Results 1 to 5 of 5
    Veteran Member Four Rings BoostTed's Avatar
    LA
    034 sway bar question
    Do i need to get the adjustable sway bar links in order to adjust the stiffness?
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    No-not at all...You'll notice that there are (2) holes in the bar end.
    You place the bar link in the hole closest to the front (makes a shorter lever arm) for the stiffer setting....
    FWIW- if you're looking to upgrade the bar links these (Meyle) lnks are REAL good
    https://www.fcpeuro.com/Audi-parts/S...b=5&d=365&v=31
    They're a copy of the RS2 links by a good OEM supplier
    I've had these on my lowered S4, with a 19mm rear bar, since 2005--NO issues
    Apr 08 2013
    Connecticut
    Here-from my build thread back in 2020
    Sent from my SM-A146U using Tapatalk
    Mar 24 2016
    01 Noggy S4 09 VW CC AWD 3.6L
    westchester ny
    wow that is clean
    LA
    Cool, I'll get the meyle ones.
