Results 1 to 7 of 7
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    2012 Q5 3.2 reliability
    Looking at a 2012 Q5 with ~135k on it. What issues typically arise with these vehicles at the mileage climbs? I believe the 3.2 engine is supposed to be pretty solid, correct? What should I look out for? Thanks.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    I believe that's the last year that engine was offered so you'd be getting the most refined version available (all the bugs worked out). If well cared for, all recommended maintenance complete to-date, the 3.2 is often a very reliable motor. No pesky boost-induced PCV issues or eventual turbo failures. No timing chain issues. The 3.2 also didn't suffer the terrible oil consumption of the 2.0.
    My 2011 has been a dream so far #knockwood
    Nice power from a relatively small NA motor. Sport mode is well tuned. I never hesitate to pass a slower vehicle on 2 lane Hwy.
    Mar 07 2020
    Minnesota
    IIRC carbon build up and oil leaks are the main boogymen of the 3.2 ... and to a lessor degree timing chain stretch. Not as bad as the 2.0T, but much more difficult to address.
    Feb 02 2018
    CO
    Thanks for the responses. I always ask for maintenance records where available, number of previous owners, how long current owner has had it etc., so I hope to be able to find out about service history. I'll look for signs of oil leaks and listen for timing chain stretch to the extent I can. Will also probably have my mechanic to an inspection on it if the answers I get sound reasonable.
    Appreciate any additional feedback others may have as well!
    Mar 07 2020
    Minnesota
    Quote Originally Posted by 03TLSinCO View Post
    You'll need VCDS (or equivalent) to view how much the cam phasers compensate for chain stretch; from the 2.0 and 3.0 we look for no more than 5 degrees (assuming it's the same with the 3.2?)
    Feb 02 2018
    CO
    Quote Originally Posted by Norskie View Post
    Thanks. I have a VCDS, but this would use my last VIN. Do I need to register the VIN to check that?
    Mar 07 2020
    Minnesota
    I don't know for sure but probably - but you can also rent a vcds for $30 or so.
