Results 1 to 7 of 7
    Sep 08 2016
    ECS Tuning Coilovers with extras $550 plus shipping SoCal
    I have a set of used ECS Coilovers from my 2010 A4 Avant 2.0 Quattro.
    They were on the car for ~18,000 miles (purchased directly from ECS Tuning on February 26, 2020, installed on the car around September of 2020). For some reason, I have an extra pair of shocks, and an extra spring. I believe one of the shocks was clunking, so ECS sent me a replacement or 2 in September of 2020, shortly after installation. I don't remember the exact reason, but I can tell you that the replacements have been on the car and worked really well.
    I will also include a set of adjustable upper control arms, used, with squished boots. I would advise you to inspect them before installation, to make sure they are ok to install. They were taken off in working condition, with a good alignment.
    I went to Air Lift and purchased new suspension hardware. The ECS coilovers were removed in July of this year, in working condition. They are dirty, and the large adjustment nuts do have wear from me trying to adjust them and tighten them in a tight space. Still functional and work just fine. I would recommend a bit of Locktite on the nuts to keep them from spinning loose.
    I am looking for $550 plus actual shipping (this is going to be heavy, so estimate $75-100 shipping possibly more), via PP Friends and Family or Venmo. I can do some research if you tell me your zipcode, and cheaper if a business address. Local pickup in Chino or Upland, CA welcome.
    I believe the only things missing are the spanner wrenches and the adjustment knobs (hex key), along with the nuts and washers/installation hardware. Those should be bought new anyways. Please verify the parts you need before tearing into your car, as I am not 100% sure what other hardware is missing. I can tell you that the coilovers are complete.
    Thanks for looking!
    https://www.ecstuning.com/b-ecs-part...025412ecs01~a/
    -Pras-
    Nov 11 2013
    2014 Nissan 370z , 2010 APR K04 GTI (SOLD!)
    OC/CA
    can you say WHERE in So-Cal you're located, should someone local-ish wants to pick up instead and avoid shipping costs?
    Sep 08 2016
    Quote Originally Posted by ROOSTER1050 View Post
    You already know where I live, but yes, updated
    Nov 11 2013
    OC/CA
    Quote Originally Posted by prasamin View Post
    memory like swiss cheese in my older years
    Sep 08 2016
    Up.
    Sep 08 2016
    Up.
    Sep 08 2016
    Bump. $500 cash, picked up from Chino, CA 91708
