Page 3 of 6 FirstFirst 12345 ... LastLast
Results 81 to 120 of 232
  1. #81
    Apr 07 2011
    Home of the mighty beaver
    Quote Originally Posted by Jetta03 View Post
    Anyone have quarter mile times yet on the APR stage 3 kit?
    One guy on FB reported an easy mid to low 10 on E, low 11 on 93. This was on a car with no prep, just street trim.. I think high 10s are in the realm of possible on pump gas.
  2. #82
    Junior Member One Ring
    Dec 08 2019
    Florida Panhandle
    Best out of 4 runs was an 11.39, couldn't keep tires from spinning, on 93 octane.
    Sent from my SM-S918U using Audizine Forum mobile app
  3. #83
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    Gotcha. So this kit offers a couple of tenths improvement in quarter mile times over a similarly fueled stage 2 flash basically.
  4. #84
    Jun 07 2015
    Madison, WI
    Huh? Read the drag racing thread? Saxton pulled a 10.5 @ 130 full weight with stock cat. Did it with a 2000’ DA elevation difference over The 034 car that was running drag radials and 200+ lbs weight reduction too.
    I’d say that’s hella good over a Stage 2 car!
    Looks to be about a full second and 10 mph faster than a similarly equipped stock turbo car (Dimitrys)
    2010 GTI APR Stage 3 K04, VWR springs, UniBrace.
    2013 Golf R APR Stage 2, APR DSG Tune.
    2012 B8 S4 DSG Sport diff. APR Stage 2 V4.0, APR TCU tune, JHM 187 lower pulley, Modded air box, silicone tube, CR-15 (sold).
    2019 S4 APR Stg 1 tune, TCU tune, intake, FMIC, 034 Rear bar, ECS inserts, Koni Special Active Red shocks, 034 shock mounts, Mops 10/12 spacers.
  5. #85
    Jan 28 2022
    Seattle area
    Stage 2? This stage 3 kit on the lowly 91 tune is 150+ hp (ave) over stock 4,000-7,000 RPM which in the S4 is going to easily be 11.0-11.2 with a good launch. Plus of course, it's emissions legal, not stinky and (on 91 at least) requires no other aftermarket fiddly bits (HPFP, HF cat, injectors).
    APR's still working on cracking the encryption on my B9.5 TCU box code and when done, I'm first in line! (Albeit with an SQ5.)
  6. #86
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    Quote Originally Posted by GoCougs1234 View Post
    Right, so a couple of tenths improvement over Stage 2.
    Build Thread: Audi S4 B9 with G35-1050 and Built Engine
    - Custom big turbo G35-1050 (0.83 AR)
    - Fully built shortblock and ported heads
    - Added port injection and direct meth injection
  7. #87
    Jan 28 2022
    Seattle area
    Quote Originally Posted by AldermanToffee View Post
    No.
  8. #88
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
  9. #89
    Jun 07 2015
    Madison, WI
    Come on Arin, the DTR is “only a couple tenths improvement over Stage 2”,,, per some people!
    ROTFLMAO 🤣
    That said, I want to be clear that I take nothing away from AT’s custom build or anyone’s Stage 3 build. Facts are simple, APR chose to build from scratch their own new, not rebuilt turbo, albeit a hair smaller (flowing) than all the other options out there and decided to tune it not as aggressive than all the other kits available out there. Using the factory cat and keeping spikes and peak torque to a respectable (safer?) level is impressive in itself!
    Personally, I’d get this kit tomorrow but I spend 90% of my driving below 2500 rpm and want to see more reviews on daily drive ability before I jump.
    Looking forward to reviews from S4James in his install!
  10. #90
    Apr 07 2011
    looking forward to the install next week. Hopefully it goes well.
  11. #91
    Junior Member Two Rings
    May 22 2022
    VA
    Quote Originally Posted by S4James View Post
    I hope it goes well.
    After the install, will you give your impression of how the turbo lag changes?
  12. #92
    Apr 07 2011
    If you look at the published dyno numbers, it looks like 1000RPM hit. but the HP is like a freight train right up to 7k. This is a very typical result that i have seen for stage 3 turbo cars over the years.
  13. #93
    Jan 29 2020
    I mean a stage 2 93 octane tune with required hardware seems to be running in the 11.6/11.8 range quarter mile from what I've read (please correct me if I'm wrong).
    Someone above reported a best of 11.39 with the apr stage 3 kit.
    Really seems like a few tenths difference overall. Not saying that is good or bad, just looking for an objective report here.
  14. #94
    Jun 07 2015
    Madison, WI
    Understood. Hard dive into the drag racing thread shows average Stage 2 times in the range you said with a mph of 115-119 mph range whereas the only APR Stage 3 car on the list posted a 10.5 @ 130 mph! That’s a good 10 mph faster! Full weight/no slicks. The person above stating he got a best of 11.39 with massive wheel spin only shows bad surface or tires on their runs. Needs lots more info.
    The video Arin linked above clearly shows at least from a dig their system better than a big turbo RS car,,,, I’ll also add that from a 60 (100kph) roll I guessing that big turbo RS would of pulled hard on that APR car!
  15. #95
    Jan 29 2020
    Agreed. Fuel is also key, I'm looking 93oct in particular. If memory serves that single APR stage 3 was E85.
