Hi Guys. I have a D3 S8 and it has a warning message for the headlights. i can't seem to figure out what is wrong with it. the lights work correctly for lighting. The up and down and side to side do not work. This all started with the pass side headlight going out. Replaced the Xenon bulb fixed the bulb going out but didn't fix the warning message. I have scanned it with vag com and found out it has a 02071 014 fault code in it. This is for local data bus communication error. if its a local data bus issue, to me its something that the headlight range motor communicates directly with locally but cannot see it. I am not sure what its looking for as all the data looks ok. With air suspension on the car are the level sensors on each corner are they shared with the suspension level sensors as well? Also does anyone have a full wiring diagram of the headlights as well?
Thanks for the help, this one has me stumped right now.
