    Aug 08 2023
    Washington, USA
    Engine Code P0366 Help
    I recently got the engine code P0366 on my ‘13 S7, which is the “Camshaft Position Sensor 'B"
    Circuit Range/Performance Bank 1” code.
    I have absolutely no idea where to start with this. Does anyone know where this sensor is on this particular platform and how to troubleshoot this code? I haven’t been able to find anything online regarding it on this platform.
    Thanks for any help you guys can offer
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by JJcream View Post
    Check AZ thread "Fault code p034500. camshaft position sensor circuit bank 2". I think the information is essentially the same for your similar fault code.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 08 2023
    Washington, USA
    Not inherently much info in that thread. I’m just trying to find out where the sensor is located.
    Aug 08 2023
    Washington, USA
    Quote Originally Posted by Alabama View Post
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Looks like it's Repair Group #28 "Ignition System" in the Repair Manual "8-Cylinder Direct Injection 4.0L 4V TFSI Fuel Injection and Ignition System". Repair manuals may be obtained from the Audi website ErWin, or I believe a Telegram channel operated by some AZ members. AZ member THCarpenter wrote in another thread "check the C7 chatterbox for the Telegram group we have the manuals in there."
