Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 232
  1. #161
    Jan 11 2020
    Ontario
    I meant to type PCV. The fix which involves using a Mishimoto check valve
    2018 Audi S4 Prestige - Daytona Grey
    Logic Street Performance custom tune via Deadbeef Flash platform | Andy's Big Ass CF Intake | 034 J Hook Rotors | iSweep 2000 pads | Valved Exhaust Titanium straight pipe | CAP Decat 2.0 revision | CTS Turbo Intercooler | APR DTR8868 Turbo + RS Injectors + HiFlow HPFP + LPFP | Osman BicepBrah Ali PCV fix | OEM 4-bar MAP sensors
  2. #162
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    I don't know what that is but that's not something from our team.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
  3. #163
    Jun 09 2021
    Houston , texas
    I have this turbo upgrade and there most definitely is more lag but when the power hits it hits hard! And it’s a lot quieter too no loud swoosh like before which I liked the louder swoosh
  4. #164
    Junior Member Two Rings
    Jul 20 2012
    London
    Quote Originally Posted by macspring View Post
    Hi, can I ask what the DV ‘fix’ you mentioned.
    I’m not on Facebook. 🫣
    Thanks.
    ( Great thread by the way )
    I believe it's this which involves an additional in-line check valve integrated into the factory PCV breather system: https://www.instagram.com/logicstper...p/C2lj02lATgg/
  5. #165
    Jan 28 2022
    Seattle area
    So I've had APR stage 3 installed for a few months and ~10,000 miles now. As I've mentioned before, power is monster but I've always had prominent hesitation, which feels like a timing or fueling problem. Thing is it's only present at ~5,000+ RPM in 1st and 2nd gear near or at WOT and most severe (and quite severe at that - like a hard fuel cutoff) at the 1-2 and 2-3 shifts. Thing is it never happens in the other gears/shifts. And even then, it's fairly intermittent. It seems to be the most prominent if it's been a number of days without WOT shifting. I have zero CELs or DTCs. I've contacted APR multiple times but they have no advice (since there are no CELs/DTCs) other than a guess that it's actually traction control kicking (however, even when I fully disable stability/traction control (to the extent that that does so) the issue is still present). I was APR stage 1 for ~40,000 miles prior. with no such issue. About a month ago when changing my plugs I discovered a loose plug (not even fully seated in threads - there was actually blowby on the plug) but alas, new plugs didn't solve the problem (the old plugs looked great). Anyone else having this issue?
    • 2021 SQ5 Prestige
    • 83,000 miles
    • APR Stage 3 91 octane
    • APR TCU stage 3
    • APR intercooler and piping
    • IE intake
    • Stock fuel pump (only such 91 octane tune available)
    • Stock plugs (which APR recommends)
    • Stock everything else (coils, etc.).
    2021 Audi SQ5 Prestige SSP w/Sport Exhaust and APR Stage 3 (91 octane) - 0-60 in 3.5 s and 1/4 mile in 11.6 s @ 117 mph
  6. #166
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^ You are going to have to run some logs showing boost, fueling etc.
  7. #167
    Jan 28 2022
    Seattle area
    Quote Originally Posted by A4 Centaur View Post
    I asked APR for advisement but they had none. They said if it was fueling or timing problems to that extent you'd have all sorts of CELs/DTCs. Is that not the case IYE - can there be fueling/timing problems that cause drivability issues without CELs/DTCs? It's also very odd IMO that it's NEVER happened in gears 3+ or shifts 3-4+ (and I try A LOT!).
    I'm well versed with logging via OBDeleven but there's so much there I'm not sure where to begin and even what to do with it. APR has a logging guide (https://www.goapr.com/support/vcds_logging/) but there's no advisement on interpretation.
  8. #168
    Jul 20 2012
    London
    Quote Originally Posted by GoCougs1234 View Post
    This is a little disheartening to hear having just purchased the APR DTR8868 for my '17 S4 Avant. I wonder if it could it be a gearbox issue?
    I believe there is quite a powerful free logging tool out there called DBF1 which may be able to help you log (https://www.youtube.com/@DEADBEEFFlash/videos), although I have not tried this tool myself yet as I'm still waiting on the OBDII <> Ethernet connector to arrive.
  9. #169
    Jan 28 2022
    Seattle area
    Quote Originally Posted by Akis View Post
    Don't see how it could ever be a gearbox issue. This 100% feels like a fueling issue. However, my strong hunch is that the fault lies in my particular vehicle and not the APR stage 3 HW/tune.
    Logging is all fine and good but without the interpretation and esp. absent either CELs or DTCs I'm not sure where to start.
