Results 1 to 13 of 13
    Junior Member Two Rings
    Jul 24 2020
    Texas
    2.7t timing tight fit?
    It seems like I have no slack putting my continental belt on, everything is as tight as I can get and I still don’t have enough to get it over the last cam sprocket. Tensioner is not installed and I did not mess with the cam sprockets at all. Anyone else had this problem?
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Not to sound like a smart ass BUT-
    Are you sure you have the correct belt---078 109 119J
    Are you routing it correctly....
    You need to have the cam sprockets loose(can rotate) when assembling the belt well as for the belt pre-tenson---VERY IMPORTANT
    Do yourself a favor and review the following-
    https://www.youtube.com/watch?v=notzLin4dVI
    This is an easy job--take your time and follow the steps in the video--you'll be fine!
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    If you didn't mess with the cam sprockets then you're not doing the right thing.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Just installed mine yesterday and it slipped over quite easily. I had the tensioner and everything installed. I like to route the belt all the way and then on the passenger’s side I just get the edge over the Bank 1 cam sprocket and it’ll slide straight back. I only used my hands.
    Some guys like Justin relieve the tensioner roller and slip it over at that spot while holding the wrench to keep pressure off. JHM has a video that shows them bumping the cams a touch to help align the belt and then bumping them back into TDC position.
    Any pics of what you’re working with?
    Jul 24 2020
    Texas
    Quote Originally Posted by ShelbyM3 View Post
    I wish I had pics, had to put the body pieces back on so I can trailer it to my next apartment in a few weeks
    Yeah it seems like I just don’t have enough slack, I even tried the belt I took off and even that was having the same problem.
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    It shouldn’t be too hard to slip the belt on by hand, I usually do the passenger cam sprocket last. You need to break the cam sprockets loose so you don’t shift the cams once you figure out how to get the belt on and apply tension to it..
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Quote Originally Posted by LJS View Post
    LJS and I just did mine, we followed Justin’s procedure exactly. No issue.
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    If OP didn’t mess with the cam sprockets. He probably isn’t using the tool? And most likely his cam gears aren’t loose.
    May 14 2012
    new jersey
    I've done my timing belt 3 times on my car and I have never loosened the cam sprockets. I used the timing tools, the belt was a little tight getting
    May 14 2012
    new jersey
    On but that is cause I didn't loosen the sprockets (just me being lazy). 2 tines I replace the belt for failing water pump, the other was routine maintenance.
    Aug 30 2015
    Derry NH
    Does your bumper come off during routine maintenance?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I can’t imagine doing a tbelt and not taking the 2 minutes to loosen the cams and do it correctly.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by CELison View Post
    Agreed. If you have the tools no idea why you wouldn’t.
