Restriction due to Faults in Other Modules
    U1113 00 [000] - -
    Nov 27 2015
    Bellevue, WA
    Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
    Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
    Component: ....LWR12.... H02 0010
    Serial number: 120810-0002-063
    Coding: 12216F601002A400
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic_AU21.rod
    VCID: 2D5BF0C37CE090FB50-8078
    1 Fault Found:
    120580 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 33
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:41:55
    Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
    Part No SW: 4G0 035 082 H HW: 4G0 035 082
    Component: Radio U SIRIU H60 0138
    Revision: AB001007 Serial number: 156H$0C7621348
    Coding: 020007010000000001
    VCID: 254B08E32C10A8BB98-8070
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 746 J HW: 4G0 035 746 B
    Component: H-BNT-NA H49 1038
    Revision: -------- Serial number: 194HZ0C7510066
    Coding: 060200000203FDEF7D16CB1E00000003100001000000000000
    VCID: 2E59F7CF79E6EBE369-807A
    Subsystem 1 - Part No: 8R0 060 884 AM
    Component: NAR 2012 0605
    Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
    Component: DU8 C7 SV H42 0021
    Serial number: AUZ8ZDC94028RS6
    Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
    Component: E380 BDT C7 H11 0204
    Serial number: 90349LH3000KJ
    Subsystem 4 - Part No: 8R0 060 961 D
    Component: CD-Database 4353
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 144070 km
    Time Indication: 0
    Date: 2023.10.07
    Time: 08:42:42
    Freeze Frame:
    Bin. Bits: 00000000 01000000
    Bin. Bits: 00000000 00000000
    Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0506
    Coding: 010F17004000628002000002
    VCID: 4993A453E048ACDB5C-801C
    Address 6C: Back-up Cam. (J928) Labels:* None
    Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
    Component: TopView H05 0111
    Revision: 11001001 Serial number: 82330JF0051758
    Coding: 0201000001010000000102000000
    ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
    ROD: EV_CamerSysteTopViewAUDI_005.rod
    1 Fault Found:
    9617993 - Proximity Camera
    B145C 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 239
    Mileage: 137509 km
    Date: 2023.06.20
    Time: 17:37:03
    Voltage terminal 30: 11.8 V
    Terminal 15 status: Terminal 15 on
    Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
    Component: TSG HR H03 0506
    Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
    Part No SW: 4G0 919 604 G HW: 4G0 919 604 G
    Component: HeadUpDisplay 006 0106
    Revision: 00000000 Serial number: 00000000000000
    Coding: D60000
    ASAM Dataset: EV_HUDContiC7 001020
    ROD: EV_HUDContiC7.rod
    VCID: 2F67EACB76ECE2EB62-807A
    Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
    Part No SW: 4H0 907 547 F HW: 4H0 907 547
    Component: NV-ECU-Gen1 H09 0042
    Serial number: 0K84AE40078358
    Coding: 1311
    ASAM Dataset: EV_NightVisioGen1 001002
    ROD: EV_NightVisioGen1.rod
    Night vision system camera:
    Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
    Component: NV-CAM-Gen1 H08 0007
    Serial number: 00000000001219100481
    1 Fault Found:
    9986 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 13
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:43:04
    Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
    Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
    Component: DPC-SG H25 0038
    Revision: -------- Serial number: 262130025421000 Dataset Number: 4G0909547C 0028
    Coding: EA060000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 26490FEF5916A3A391-8072
    1 Fault Found:
    0706 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 36
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:41:55
    Outside temperature: -43.5 °C
    Control Module temperature: 33.0 °C
    Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 541 A HW: 4G0 907 541
    Coding: 7601010102
    ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
    ROD: EV_AdaptCruisContr2AU57X_002.rod
    1 Fault Found:
    34048 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 144071 km
    Date: 2023.10.07
    Time: 08:47:15
    Control Module temperature: 23 °C
    Voltage terminal 15: 14.366 V
    Velocity_vehicle_reference: 14.91 m/s
    Longitudinal_acceleration_vehicle_reference: -0.83 m/s²
    Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
    Part No SW: 4G0 907 107 D HW: 4H0 907 107
    Component: BV-SG H30 0038
    Serial number: 005000050808127 Dataset Number: 4G0909548C 0026
    Coding: 04C19A1A0111
    ASAM Dataset: EV_BC7 001001
    ROD: EV_BC7.rod
    3 Faults Found:
    0148 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 19
    Reset counter: 226
    Mileage: 144071 km
    Date: 2023.10.07
    Time: 08:46:17
    Outside temperature: 14.5 °C
    Control Module temperature: 27.0 °C
    0165 - Function Restriction due to Faults in Other Modules
    U1113 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 15
    Reset counter: 186
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:44:58
    Voltage terminal 15: 14.4 V
    Control Module temperature: 26.0 °C
    0091 - Function Limitation due to Missing Video Data
    C1108 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 15
    Reset counter: 226
    Mileage: 144070 km
    Date: 2023.10.07
    Time: 08:42:41
    Outside temperature: 13.5 °C
    Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
    Component: RGS-VL H13 0080
    Dataset Number: 4G0909614B 0005
    Coding: 0066E608031F037E070308014240C2010000
    ASAM Dataset: EV_RGS_L 002004
    ROD: EV_RGS_L.rod
    VCID: 3163ECB360D8F41B74-8064
    3 Faults Found:
    12583697 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:49:57
    12583976 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 55
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:47:32
    12583979 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:49:35
    Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
    Component: RGS-VR H13 0080
    Dataset Number: 4G0909615B 0005
    ASAM Dataset: EV_RGS_R 002004
    ROD: EV_RGS_R.rod
    3 Faults Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:49:57
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 55
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:47:32
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 226
    Mileage: 144072 km
    Date: 2023.10.07
    Time: 08:49:35
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0010
    Serial number: 120717201475
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 2C5DFDC747FA99F347-8078
    Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
    Part No SW: 4H0 907 145 HW: 4H0 907 145
    Component: AEM - LEAR H05 0006
    Revision: 00001001 Serial number: 97804000594104 Dataset Number: 4G0909578A 0009
    ASAM Dataset: EV_AEMLearAU64X 002014
    ROD: EV_AEMLearAU64X.rod
    VCID: 66C94FEF999663A351-8032
    End-------------------------(Elapsed Time: 07:35)--------------------------
    Established Member Two Rings schonc's Avatar
    Aug 21 2021
    Alberta
    Seems like most of the faults are from communication not working.
