I have a stock A4 B7 2.0T, the engine just switched off while driving and does not start any more. I towed the car home, opened the cam belt inspection window. The cam belt is intact. When I try to start the the car, the engine turns slowly but does not start. There is no check engine light. I have a full Vagcom and here are the errors when I scanned it immediately after this happened:
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected.
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 35
Reset counter: 255
Mileage: 310966 km
Time Indication: 0
Freeze Frame:
RPM: 922 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 87.0 C
Temperature: 49.0 C
Absolute Pres.: 840.0 mbar
Voltage: 13.716 V
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 317355 km
Time Indication: 0
Freeze Frame:
RPM: 3685 /min
Load: 61.9 %
Speed: 55.0 km/h
Temperature: 61.0 C
Temperature: 11.0 C
Absolute Pres.: 850.0 mbar
Voltage: 14.224 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 317581 km
Time Indication: 0
Freeze Frame:
RPM: 859 /min
Load: 63.1 %
Speed: 0.0 km/h
Temperature: 93.0 C
Temperature: 55.0 C
Voltage: 13.335 V
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 318185 km
Time Indication: 0
Freeze Frame:
RPM: 991 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 24.0 C
Temperature: 15.0 C
Voltage: 14.224 V
004688 - Fuel Level too Low
P1250 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 318626 km
Time Indication: 0
Freeze Frame:
RPM: 957 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 93.0 C
Temperature: 41.0 C
Voltage: 13.843 V
000835 - Camshaft Position Sensor (G40)
P0343 - 001 - Signal too High
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 318637 km
Time Indication: 0
Freeze Frame:
RPM: 2592 /min
Load: 9.0 %
Speed: 39.0 km/h
Temperature: 89.0 C
Temperature: 36.0 C
Voltage: 13.843 V
I thought, it might be the in-tank fuel pump but I opened the inlet of the HPFP and when I try to start the car, fuel comes out. I checked all the fuses and there is nothing blown. I opened the ECU compartment and checked the fuses under the ECU - they are fine. I also swapped the 2 relays under the ECU (I believe one of them is for the fuel pump) but no difference. I measured them with multimeter and both show about 55 Ohms.
Next, because of the codes above about the camshaft sensor errors, I bought a new camshaft sensor, replaced it but the issue is still the same.
After that, I bought a new crankshaft position and sensor, even if there was no code for it, replaced that one as well but still no start.
After I cleared the above codes and after multiple starting attempts, there is no any error codes when I scan it again with Vagcom.
The only thing left is maybe a faulty HPFP but I don't have another one to test with and a new one is too expensive just to try. Is there a way to test it and know for sure, if it's faulty? If I open the banjo bolt and crank the engine, is fuel supposed to come out without the car starting?
I'm running out of ideas. Any recommendations of what to test and try next?