    I did more research. This Audi owner sounds like he had the same issue (albeit with a B8 S4): https://www.youtube.com/watch?v=qIbGEbod8Bs. Turns out his battery was weak (but still strong enough to both start and run the car) and couldn't fully push the fuel pumps - fixed by a new battery. I just measured my battery and at 12.3-12.35 V (resting over night) = under 50% health (3.5 years and 83,000 miles) so it's definitely weak - but weak enough? I'm skeptical but I just put on a charger and will then do some 'roddin' to see if that fixes the issue. Even if it doesn't, time for a new battery.
  10. #170
    Jul 20 2012
    London
    Gotcha. Fingers crossed for you. Keep us posted!
  11. #171
    Aug 23 2008
    Auburn, AL
    GoCougs1234, Could you send our support guys a video? Maybe it's hitting the rev limiter.
  12. #172
    Jan 28 2022
    Seattle area
    Quote Originally Posted by Arin@APR View Post
    Here are some videos (I also just sent to Andrew). All instances happen well under the (new 7,200 RPM) red line.
    I sent APR this a while back:
    This shows moderate hesitation on the 1/2 shift when in AMAX: https://www.youtube.com/watch?v=0ghg...ALNinethousand
    New videos from today:
    This shows minor hesitation on 1/2 shift and major hesitation leading up to 2/3 shift when WOT in M mode: https://www.youtube.com/watch?v=BWBg...ALNinethousand
    This shows the same plus what sounds like a backfire (alarming in person TBH) near the top of 2nd gear followed by a short shift (by the ECU/TCU, not me) when WOT in M mode - also note traction control light on the 2/3 shift (I've never heard of traction control causing what sounds like a backfire though): https://www.youtube.com/watch?v=uBx8...ALNinethousand
  13. #173
    Aug 23 2008
    Auburn, AL
    I spoke to Andrew. You're in good hands! We'll get it narrowed down and figured out.
  14. #174
    Apr 29 2022
    Middletown DE
    The APR Stage 3 DTR8868 Turbocharger System is Here
    Arin mine is doing this identical thing. I called yesterday and spoke with Blake. He put me on hold and came back on and said get a video because we’ve never heard of this happening. Maybe it hadn’t made it around the room yet haha. Mine is a 21 as well.
  15. #175
    Apr 29 2022
    Middletown DE
    Here 3 videos I took. I suck at taking the video but my downpipe certainly allows the cuts to be more noticeable. The one video it cuts so hard I fly forward.
    https://youtube.com/shorts/ts5IU1YcG...Yv3RPUTjeVLL9k
    https://youtu.be/rx32shladFc?si=utGbnzuiElISBlNE
    https://youtu.be/v3QPO3wInyc?si=bPzK5otkH7emBdG2
  16. #176
    Apr 07 2011
    Home of the mighty beaver
    Sounds like a hole in the programming somewhere. Or it could be a shared issue. Im on a 2019 S4 setup and dont have these issues (other than an n75 that was bad). One thing i might try, if you are on the 91 tune, is to fill the tank with a higher octane. Or use some booster like Boostane... Its possible your 91 is more like 89 or worse.
    It would not be the first time local gas stations were selling sketchy fuel.
  17. #177
    Apr 29 2022
    Middletown DE
    Quote Originally Posted by S4James View Post
    Yeah I agree it’s something in the programming somewhere. It depends on the car they used to create the software I’m guessing it was not a 21. So many box codes over the years these things are bound to happen. I have a few things I’d like to test but I’ll wait for word back from APR before diving into the diag. Last night made me kinda nervous about driving. If I needed to pull out into traffic in a hurry this thing cuts out I’m screwed. Luckily I don’t daily drive my SQ5.
  18. #178
    Aug 23 2008
    Auburn, AL
    Sounds like the same thing as the other guy. Team is now aware. We'll get to the bottom of it!
  19. #179
    Oct 23 2023
    Illinois
    Quote Originally Posted by Branman1 View Post
    I also had the exact same issue while running on the e85 tune. The first tank was great. No issues. Dyno was 551 to the wheels. Pulled like a train. Filled up new tank got hard cuts def felt like fuel cuts and backfires with hesitation on the shift almost rev limiter style shift. Normal driving it was fine. WoT and above 5500 is where it occurred. I tried multiple gas stations and tanks no change. I did not have a e85 gauge so I figured I’d flash back to 93 fuel pump tune until I got one. The issue disappeared and there is no cut or hesitation on the 93 tune. I figured it was a fueling thing as well. Interested to hear what it is. Wasn’t going to go back to e85 until I installed the fuel it gauge. Was thinking I could blend down closer to e60 if it was a fueling issue. I’d like to run e85 all the time. The power difference is night and day between the two.
  20. #180
    Apr 29 2022
    Middletown DE
    Yeah I believe so. I watched his videos and it’s quite similar. I appreciate you guys!
  21. #181
    Apr 29 2022
    Middletown DE
    Quote Originally Posted by SQ5onFIRE View Post
    Interesting and you have a 21 as well! I was actually going to try e85 but I’ll hold off. I found a pump about 25 mins from me so I thought about giving it a shot one day just to see the difference. Sounds like all 3 of us with 21MY so far have very similar issues.
