Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 232
  1. #121
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    Quote Originally Posted by A4 Centaur View Post
    I was comparing these results with the M3/ M4 forums 1/4 mile times as I have to say these numbers are quite impressive.
    For the old gen, right? Since the S58 is in the 9’s on stock turbo..
    You’re better off comparing 60-130 though, since the previous gen is RWD.
  2. #122
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by S4James View Post
    Arin: Any comment on differences between the 93 octane files (pump vs no pump) ?
    More fueling headroom means we can keep power full on longer before reducing output for thermal protection situations.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
  3. #123
    Apr 07 2011
    Home of the mighty beaver
    when does this happen typically in a run? Ive heard this response before, and the support guys on the phone have said the opposite. So what exactly does this mean? will the car dyno higher? 1/4 mile? or is under sustained loads at high RPM where this kicks in?
    Id like to know the specifics.
  4. #124
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Quote Originally Posted by AldermanToffee View Post
    Yea, the F80's https://www.m3post.com/forums/showthread.php?t=630463
    G80's and the S58 engine are a bit faster for sure: https://g80.bimmerpost.com/forums/sh....php?t=1853637
    Wish Audi/Porsche would make an engine as good as the S58. Their response: Ah, aber Sie bekommen unseren herrlichen E839-Motor!
  5. #125
    Oct 23 2023
    Illinois
    If it’s hot out and you’re doing multiple pulls. Your car will slow down without the pump is what he means. Likely why it felt faster to me with the pump. It sustains the same power throughout vs tailoring back power when doing multiple pulls on no pump.
  6. #126
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    Dumping more fuel can be used as a strategy to help reduce timing pull by cooling the air/fuel charge. I'm guessing the APR 'fuel pump' tune is looking for a bit more leeway in terms of injector duty cycle and fuel flow capacity when using such a strategy to get the last bit of boost/horsepower out of the hardware.
  7. #127
    Apr 07 2011
    Quote Originally Posted by Jetta03 View Post
    Yes but i want specifics, scenarios, scale of HP loss. High gear low gear. etc.
  8. #128
    Aug 23 2008
    Auburn, AL
    When our modeled (Sensor verified during development) EGT threshold is crossed from running hard it will richen the air fuel ratio to keep EGT down. When that's no longer an option, it reduces power so the engine doesn't melt down.
    With the HPFP there's more fueling headroom so you can richen the air fuel ratio more, which doesn't sacrifice much power at all.
    If it were my car, I'd probably do it. Simple upgrade for a stage 3 guy.
  9. #129
    Apr 07 2011
    Im starting to see that... Is it expected to cross that threshold often? And under what conditions?
  10. #130
    Aug 23 2008
    Auburn, AL
    Depends. Short bursts, maybe not. But driving hard for a while, like multiple back to back pulls, I would expect it.
  11. #131
    Veteran Member Four Rings oc cc's Avatar
    Oct 14 2011
    OC
    Dying for this to be sold to us in CA.
    Current: 2019 S5 Sportback Quantum Gray
    Previous: 2012 A4 Avant Glacier White
  12. #132
    Apr 07 2011
    Quote Originally Posted by Arin@APR View Post
    So a full on 30-160 run would probably trigger it.. Theoretically, in mexico. Looks like im making a call.
  13. #133
    Nov 20 2021
    United Kingdom
    Arin is helpful… eventually ;)
    But if you’re wanting specifics like this you’re best off going with a custom tune, not an OTS. They typically aren’t going to give you all of the operating conditions of their tunes.
  14. #134
    Aug 23 2008
    Auburn, AL
    Specifics aren't something anyone can do because every scenario and condition will be extremely different. In a lunching scenario the first stages of enrichment will happen before the end of the quarter mile - that's easy to tell. I don't specifically know in every scenario if the secondary reduction would trigger - there are too many variables. But adding the HPFP would limit it from activating early, if at all.
    And let's be real: A 'custom tuner' is not turning this feature on or using it properly in most scenarios. It's not on by default on many platforms and if it is it's tied to a model that's broken (no longer accurate at all) when changing the turbo. It's even broken when changing simple things like turning up power beyond the OEM levels. To turn this protection on or use it properly you also have to drill and tap the engine and turbo with additional sensors to correct all the factory models within the calibration. They are completely wrong when you upgrade the turbocharger, so the ECU, for example, has no idea what the temps may be. We know because we actually measure it, and then correct the modeled information. This process isn't quick either. This isn't happening with a few logs or a couple dyno pulls. This is part of the reason why our tunes take months to make. So on other setups they'll enrich as much as they can (unnecessarily in many cases, if they enrich at all), and let it get, unknowingly, hotter than is safe for the hardware. We let it enrich as much as it can safely support within our specified bounds, such as injection window, and AFR targets, when a specified corrected EGT limit is crossed. If the available fuel enrichment cannot maintain safe EGT levels the airflow output will begin to reduce, only enough to maintain safe EGT levels, and no more. In doing this it protects the engine and other components from damage.
