Results 1 to 2 of 2
    Aug 07 2023
    St Paul
    Exclamation 2004 a4 quattro 3.0 camshaft related engine codes.
    recently purchased a 2004 3.0L a4 quattro when the MIL came on. I ran the codes with my VCDS and got the codes listed below. I've been doing a little work on it since I bought it such as replacing fluids, sensors, belts ect. to see if I could figure out what the P1996,8 codes are about. I read on another post that it could be the camshaft seals but that post only went so far. I replaced them this weekend while servicing the timing belt along with a number of other things, as you do, but nothing changed. one thing I did notice while I had the timing covers off was the difference in color between the passenger and driver side banks. the passenger side looked substantially darker and less lubricated than the driver side. other than that the car works great! the only weird noise it makes is the pcv valve, it humms most of the time but I believe the valve just needs to be replaced.
    but anyway, here are the codes.
    19759 - Exhaust Camshaft Position Sensor Bank 2 (G301)
    P3303 - 001 - Open or Short to Plus - Intermittent - MIL ON
    18404 - Friction too High; Intake Cam Adjustment Bank 1
    P1996 - 008 - - Intermittent
    18406 - Friction too High; Intake Cam Adjustment Bank 2
    P1998 - 008 - - Intermittent
    17927 - Camshaft Adjustment; Bank 1
    P1519 - 008 - Malfunction - Intermittent
    17930 - Camshaft Adjustment; Bank 2
    P1522 - 008 - Malfunction - Intermittent
    17831 - Secondary Air Injection System; Bank 1
    P1423 - 002 - Insufficient Flow - MIL ON
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 002 - Signal too High - Intermittent
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 002 - Signal too Low - Intermittent
    at the end of the day I'm curious what could be causing these codes, seems to be mostly cam related. anyone have potential causes, solutions?
    Established Member Two Rings Fahrvergnugen's Avatar
    Dec 01 2017
    '03 Allroad yet to be resurrected, '99 VW Cabrio, '99 BMW 323i, '83 VW Pickup, '84 MB 380SEC
    Olathe, CO
    IIRC, I had some of the same codes. When doing that job, You Have to replace the caps that cover the camshaft bolts. I assume you’ve double checked your timing since replacement?
