I've got a super clean 2002 A4 1.8T/Tip with ~198k. I bought it from my aunt and uncle who had it since new. It was in nice shape, but has needed some love in terms of maintenance, so I have been working on getting it up to par. One problem that I haven't been able to fix is the car continues to get oil in the spark plug holes, will puff on startup periodically and have a bit of an oil burn smell while it is running. I never notice anything out the tailpipes unless it's been sitting and started for the first time.
So far, I have replaced the full valve cover and chain tensioner seal kit which uses a Victor Reinz gasket from ECS, replaced the entire PCV system with 034 refresh kit and I'm still getting it. Any other ideas. My only final thought is that there is something worn or wrong with my valve cover that is now allowing things to seal properly. Should I try a new valve cover and gasket? Should I try another gasket in case I messed something up the first time around? It seems unlikely that I would have messed anything up in replacing the basket as it is not hard. Any feedback/advice would be appreciated.
