Looking for help--
I pulled the driver's side CV axle and replaced both boots. I did this to retain the OEM axle. The issue I have is threading the axle back into the hub. I have tried multiple angles during install. I am looking for help on how to reinstall this axle. Any tricks or approaches that have been learned over the years. I searched the forum with little on this topic, only the removal is outlined.
Currently, I have tried with the wheel turned all the way to the right with the suspension jacked up on the ball joint (this is how I removed the axle). It seemed almost impossible to reinstall this way as the CV joint was stressed significantly with little luck and the rear CV pushed all the way up into the driver's side turbo area.
I cannot release the pinch bolt as it is frozen via rust to the arm.
Any help or direction is appreciated, I have been trying to line this axle up for a few hours on and off over the last two days.