  15. #135
    Apr 07 2011
    likely to trigger by the end of a quarter mile run is specific enough for me. Making that call. Too bad its so expensive in canadabucks. This is why i dont mind "the most power" setup, or the APR premium in this case. My old custom tuned car was worth nothing. I paid 50 grand cash for this one and im not interested in going through three motors like the last time.
  16. #136
    Jan 28 2022
    Seattle area
    FWIW, I had APR stage 3 installed on my 2021 SQ5 last Friday. I went 91 octane as my region only has 92. APR says there is no aftermarket HFPF file for the 91 octane tune so by that I take it that excess EGTs to the extent that can be experienced on the 91 tune can be handled by the factory fuel pump. I've tested o' plenty the last week, with 1-3 minutes between runs and experienced no derating to the extent that can be measured by acceleration times.
  17. #137
    Apr 07 2011
    That would kind of make it impossible for you to switch back and forth between e85 and 91 octane tunes if that was the case no? APR needs to get their messaging straightened up with these various configurations.
  18. #138
    Jan 29 2020
    Silly question, are EGT's measured by the O2 sensors?
  19. #139
    Dec 18 2021
    Their message is whatever fits best at the moment. They told me with their ungraded pump you can only run e85. That fitted the negative when their pump failed with less than 1000 miles in use, and I said I'm running 93.
  20. #140
    Aug 23 2008
    Auburn, AL
    There is no measurement. It's modeled. It's a guess based on known variables. But those variables change with tuning and swapping turbos. You have to install a new sensor, and run through many tests to correct them, which is what we do.
  21. #141
    Aug 23 2008
    Auburn, AL
    The messaging is correct on the website.
    E85: Limited power on stock HPFP. More power with HPFP. Files for stock or APR HPFP.
    Pump fuel: Full power on stock or upgraded HPFP. Headroom for protection increased. Files for stock or APR HPFP.
  22. #142
    Apr 07 2004
    Auburn, AL
    I think what you are asking is this... There are no "flex fuel" files. You are either running 91/93 or E85 (well E60+). No blends. You pump out whatever fuel you are running to put in the one you are changing to and reflash.
    APR, LLC
    (800)680-7921
  23. #143
    Apr 07 2011
    That's how i certainly interpreted it. However when i spoke to your reps on the phone and asked if there was any advantage whatsoever to running the HPFP on 93, the answer was an unequivocable no. I have now learned differently, and ill be upgrading to it.
  24. #144
    Apr 07 2011
    Quote Originally Posted by Tom/APR View Post
    No im not. I just thought the scenario of having the hpfp, and no 91 octane file being available seemed unlikely. If the guy is in a place where 91 is all he can get, but he wants to run the FUN e85 file, he would be SOL if that were true.
  25. #145
    Jun 07 2015
    Madison, WI
    Arin, excellent detailed answer! So much want this turbo but loving my current E85 tune! (And it’s massive low end torque!)
  26. #146
    Jan 11 2020
    Ontario
    94 Octane w/~10% ethanol
    APR DTR8868 turbo
    APR HPFP
    Upgraded Injectors
    Custom Tune on Deadbeef Flash platform by Logic Street Performance
    Just a casual launch. This is *not* the final file revision.
    I wanted an upgrade over my previous TTE710. Given the resale value of the TTE, and that the APR turbo happened to be on sale, upgrading made sense - especially here in Canada where prices on everything car related are crazy. Even if I didn't have a turbo with high resale value, the price on the APR turbo alone makes it a logical choice over the TTE810 let alone in consideration of other factors, like more flow on the hot side. Install was not an issue, and the full kit of parts that comes along with it (including a new DV) makes it a real value IMO.
    Sadly, LPFP needs replacement so will be able to put up a couple of Dragy when I get the LPFP sorted out in the next couple of business days.
