All the lights on the dash come on, but the starter doesn't click or crank. That went on for two weeks. I went back to Maryland, got all of my tools, and returned here a few days ago when I jacked up the car and inspected the starter. Connections look fine. I dropped it back down and it started right up. Again, I didn't actually do anything.
It drove around for a day or so, then it wouldn't start again. No click, no crank, nothing. I'm pretty sure the starter, relay, fuse, etc is all fine. Battery voltage is 12.5V. I scanned the car (posted below) a few minutes ago and one alarm stood out to me: P3052 00 [032] - 50 Short to Plus
I have absolutely no idea where to look in here. I'm pretty familiar with the engine bay since I had the engine out but I really have no idea where or how to look for a possible short. The intermittent nature of this issue makes me think a short might be the culprit, and I really don't think I can get the starter out with the engine in. I forgot to put the starter in when I mounted the engine and I *almost* removed the engine again to get it in because it was such a pain in the ass. With nothing bolted to the engine we were able to jack it up and remove the mount but I'm not sure I could do it now with everything in there.
Any ideas? I am pretty good with electronics but I have the crappiest documentation on this car, and it rarely seems to be correct. Thanks for any help!
Code:
Friday,04,August,2023,21:03:35:27321 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: WAUVFAFR5DA048574 License Plate: Mileage: 160840km-99941mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FR-AU48 (8R0) Scan: 01 02 03 05 06 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F 6C VIN: WAUVFAFR5DA048574 Mileage: 160840km-99941miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 08-Auto HVAC -- Status: Sporadic communication error 1000 09-Cent. Elect. -- Status: Malfunction 1010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb Part No SW: 8K5 907 115 F HW: 8K2 907 115 L Component: 2.0l R4/4V TF H09 0008 Revision: ECH09--- CVN: D7D6EE36 Coding: 5A2A0013242600062000 Shop #: WSC 41578 002 1048576 ASAM Dataset: EV_ECM20TFS0118K5907115F 001009 ROD: EV_ECM20TFS0118K5907115F.rod VCID: 35372243A5C7DD32ECD-8060 VINID: 9D19665915A21544401081471013045769 3 Faults Found: 5456 - Starter Will Not Turn P3054 00 [229] - Jammed or Electrical Malfunction MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 160807 km Date: 2023.07.20 Time: 13:05:25 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 84 °C Intake air temperature: 74 °C Ambient air pressure: 960 mbar Voltage terminal 30: 12.368 V Unlearning counter according OBD: 40 Mean injection time: 0.000 ms Engine operating condition: Idle Engine operating condition-Test_Program_Channel 87: 5 5463 - Starter Control; Returned Message P3052 00 [032] - 50 Short to Plus Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 160807 km Date: 2023.07.20 Time: 13:34:32 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 63 °C Intake air temperature: 61 °C Ambient air pressure: 970 mbar Voltage terminal 30: 12.180 V Unlearning counter according OBD: 35 Mean injection time: 0.000 ms Engine operating condition: Idle Engine operating condition-Test_Program_Channel 87: 5 4106 - Bank 1; System too Rich at Idle P2188 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 159182 km Date: 2023.07.12 Time: 10:48:59 Engine RPM: 867.50 /min Normed load value: 23.1 % Vehicle speed: 8 km/h Coolant temperature: 96 °C Intake air temperature: 48 °C Ambient air pressure: 970 mbar Voltage terminal 30: 13.570 V Unlearning counter according OBD: 40 Mean injection time: 1.823 ms Engine operating condition: Idle Engine operating condition-Test_Program_Channel 87: 5 Brake actuated status-Bits 0-7: 222 Engine torque: 66.8 Nm Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8K0 927 158 T HW: 0BK 927 156 AL Component: 0BK 20TFSIUSA H16 1003 Revision: --H16--- CVN: 17DA5374 Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002020 ROD: EV_TCMAL551211_002_AU48.rod VCID: 47CB588BCF2B5FA28E1-8012 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK Component: ESP8 quattro H09 0100 Revision: -------- Serial number: -------------- Coding: 2D1D18 Shop #: WSC 06325 000 00000 VCID: 04518F87BE1DB4BA2B3-8050 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM Component: BCM2 2.0 H12 0633 Revision: 00002001 Coding: 0D804000000000000000 Shop #: WSC 06325 000 00000 VCID: 015F8693A10FA192005-8054 Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000277736013 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160806 km Time Indication: 0 Date: 2023.07.20 Time: 14:22:16 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 E HW: 8T0 959 760 E Component: MEM-BFS H10 0076 Revision: AA000000 Serial number: 00000046867950 Coding: 08037025002400001000 Shop #: WSC 06325 000 00000 VCID: 45D75283F5A74DB27CD-8010 1 Fault Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:11 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb Part No SW: 8K1 820 043 T HW: 8K1 820 043 T Component: KLIMA 3 ZONEN H04 0123 Revision: C1000000 Serial number: 01201220121261 Coding: 6482208000 Shop #: WSC 06325 000 00000 VCID: 392F2E73895F3952085-806C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ Component: BCM1 1.0 H16 0103 Revision: 09016001 Serial number: 00000528721902 Coding: 26008091863CAFC00000480300003D0D0F1C5288A2090221000008004000010200040030000000 Shop #: WSC 06325 123 12345 VCID: 7AADF17FCCD9F24A41F-802E Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 111212 H15 0080 Serial number: SWF12120110187 Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 20836741 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000712121779 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R4B2T02 Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329 H01 0031 Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329 H01 0031 Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: A9F8CE56000000000001 3 Faults Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:11 00908 - Control Module for Wiper