Results 1 to 8 of 8
Thread: Boost problems
    Jul 29 2023
    Michigan
    Boost problems
    I’ve got a 2000 Audi a4 1.8t. I’ve got a stage 2 tune I just changed my turbo to a k04 because I had the head off because I was changing it instead of doing valves did the timing. The car runs fine when at like 5 pounds but 6 psi and up the car feels like the turbos surging. As soon as my car builds to 6 psi and up it starts bucking kinda and surging. I’m not sure if I’m running out of fuel Or something else I’m a little lost any ideas?
    Established Member Two Rings rzyao's Avatar
    Jan 05 2020
    Massachusetts
    I'd say start looking for boost leaks, then move onto fueling if you're absolutely sure there are no leaks
    Jul 29 2023
    Michigan
    After getting on it, it throws a misfire code while building boost and after
    Jul 29 2023
    Michigan
    What would you say is the simplest way to test for boost leaks? I’m almost certain there isn’t a boost leak but there could be one
    Jan 05 2020
    Massachusetts
    Quote Originally Posted by Ybr_fr3d View Post
    If you're misfiring, maybe you have a bad coil pack. Try moving it around and seeing if the cylinder that the misfire is detected in follows where you moved the coil to, as the code should say which cylinder is misfiring. That's how I diagnosed a bad coil on my car
    Jan 05 2020
    Massachusetts
    For around $10 you can build one with a cheap soldering iron from harbor freight, an empty pickle jar, and some tubing. I'd suggest looking up a guide to making one, and it could come in handy in the future as well. You should see smoke pouring out of any major leaks that might be hard to find otherwise
    Jul 29 2023
    Michigan
    I’ve got old coil packs in it right now I had a misfire problem now it don’t misfire except certain occasions. When I hammer on it start building boost it send a misfire code. And second when the cars completely cold it starts fine but if you give it too much gas while cold it starts misfiring and usually will stall like it floods over or something. Which is what points me towards fuel
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    You are running into fuel problems with your stage 2 tune. You can downgrade your tune to a stock tune and run your K04 but it won’t run properly with a higher flowing turbo with higher boost. Get a custom tune from Motoza. Sell your stage 2 ECU and that will help pay for a replacement stock ECU and a custom tune.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