    And there seem to be stg2 flashes running on e85 that are also running 10.9/11's.
    It is awesome to have such a dataset to see how these setups are performing in real life.
  16. #96
    Apr 07 2011
    its difficult to compare like for like when you have factors like tires, weight, prep, conditions, track vs street... not to mention a really small dataset of APR cars reporting results. I dont feel that "a few tenths in the quarter" is a fair conclusion. Also consider that APR has a different approach to their tunes. Stock downpipes, and being 100% street legal.
    Maximizing performance of this car without sacrificing comfort, or attracting the eye of our local emmisions karen squad was my goal here, APR was the obvious choice. The results ive seen so far have been very encouraging. And it doesnt look like they left much power on the table.
  17. #97
    Jan 28 2022
    Seattle area
    I think there's some inexperience at play (not yours).
    11.39 is simply wrong, or in the very least a time of said vehicle not driven and/or set up correctly. On just the 91 tune, the +150 hp average over the meat of the power band = ~11.0 car easily.
    Also, the quicker you go, the bigger the gap difference. 11.0 vs. 11.5 is a WAY bigger gap ("quicker") than 15.0 vs. 15.4 (like at least double the gap) for example.
    I'm on board but APR has yet to crack my TCU (and the TCU tune is needed for this stage 3 kit (much different shift points and higher red line)).
  18. #98
    May 22 2023
    MD
    most emissions legal stage 3
    (some undetermined tenths quicker than a downpipe and tune)
    APR now has their flash tool ready
    feel like they waited until the early birds did their thing, then released the most reasonable tune
  19. #99
  20. #100
    May 08 2024
    Lewiston/Maine/USA
    Love to see the continued innovation of the platform. It's this type of competition that'll keep things going strong. Keep at it!
  21. #101
    Dec 18 2021
    Is that stock tune 330 wheels? Would be somewhat inflated.
  22. #102
    Oct 23 2023
    Illinois
    Yes it is stock. I’m more concerned about the gain when everything is installed vs the number itself. Will be at the same dyno when it’s all on to keep it the same.
  23. #103
    Jan 28 2022
    Seattle area
    Quote Originally Posted by SQ5onFIRE View Post
    Yes - relative HP/TQ measurements are all chassis dynos are good for, and even then the +/- won't be tiny if the vehicle is unstrapped from the dyno between measurements.
  24. #104
    Jan 28 2022
    Seattle area
  25. #105
    Oct 23 2023
    Illinois
    I have my draggy runs posted for 93 octane with fuel pump on this link. This forum keeps saying error uploading photos. When it lets me I will post here as well but if anyone wants to take a peek.
    https://www.audiworld.com/forums/q5-...build-3070901/
  26. #106
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    it’s an old school bbs board you don’t upload photos to it you link them with bbs code smh
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  27. #107
    Oct 23 2023
    Illinois
    Yea well Audi world is soo much easier I have no idea what you even said
  28. #108
    Jan 28 2022
    Seattle area
    Quote Originally Posted by Gunnarrrrr View Post
    Which is an old school "bbs forum" - this site nor AudiWorld? (TBH, kinda surprising as neither appear to be.)
  29. #109
    Mar 25 2015
    Placer County
    well they function no better than one.
    as for pictures on this site, gonna have to take that up with Mr. mod on paying for more storage to host pics here that are beyond potato quality (keep dreaming it’s not gonna happen)
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  30. #110
    Oct 23 2023
    Illinois
    2021 sq5 stock rims stock all seasons on the 93 octane tune. 1100 da with 2 car seats in the back and stuff in my trunk.
  31. #111
    Apr 07 2011
    APR told me directly that the fuel pump does nothing for the 93 octane tune. Yet you mentioned that there was a difference. Can you explain a little further?
  32. #112
    Oct 23 2023
    Illinois
    Honestly it was a butt dyno thing. It felt quicker to me. I have no actual data to back that up. I did not do draggy runs without the pump.
  33. #113
    Oct 23 2023
    Illinois
    Switched over to e85 and did a dyno run. Very happy with the results being it was 80 degrees for the run. Also it shows it is right in line with Apr claims to the wheels on e85. Within 20 wheel from their dyno and my curve looks the same. Easily dyno to dyno variance and weather. Good work APR!
  34. #114
    Apr 07 2011
    may i ask what percentage of ethanol you need to run? APR doesnt seem to have much posted on that.
  35. #115
    Oct 23 2023
    Illinois
    Any amount from e60 to e85 basically pump e85 should I say should, technically fall in that range. By me it always is. You shouldn’t have to mix anything pretty easy. Pump and go. Sometimes you can get less or more but it’s rare. That’s why a fuel it gauge helps really for piece of mind only.
  36. #116
    Aug 23 2008
    Auburn, AL
    Nice gains!
  37. #117
    Apr 07 2011
    Arin: Any comment on differences between the 93 octane files (pump vs no pump) ?
  38. #118
    Oct 23 2023
    Illinois
    I commented above to your previous post.
  39. #119
    Apr 07 2011
    i should have quoted arin...
  40. #120
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    I was comparing these results with the M3/ M4 forums 1/4 mile times as I have to say these numbers are quite impressive.
