Results 1 to 40 of 60
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    Clearing out extra B5 S4 & RS4 parts
    Compiling a few items I've got spare from my builds together into one "for sale" ad here. I'll keep this updated with what's currently available and will add and remove items as I get more ready or sell some. Located just outside Denver, CO and willing to ship anything listed unless noted otherwise. Everything is available for pickup locally. Unless it says "shipped" next to the price, I'll need to get a shipping quote and shipping will be covered by buyer. Feel free to make an offer on any item, worst I can say is no!
    -B5 S4/RS4 Brand new unopened 034 Motorsport 85mm aluminum Hitachi MFA housing - $125 shipped
    -B5 RS4 Brand new unopened 034 Motorsport aluminum MAF adapter to fit their 85mm MAF housing to RS4 airbox. Would work perfectly with the MAF housing listed above. - $75 shipped
    -B5 RS4 oem dual mass flywheel part 078105266S. Came off my AZR engine with 104k miles on it. - $125 plus shipping
    -17Z Brembo brake calipers. I don't recommend rebuilding with new seals. These don't appear to need it. Porsche doesn't sell a kit themselves for these brakes so only aftermarket kits are available for new seals and dust boots. Those change where the piston engages and you end up with the mushy pedal feel a lot of the 17z, 18z, 19z brakes have after rebuild. -$165 plus shipping
    -B5 RS4/4.2L V8 Bosch MAF. This is brand new from fcpeuro. Outside my return window, never used, only mocked up once to check fitment. It's the Bosch OE part they make for Audi, not the Audi part directly, so a bit cheaper. -$100 shipped
    -B5 S4 Avant rear bumpers x2. Both have complete crash bars inside. PM for more pics.
    First one was santorin blue. Has been sanded to prep for paint, but I changed my build to widebody before I got a chance to spray this (also why it's separated). Great condition main bumper cover & lower valence. - $200 picked up
    Second one is silver and in crap condition. Can be salvaged with some work. Lower valence has the main damage with the center area bent up where something was hit. - FREE picked up
    -B5 S4 Avant passenger/right tail light. Good shape, I polished it to get light scratches out. One very small crack can be seen in 2nd pic. - $65
    -B5 S4/RS4 N75 valve. Genuine Audi part opened and plugged in once for test. Otherwise new part - $90 shipped (will add picture)
    -B5 S4 OEM Intercoolers and air shrouds - $75 for all of it or I can split the shrouds from intercoolers
    -B5 S4 door sills - $110 - Would prefer pickup since these are long, but can chat about shipping if needed
    -B5 S4 oem rear brake calipers and carrier brackets. - FREE (pay shipping)
    -B5 S4 APB 2.7T engine crankshaft in great shape. If interested hit me up and I'll unwrap it to get you pics - $60 OBO
    Sold items removed:
    -RS4 K04 turbos
    -B5 RS4 OEM intercooler pair plus original hoses
    -034 Motorsport 3" downpipes w/ RS6 turbo flange
    -RS4 heat exchanger/oil cooler
    -RS4 inlets
    -RS4 fuel rail
    -RS4 OEM Bipipes
    -EV14 550cc injectors
    -Spare ECU
    -034 MS silicone breather hose kit
    -Brand new genuine Audi N75 valve
    -Apikol rear 300mm brake bracket kit
    -Mamba k03/k04 wastegate actuators
    -RS4 original fuel injectors
    Veteran Member Four Rings vailshred's Avatar
    Aug 20 2011
    Arizona/Colorado
    Pm’d
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Do these intercoolers utilize the same intercooler hoses on the b5 s4?
    Apr 17 2019
    Quote Originally Posted by bmwpower603 View Post
    Nope. I think the inlet and outlet sizes on rs4 intercoolers are 1/4" bigger than the s4. They're 2.25" ID. so would either require these oem rs4 hoses or some places sell aftermarket silicone versions (THE-Tuner would be one).
    As a side note, if anyone wants just the intercoolers, then vailshred was interested in just hoses. I won't split them unless there's a buyer for each.