    One thing that jumped out to me was that your camera thinks the outside temperature is -43.5 deg C.
    With all the other things going on, that seems like nothing to worry about. But I seem to recall someone else posting on AZ that mentioned a rock hit on the front temp sensor caused a load of seemingly unrelated faults.
    Sent from my SM-S911W using Tapatalk
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by schonc View Post
    I can affirm this... on a B8.5 S4... a crushed temp sensor cause an astounding array of seeming unrelated faults. ABS, EPC, TCU, Sport Diff..... to name a few.
    I just happen to pick the Air Temp as the low hanging fruit problem to start the troubleshooting and POOF!!! all the other issues cleared them selves!
    Gotta love Audi and their cross connected systems!!
    Good Luck!
    KS
    Nov 27 2015
    Bellevue, WA
    Good catch! That appears to be for the front-facing camera.
    Why would that read a separate temperature from the sensor that provides the exterior temperature to the instrument cluster display, which read perfectly accurate on my car?
    When people had this correlated fault, was the exterior temperature reading displayed in the instrument cluster also way off?
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by huntercross View Post
    Any ideas?
    Seems unlikely given the long time period you've had the problem, but have you checked the battery? A mildly weak battery may still start the car, power lights, etc., but will allow voltage variations that are enough to trigger a variety of faults. Several AZ threads discuss this.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Nov 27 2015
    Bellevue, WA
    Quote Originally Posted by Alabama View Post
    I have checked out the battery and it is all good. Thanks for the idea though.
    - - - Updated - - -
    Quote Originally Posted by Botbasher View Post
    Good Luck!
    KS
    When you had this issue, was the outside temperature readout in your instrument cluster also showing the wrong outside temp?
    Established Member Three Rings Avantly's Avatar
    Oct 02 2023
    Squirrels, Chickens, and then there's the mice :/
    "Pure Michigan"
    Have you posted this over at the ross tech forums? The functions restricted due to missing messages appears to be a key clue - You may want to get an oscilloscope on the can bus and see what the waveform actually looks like, you may have a module or water ingress issue that has you right at the edge of signal integrity issues. I also have a '13 S6 and haven't had any issues with it but I'm barely over 100k miles and I check the drains religiously. I know that the B9(and maybe B8/B8.5?) Q5's are having issues with water ingress into the BCM (due to placement of the BCM directly below the rear passenger side sunroof drain tube) causing similar issues at first (and later, uhh, BCM goes bye-bye) and I would wonder if maybe you have a little bit of corrosion in a module from water ingress. I've also run into issues on the C6 platform caused by modules using press-fit for the connector pins into the circuit board instead of soldering them, resulting in signal integrity/communication issues. If you happen to have an oscilloscope you can take a look at waveforms on the CAN bus and compare to reference waveforms (or another car with no issues).
    The guys at ross tech are extremely effective at weeding out the irrelevant codes and helping you find root cause.
    Nov 27 2015
    Bellevue, WA
    Great tip with RossTech! Thank you!
    My car has been garage kept since new, but probably still should check the drains.
    Oct 02 2023
    "Pure Michigan"
    Even with keeping it in the garage, you will get little bits of tree and plant matter in places, especially the cowl. A drain that isn't completely clogged with debris can become completely clogged in the winter if you live in an area that sees freezing temperatures, water will get in the debris either from driving the car and warming it up (and melting snow or ice which drips into the cowl) and the next time you shut it down in freezing temps, the moist debris freezes and turns into a complete clog until the next time you drive it long enough to melt all of the ice in the debris. I check my drains regularly and I have never had water issues except from separated drain tube connectors on the sunroof and rear washer fluid hoses on the avants, and I've had dozens of audis over the years.
