    Junior Member Two Rings
    Aug 26 2020
    2014 S5 coupe
    Lancaster, PA
    NEW TRANSMISSION
    So I'm looking into a new, rebuild or used tranny. Some transmissions are referenced with these codes:
    Transmission ID:NHS
    NSC
    PWW
    PWZ
    Are these gearbox codes and what do they mean?
    2014 s5: 034 Stage II+ ECU and TCU tunes, 57/179 mm dual pulley upgrade, 034 heat exchanger, 034 high pressure fuel pump, coilovers, Ceika big brake kit, Kohlfaser CF intake, custom 2 1/2" SS exhaust with resonated down pipes and RS5 front/rear bumper conversion.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Yes, those are transmission codes. The 7spd DCT is a DL501 type but depending on internal clutches, software, gearing, etc... they use a specific code. For your car you are looking for a PWW, NSC, or NHS. You don't want a PWZ, that transmission has the wrong final drive ratio, won't match up to your rear diff. Also, if you swap in a different transmission the transmission goes into a protective theft deterrent mode, it won't drive but you can read the TCU. You can either take it (whole car) to a dealer and they can recode it to your VIN or you can swap out the Mechatronics board from your old transmission.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Aug 26 2020
    2014 S5 coupe
    Lancaster, PA
    Thank you
    Aug 26 2020
    2014 S5 coupe
    Lancaster, PA
    How do I find out what the transmission ID code for my car?
    Jul 16 2018
    Atlanta
    You have an MY14 S5 3.0T, so you either have a type 0B4 6-speed manual or a type 0B5 7-speed dual clutch (aka DL501-7Q). As for the specific transmission code, it'll be on your vehicle identification sticker (in the maintenance booklet or also on the sheetmetal of the spare tire well) as well as on the transmission itself. But where on the transmission depends on what transmission you have. And Audi made transmissions don't have a nice plaque with the details mounted in clear view like the ZF transmissions.