Motor 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:29 01520 - Rain and Light Recognition Sensor (G397) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:29 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 P HW: 8K0 959 655 P Component: AirbagVW-AU10 H45 0610 Serial number: 003KJD917UL. Dataset Number: 8T0909602N 0004 Coding: 303343334830303030304A55304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 4ACD61BFDC39A2CA91F-801E Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A Component: BF-Gewichtss. H02 0060 Serial number: 5810000R120000C0ND Crash sensor for side airbag: driver side: Serial number: 6334MSME755023050 Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME75750C54J Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME4F27224CP Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME4C271450D Crash sensor for front airbag: driver side: Serial number: 63732SME26271946- Crash sensor for front airbag: front passenger side: Serial number: 63832SME29273844$ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q Component: Lenks.Modul H02 0171 Revision: 00000000 Serial number: 20130104000128 Coding: 000036 Shop #: WSC 06325 000 00000 VCID: 4FFB70AB27DB87E2C61-801A Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8T0 920 983 L HW: 8T0 920 983 L Component: KOMBIINSTR. H35 0556 Revision: 00000000 Serial number: UUU354CDD Coding: 83B701000B01D705020000 Shop #: WSC 06325 123 12345 VCID: 47CB588BCFAB5FA28E1-8012 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 P HW: 8R0 907 468 D Component: GW-BEM 5CAN-M H11 0055 Revision: 1Z100027 Serial number: 2741Z12C060288 Coding: 80C303FF00 Shop #: WSC 06325 000 00000 VCID: 4CC167A7D6CDBCFAA33-8018 Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 2307038801 2 Faults Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:08 Freeze Frame: Bin. Bits: 10000 Voltage: 12.40 V Count: 10 Bin. Bits: 00000 Time: 13.10 s 00457 - Central Electronics Control Module / BCM (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 160806 km Time Indication: 0 Date: 2023.07.20 Time: 00:00:01 Freeze Frame: Bin. Bits: 00000 Voltage: 12.50 V Count: 7 Bin. Bits: 00000 Time: 0.90 s ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 E HW: 8T0 959 760 E Component: MEM-FS H10 0076 Revision: AA000000 Serial number: 00000046834003 Coding: 081B7B25002400001000 Shop #: WSC 06325 000 00000 VCID: 45D75283F5A74DB27CD-8010 1 Fault Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:11 ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb Part No SW: 8T0 907 566 B HW: 8T0 907 566 B Component: SWA Master H04 0060 Serial number: 0188717094 Dataset Number: 8T0909535G 0021 Coding: 010211 Shop #: WSC 06324 000 00000 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis_AU21.rod VCID: 3FDB406B97FB1762361-806A Lane change assistance control module 2: Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B Component: SWA Slave H04 0060 Serial number: 0190315466 Coding: 000102 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 P HW: 8T0 959 793 G Component: TSG FA H09 0304 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 06325 000 00000 VCID: 56F585CF1801F62A057-8002 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8K0 909 144 F HW: 8K0 909 144 B Component: RCEPS H37 0507 Revision: 00001000 Serial number: 0026091165 Coding: 100000000001 Shop #: WSC 06324 000 00000 ASAM Dataset: EV_RCEPSAU48X 008014 ROD: EV_RCEPSAU48X_008.rod VCID: 34311F47AEBDC43ADB3-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM Component: BCM2 2.0 H12 0633 Revision: 00002001 Serial number: 0300029758 Coding: 0106069A00FA400583B0003200000000 Shop #: WSC 06324 123 12345 VCID: 015F8693A10FA192005-8054 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000615411 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H04 0220 Serial number: 0123456789ABCDEFGHIJ 2 Faults Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160807 km Time Indication: 0 Date: 2023.07.20 Time: 13:30:11 00457 - Central Electronics Control Module / BCM (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 104 Mileage: 160806 km Time Indication: 0 Date: 2023.07.20 Time: 14:22:16 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H05 0030 Revision: 00005001 Serial number: 94813008927802 VCID: 2D070A234D1795F294D-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 P HW: 8T0 959 792 G Component: TSG BF H09 0304 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 06325 000 00000 VCID: 55F782C30507FD320CD-8000 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 L HW: 8K0 907 801 J Component: EPB-4 H01 0003 Revision: -------- Serial number: 10000000151357 ASAM Dataset: EV_ParkiBrake 001027 ROD: EV_ParkiBrake_AU48.rod VCID: 38292B77B2D5205AF7B-806C 1 Fault Found: 721152 - Brake Pad Replacement Mode Active C1011 00 [000] - - Intermittent - Not Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 082 E HW: 4G0 035 082 Component: Radio U SIRIU H60 0121 Revision: AB001007 Serial number: 156L60C7677901 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 221DE91F04C95A8A39F-8076 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 C HW: 8R1 035 746 B Component: H-BNT-NA H44 0624 Revision: -------- Serial number: 204LW0C7550063 Coding: 130200020006A1EF51028B4E00000403140000000000000000 Shop #: WSC 06325 000 00000 VCID: 372B284BBF4B2F22FE1-8062 Subsystem 1 - Part No: 8R0 060 884 BA Component: NAR 2013 0703 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130L+0C2607688 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Serial number: 00000001364637 Subsystem 4 - Part No: 8R0 060 961 E Component: CD-Database 4949 1 Fault Found: 01524 - Antenna for Telephone 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 7 Fault Frequency: 21 Reset counter: 103 Mileage: 158336 km Time Indication: 0 Date: 2023.06.26 Time: 04:39:36 Freeze Frame: Voltage: 14.30 V ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H07--- Serial number: 525PA8-J2X90RC Coding: 1000008 Shop #: WSC 06318 000 00000 VCID: 38292B77BE55205AF7B-806C No fault code found. End----------(Elapsed Time: 01:48, VBatt start/end: 12.1V/12.1V)-----------