    2018 Audi S4 Prestige - Daytona Grey
    Logic Street Performance custom tune via Deadbeef Flash platform | Andy's Big Ass CF Intake | 034 J Hook Rotors | iSweep 2000 pads | Valved Exhaust Titanium straight pipe | CAP Decat 2.0 revision | CTS Turbo Intercooler | APR DTR8868 Turbo + RS Injectors + HiFlow HPFP + LPFP | Osman BicepBrah Ali PCV fix | OEM 4-bar MAP sensors
  27. #147
    Apr 07 2011
    Quote Originally Posted by TunedB9S4 View Post
    APR DTR8868 turbo
    APR HPFP
    Upgraded Injectors
    Ill put money on this turbo performing very well.
  28. #148
    May 22 2023
    MD
    wow custom, APR did mention leaving room for such projects since the OTS stays very much in the range of safety
    why is a new diverter valve necessary with the APR b9turbo? was stated that the turbo came with a new DV
    "Additional HPFP software is available for max output on ethanol and increased protection headroom on pump fuel. Lastly, for dedicated race cars the turbocharger is designed with headroom to go even further on your own!"
    https://www.goapr.com/products/engin...parts/T4100001
  29. #149
    Jan 11 2020
    Ontario
    Quote Originally Posted by handspin View Post
    Yes. I called APR before making the purchase and they very kindly confirmed there is room beyond what their tunes achieve.
    The tuner has commented that compared to the TTE810, the APR turbo seems to spool more quickly and run with less back pressure.
  30. #150
    Aug 23 2008
    Auburn, AL
    Awesome results! Glad we could be a part of your build!
  31. #151
    Jan 11 2020
    Ontario
    I feel quite confident (as does the tuner) that there is a 10.7 run yet to be had. Couple of more optimizations but, so far so good.
    94 Octane
    APR DTR8868 turbo
    APR HPFP
    Upgraded Injectors
  32. #152
    May 22 2023
    MD
    Sub 10 E85? Any plans to convert
  33. #153
    Jan 11 2020
    Ontario
    I've got an LPFP on order (good for around 1000HP) to pair up with a similar HPFP (also good for around 1000HP) and then will put in some runs with something spicier than 94
    and, yes, I'll never come close to utilizing them at 100% capacity but I won't be fuel starved, either....Injectors still have plenty of room to play.
  34. #154
    Jan 11 2020
    Ontario
    refinements ongoing with 94 octane pump gas.
  35. #155
    Jan 28 2022
    Seattle area
    Just curious - how are you launching? I have found it exceptionally tricky - far more so than stage APR stage 1. On APR stage 1, with my setup, launching on the upswing at ~3,500 RPM produced the best results and was relatively easy to replicate once I figured out what worked best for my setup.
    I have an SQ5 on the 91 octane tune, and 99% of the time I either launch flat with no boost or launch hot and hit a torque limit and get a 60' time barely better than stock at 1.90 s. I've only ever had two good launches and that was also on the upswing at ~3,500 RPM (and even then, these two launches only matched my stage 1 60 ft at 1.76 s).
  36. #156
    Jan 11 2020
    Ontario
    I can't speak to your tune, but I launch in a fairly straightforward way...
    Rear tires (ExtremeContact DWS06 Plus) at around 35 PSI. Front tires closer to 40 PSI. Traction off. Automatic (or manual).
    The right road (some around me provide grip, others provide more slip)
    And yeah... aiming for 3400 on the upswing in case I overshoot 3500.
    I've got 2nd gear launch, but haven't played around with it enough. It does, however, seem to completely eliminate any wheel spin at launch.
  37. #157
    Apr 07 2011
    Can anyone tell me what the cracking pressure of the wastegate is set to? I want to check mine.
  38. #158
    Jan 11 2020
    Ontario
    I know one of the dragy "slips" is invalid, but, I was connected when I began the run. Sometimes dragy seems to do that. So, in theory, with a custom tune, 93/94 octane, and the APR turbo, you can hit a very respectable 1/4 mile.
    Oh - these runs are with the PCV 'fix' that was posted on FB a few months back. I can now consistently hit the 0-60 and 1/4 miles and 1/8th times with far less variation.
    Can't wait to see what ethanol does for this turbo. Nice job APR.
  39. #159
    Mar 21 2023
    Ireland
    Hi, can I ask what the DV ‘fix’ you mentioned.
    I’m not on Facebook. 🫣
    Thanks.
    ( Great thread by the way )
  40. #160
    May 22 2023
    MD
    stated something about APR sending a new DV with the turbo.. this is the diverter valve?
