Results 1 to 15 of 15
    May 31 2011
    moore
    Front control arms replacement
    How do I torque the highlighted nuts when there's barely enough room for a wrench? Also, should I wait to torque when all the arms are replaced or do as I go (torque the top arms then move on to the bottom arms)?20230729_113357~2.jpg
    Sent from my SM-G998U1 using Audizine Forum mobile app
    Senior Member Four Rings
    Jun 08 2021
    PA
    Put a jack under the lower ball joint. Lift the jack until the car just comes off the jack stand. Tighten all bushings under weight including the sway links. These bolts are torque to yield so it will be a certain amount of rotation after the base torque. You should not reuse the bolts. Most arms come with new hardware. If you bought some without you will need to get new ones.
    Jul 16 2018
    Atlanta
    Fasteners involving suspension bushings are torqued "at ride height". You need to jack the wheel bearing housing up until you return the wheel bearing housing to the original wheel well arch to wheel center (or axle bolt center with the wheel off) distance. Do not disrespect that being under or even near the car in this configuration is a high danger situation. That corner of the vehicle is now fully supported on whatever it is you used to jack up the wheel bearing housing.
    As for those specific bolts, I had to use a crow foot on my torque wrench. You can use whatever creative extension you want, double box end wrench with a socket on the torque wrench to fit the box end, etc. Just be sure to recompute the torque spec correctly; longer arm = lower setting, etc. Torque spec is 50Nm + 90°. After you get the 50Nm done, then you can use a normal wrench for the +90°
    Jun 23 2015
    Michigan
    You can try putting the torque wrench on the head of the bolt too. Then counter hold the nut with open ended wrench.
    Mar 31 2008
    eS-4
    CAL*SO
    something like this https://www.amazon.com/ABN-Metric-Do...%2C245&sr=8-18 and this https://www.amazon.com/URREA-1216ML-...s%2C193&sr=8-7
    and this https://www.homedepot.com/p/Husky-20...A-03/316924567
    and like mentioned, use a jack under the knuckle and jack it up all the way until right before it lifts off a jack stand.
    the tq wrench and a standard short 16mm socket should have enough space to fit on the nut side.
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
    May 31 2011
    moore
    I'm trying to remove the heat shield to get access to the front rear lower arm. So far, I found 2 of the 3 bolts. Can anyone tell me where the last one is?IMG_20230729_215728~2.jpg
    Mar 31 2008
    eS-4
    CAL*SO
    Sent you a pm
    May 31 2011
    moore
    I finally got the arms out. What's the easiest way to install the ball joint to the front rear lower arm? It needs to be torque at 110Nm. I'm thinking of buying a vise but I'm not sure the mouth opening is big enough.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Quote Originally Posted by hiwasss View Post
    I torqued it when I bolted that control arm to the car. as for the upper control arms, I replaced those when I had the front struts out, I marked the orientation of the old arms in relation to the shock mount or whatever the large bracket these arms are bolted to is called. I then transferred these marks to the new arms and tightened these after I aligned the markings. What I'd try to do now if I would struggle with access to the upper control arms' nuts is I'd jack the knuckle to the ride height, put the marks and then unbolt the shock "hat" from the strut towers, let the shock sort of lean out of the wheel well and tighten the nuts while the arms are aligned. That's what I'd do if I was struggling to tighten those upper control arm nuts
    Aug 05 2013
    N/A
    Bro you may want to visit FCP’s site and watch one of their videos for the control arms if you’ve not done some before or it’s looking difficult. It’ll answer a lot of your questions and give you a good visual aid.
    May 31 2011
    moore
    I've watched countless videos, and God knows how many times I went over the FCP Euro's video. I'm still not able to get the rear control arm into the sub frame. The passenger side was fine, but I'm not having any luck with the left side. Tried putting in a long screw driver to get the holes aligned. With the bolt partially inserted, moving the arm left, right, in, out, up, down won't get the bolt go through to the other side. It works fine with one of the smaller bolts from the other control arm. I've tried to insert the arm into the sub frame from below, top, and horizontal, each time taking over an hour.
    Sent from my SM-T970 using Audizine Forum mobile app
    Apr 23 2019
    CA
    turn the knuckle so that the bolt holes in the arm and the subframe are on the same vertical axis, then lightly tap the arm in place using rubber mallet. You can help the bolt with rubber mallet, too. that's what I did. also, clean up the corrosion/pitting with scothcbrite or something. another way is to slightly file the metal part of the control arm bush - see some naptowntuner vids.
    May 31 2011
    moore
    Quote Originally Posted by fastboatster View Post
    Thanks, I'll check out naptowntuner's videos. I use a metal wired brush to clean the surfaces before installing the arms. It requires a great deal of force to tap in the arm using a rubber mallet, and they somehow always ended up offset.
    Apr 23 2019
    CA
    you said you can get some smaller diameter bolts in - perhaps try hitting those on their side to move the arm and fine tune with prybar
    May 31 2011
    moore
    Thank you all for the help. I got all the control arms in and torqued. Just need to somehow put the heat shields back in and find all the screws/bolts for the undercarriage for the engine and gearbox.
