Results 1 to 9 of 9
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    BuyBrakes.com ???
    Has anyone ever ordered from these guys? The prices seem too good to be true. I’m skeptical but if anyone has any insight or experience with them I’d like to hear it.
    May 20 2010
    I haven't, but if you think you'll be buying a set and going through it in fairly short order (couple years), then it may be worth it to buy from FCP Euro for their lifetime warranty. Buy a set and be done!
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Junior Member Two Rings Jvyn's Avatar
    Feb 25 2023
    CA
    BuyBrakes.com ???
    Quote Originally Posted by blubusdrvr View Post
    They’re cast iron rotors and they’re heavier by a few pounds. I wouldn’t recommend them. What size rotors are you looking for?
    Dec 05 2006
    So. Cal.
    FCP Euro has changed their return policy. Go read it and make sure it will work for ya. I'm on the west coast and Pelican is a hop skip and jump away so I'll be moving my purchases over there. Staying with FCP for the stuff I already have.
    May 20 2010
    I have, and it still works for me at least. I actually chatted with them when I saw the change. And since OP is in MD, it may make sense.
    Quote Originally Posted by Jvyn View Post
    Most brake discs are cast iron (or steel cast iron). More likely because it's solid, single-piece cast iron disc rather than having a 2-piece, lightweight aluminum hat.
    Mar 02 2015
    I guess I should’ve specified, I was more thinking on the pad side of go fast stoppers than rotors. I use FCP for a lot of things but still haven’t decided I’m ok with sending back consumable parts (brakes, oils, other fluids) like others have. BuyBrakes.com is certainly cheaper than any other outlet, just not sure if you’re getting Chinese knock-offs or if someone could verify they were legit.
    Dec 05 2006
    So. Cal.
    Every part on a car is consumable! Send that s*it back. My Cayenne TT eats through brakes like no tomorrow at a cost of about $1,000 in parts. I'm not into spending $1,000 every 18 months for brakes. FCP will be ok with you sending those parts back so you should too.
    May 20 2010
    Also, while not as extensive as FCP's program (like fluids), ECS has started a lifetime warranty on a lot of parts, including brake pads and discs (will be marked Lifetime Warranty on the right side). Seems to function similarly to FCP.
    Dec 05 2006
    So. Cal.
    Great News!