    **Edit**
    Just read your question again and maybe misunderstood it on first read. If you are asking if the rs4 intercoolers can be used on an s4 with these same rs4 hoses I have for sale, then yes (mostly). These hoses will fit up to all but the s4 bipipes. You'd need rs4 bipipes or other of that same size, or you can get a hose that reduces down 1/4" for the intercooler outlet to s4 bipipes.
    Sent from my SM-F731U1 using Audizine Forum mobile app
    Apr 17 2019
    Adding another item for sale. Will edit and add pic on the original post once I can get on my laptop later.
    -034 Motosport 3" downpipes with rs6 turbo flanges - $400 OBO
    In great shape, don't think these have been made in a while now.
    Apr 17 2019
    Updated ad finally and added b5 rs4 oil cooler
    Apr 17 2019
    Bump... more items added and rs4 fuel rail price change
    Apr 17 2019
    K04 original RS4 turbos added. Perfect for someone looking to drop new CHRAs in. Price drops on most items listed as well
    Active Member One Ring OneLoveTwoWheel's Avatar
    Jul 24 2014
    14' 370z 17' RSV4 RF
    United States
    Are the door sills new or are they used?
    Apr 17 2019
    Quote Originally Posted by OneLoveTwoWheel View Post
    Used. They're in good shape, not peeling or anything. Got them from audis4parts a couple years back for my own project, but did an rs4 build instead so never used them.
    Junior Member One Ring
    Nov 12 2020
    Valrico, FL
    Will those RS6 flanged down pipes work with SRM RS4+ hybrid turbos? I’m new to the B5 platform so I’m not sure if they’ll bolt up
    Apr 17 2019
    Quote Originally Posted by Kingman34 View Post
    I would be lead to believe those use the rs4 k04 hot side, but their site doesn't say for sure and they don't have pics of the exhaust side. The hybrids always confuse me. You might reach out to srm to verify, but my guess would be those turbos will not fit up to these downpipes. I was planning to have new rs4 k04 flanges welded onto these downpipes, but decided on a whole new set in the end. That's always an option to have an exhaust shop do.
    Apr 17 2019
    K04 turbos ***SOLD***
    Apr 17 2019
    B5 RS4 intercoolers and hoses ***SOLD***
    034 Motorsport 3" downpipes w/ RS6 flanges ***SOLD***
    Ad has been updated. Probably last call on the rs4 oil cooler/ heat exchanger. Going to stash it away soon.
    Apr 17 2019
    Bump. RS4 heat exchanger SOLD.
    Lower only RS4 inlets added. Sorry no uppers with that set. Been trying to get them sent from Steve in the UK since early May when they were missing from my rs4 engine and I give up. You can use stock/k03 uppers though if needed with these.
    Apr 17 2019
    Bump. If you have any interest in the catback exhaust at all let me know. I'll probably accept about any offer on it. Need to clear the space. Had a nice sound, not loud the little I heard of it before pulling it.
    Apr 17 2019
    Updated. Got the full set of rs4 inlets finally so it's a complete set of uppers and lowers now. Also added stock s4 intercoolers and air shrouds.
    Apr 19 2011
    Pm sent
    B5-Built motor full stage3+ RS6 ASP car, full OEM RS4 widebody
    B7 S4
    Apr 17 2019
    RS4 inlets sold. Anything still up in the ad is still available
    May 19 2023
    FL
    any idea if that exhaust fits a 2.8 a4 avant?
    Apr 17 2019
    Quote Originally Posted by Dynamiik1 View Post
    Avant part shouldn't matter. Based on this thread it seems like it should fit, though it's not something I've ever tried and could personally guarantee for ya. Sounds like all the mounts and such would be in the same places to fit.
    https://www.audiworld.com/forums/a4-...-right-285987/
    Apr 17 2019
    Bump, everything listed is still available. Make an offer if you want! Still got brand new Bosch ev14 injectors here and a good shape catback exhaust I'd damn near give away to anyone who wants it.