  22. #182
    Jan 28 2022
    Seattle area
    Yep - sound comes through way better with an aftermarket DP!
    My issue appears identical, esp. that sometimes it is rather violent. Sometimes I get it at the top of first and the 1/2 shift too, but it seems second and the 2/3 shift is usually worse. Then again, I'd say half the time everything works great.
    I'm confident it will get solved soon.
  23. #183
    Apr 29 2022
    Middletown DE
    They contacted me and we are going to attempt to do some remote live logging tomorrow morning and hopefully get a better idea on what’s happening.
  24. #184
    Apr 29 2022
    Middletown DE
    Update: Logs are complete! APR is on top of it!
  25. #185
    Apr 29 2022
    Middletown DE
    Update: Ran a few more logs with APR and sounds like they have figured out the issue and working to correct and offer an updated file. Andrew and the crew at APR have been working on this for the last 6 hours. I’ve said it plenty of times. It’s not about the issue that comes up because shit happens. It’s about how companies handle these issues. [mention]ArinAPR [/mention] you got a great group! I’ll keep updating this but I’m sure those that are affected will be contacted with updates as well.
  26. #186
    Jul 20 2012
    London
    This is really promising news, fingers crossed for all those affected. Good job APR!
  27. #187
    Apr 29 2022
    Middletown DE
    The APR Stage 3 DTR6 Turbocharger System is Here
    Update is live! The file version is 1.3.1
    I’m going to load mine in a bit. Incredible job by APR to crank out an update this fast.
    Not sure if this is needed for those that did not experience any issues but I’m sure the update can’t hurt especially if you have an ultralink!
  28. #188
    Jan 28 2022
    Seattle area
    I just downloaded the fix (1.3.1) and it worked charm after MUCH testing - no hesitation or anything. APR says they got a vehicle in that had the issue (yours?) and went to town on it to solve it.
    And just as I suspected, it wasn't APR (per se) but the vehicles. The issue was apparently only with vehicles with aftermarket intakes. APR calibrated the tune to the stock intake since APR doesn't have an intake yet for the B9/9.5 SQ5. Turns out the aftermarket intakes what with less restriction were allowing the turbo to spool quicker than planned for at WOT, resulting in overboost protection in the shorter (quickest accelerating) gears. I asked APR just before I had stage 3 installed if an aftermarket intake was kosher and fair enough APR did tell me the tune was calibrated only to the factory intake.
    Great work by APR to get on it so quickly especially that strictly speaking it wasn't their fault. Very satisfied overall.
  29. #189
    Jul 20 2012
    London
    Really great to see this and it has painted APR in a very good light IMO. So, it sounds like the built in safety parameters were kicking in on the original tune when certain expected values were out-of-range?
    This is definitely confidence inspiring and I'm really looking forward to fitting mine when it arrives!
  30. #190
    Apr 07 2011
    and inadvertently proved the stock intake was a big restriction too.
  31. #191
    Oct 23 2023
    Illinois
    This is fantastic thanks time to see if it works on the e85 map.
  32. #192
    Oct 23 2023
    Illinois
    Ok so I just checked and I already have 1.3.1 it’s not a new flash. I checked my history and my first flash when I installed the kit was 1.3.1 so this isn’t new. You can check your history but I’m betting you have always had 1.3.1 like me.
  33. #193
    Jan 28 2022
    Seattle area
    It seems like it's a new rev despite the actual rev number not incrementing - lots of 1/2 and 2/3 WOT shifting today and not a single hiccup.
  34. #194
    Aug 23 2008
    Auburn, AL
    If you checked version history with Ultralink, this is a bug in the reporting. It's pulling the latest available version number in the history report, and not what you actually flashed. We spotted this last week and will be rolling an update to the reporting agent.
  35. #195
    Apr 07 2011
    FYI it also reports the ECU flash as "incomplete" whenever you do ECU then TCU in sequence.
  36. #196
    Aug 23 2008
    Auburn, AL
    Thanks! That update fix is being pushed with the next platform we're releasing.
  37. #197
    Jul 20 2012
    London
    Turbo arrived today, looks very nice
  38. #198
    Jan 11 2020
    Ontario
    [QUOTE=Akis;15108993]Turbo arrived today, looks very nice
    Are you going with an APR tune or perhaps going to explore an independent UK tuner like Unicorn?
  39. #199
    Jul 20 2012
    London
    Quote Originally Posted by TunedB9S4 View Post
    Good question, still looking at options at the moment. The APR tune is definitely a safe bet but Rick at Unicorn certainly knows his stuff. Also been in touch with Logic Street Performance who confirmed they can remote tune with the DBF1
  40. #200
    Oct 21 2024
    Nicosia/Cyprus
    Hey, guys! Could you please confirm if APR stage 3 ECU software will work fine with 034 stage 3 TCU software?