    Only item that likely won't be available going forward is the rs4 fuel rail since I'm trading it for something else I need this weekend.
    Apr 17 2019
    BUMP. Bringing this one back from the dead. Updated to reflect what I still have available now and added a couple of brand new parts I've never used. Mamba wastegate actuators and genuine Audi n75 valve.
    Apr 17 2019
    Bump. More parts added. Factory RS4 bipipe set that's been refinished. See original post for pics and prices.
    Sent from my SM-F741U1 using Audizine Forum mobile app
    Apr 17 2019
    RS4 bipipes SOLD
    Updated ad prices
    Found a 2nd new N75 valve I no longer need. This one is not in original packaging. Think I had plugged it in once possibly when troubleshooting one of my cars and the issue wasn't the n75. Apparently I kept buying these thinking I didn't have one Best offer on the opened one. I think they're like $175 new these days.
    Apr 17 2019
    Prices dropped further. Motivated to be rid of some of this so make an offer if interested.
    Will also post used 034 Motosport silicone spider hose this weekend once I pull it from one of my s4s. Will need to check going rates on those but it's complete with all the hoses (late style) and check valve.
    Veteran Member Three Rings CLAY's Avatar
    Dec 14 2013
    02 s4 avant, 02 s4 sedan, 03 s6 (rs swap) avant, 13' bmw F30
    Sacramento, CA
    Is the exhaust still for sale? I'd be interested in having it shipped if so.
    Sent from my SM-S926U using Audizine Forum mobile app
    Apr 17 2019
    Quote Originally Posted by CLAY View Post
    At the moment I still have it. Just got 2 other messages with interest in it today after no interest for about a year. Weird how that happens, but I'll keep posted if it's gone or still for sale here.
    Junior Member Two Rings
    Oct 16 2008
    new jersey
    Exhaust still available??
    Apr 17 2019
    Quote Originally Posted by sunshine4 View Post
    2 people interested in front of you currently. If they back out I'll let you know and get you the shipping quote you messaged me about. Thanks!
    Dec 14 2013
    Sacramento, CA
    Quote Originally Posted by belms4 View Post
    Sounds good, man. I'm interested in it. Let me know.
    Apr 17 2019
    Hey, you're next up in line, but shipping this thing is not looking reasonable at all. Unfortunately the largest piece separated is still 53". So everything needs a box roughly 55x8x33 and 45 lbs. Which from Colorado to Washington state for the other guy interested I can't find a carrier for under $400. I don't have a commercial account or anything either. I may just need to make this thing local pickup only, but let me know if you still have interest.
    I'd honestly give it away, but it's definitely not worth $400+ in just shipping in my opinion.
    Apr 17 2019
    Added new 034 motorsport Hitachi maf housing to listing. See original post for current items available.
    Anyone after the catback exhaust - it's likely local pickup only now unless you can provide a cheap carrier.
    Dec 14 2013
    Sacramento, CA
    That's deffinetly a bummer on the shipping. If I can figure out a cheaper way to ship it, I'll pm you.
    Apr 17 2019
    Ad updated. Added 034 Motorsport silicone breather hose kit. Removed exhaust.
    May 09 2012
    Virginia
    Still have the 550 injectors?
    Apr 17 2019
    Quote Originally Posted by jbain2 View Post
    I should somewhere. Let me find them first and get back to you. Been a while since anyone's asked about them, so I think they're packed away.
    Apr 17 2019
    So sorry, I tore apart the house looking for them only to find I sold them back in January with other parts. So I no longer have those and will update the ad. I do still have everything else listed, including the rs4 injectors, which flow 480cc at 60psi/4bar.
    May 09 2012
    Virginia
    No worries. Thanks.
    Apr 17 2019
    Added a couple more items. Spare ECU and Avant tail lamp.
    Will probably be adding more as I sort through spare parts here. Got all sorts of spare factory 2.7t engine parts from multiple builds. Not going to individually list the parts out, but I've got multiple tubs full if anyone is after original replacement engine parts (piping, covers, sensors, fuel rails, injectors, hoses, etc).
