Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 169
  1. #121
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    I'm an old school style builder and I always use a bit of green loctite on all engine plugs. You'll prolly be fine though.
    Sent from my SM-N976V using Tapatalk
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
  2. #122
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    Quote Originally Posted by Allowencer View Post
    Makes sense! This is my first true engine build so learning a lot and hoping I don’t make any mistakes I can’t fix! I had a couple of motorcycle projects that were supposed to be “practice” for this but I ended up leap-frogging over completing those and went straight to the “big project”. So far so good - but happy I’m only dealing with 4 cylinders! 6 or 8 could be a bit much…but maybe one day - let’s get through this one first! I’m already looking for 911’s that need motor work! 😂
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
  3. #123
    Aug 06 2019
    Philadelphia
    2002 SV650 - SUZUKI
  4. #124
    Aug 06 2019
    Philadelphia
    Turbo installed! I put the K04 back on for break in and just to be sure all is running well. I still have a few items to finish up on the EFR before it is ready to be installed.
    I owed the crank bolt an additional 95 degrees... I have the "10.9" crank bolt. Tightening spec is 100NM + 180. I needed to wait till I had it back on the stand to complete the 180!
    Placed the starter and connected the lower harness.
    Cleaned and prepped the engine bay - ready for the engine to be dropped in!
    2002 SV650 - SUZUKI
  5. #125
    Jun 12 2013
    Good luck with getting it back in with the front clip all there! You're brave to attempt this lol
    I'm gonna contact you on the EFR
    Sent from my SM-N976V using Audizine Forum mobile app
    Build Thread
  6. #126
    Aug 06 2019
    Philadelphia
    Engine is Out!!! What next? - B8.5 2.0T Engine Upgrade/Rebuild
    Thanks!!! I think the key thing here is jacking up the transmission. With the transmission jacked up in the tunnel, you have the clearance to get the drive plate snout into the bell housing. Another necessary thing is the load leveler - which allows tilting of the engine as needed to get everything lined up. An extra set of hands also made this possible. My son was able to help guide the left side of the engine while I guided the right and controlled the descent.
    Getting the snout of the drive plate to line up with the “pin” on the torque plate took some effort but once both engine mounts were lined up, everything mated up as it was supposed to. Being able to lower and raise the tranny a bit throughout the process also helped. Took about 15 minutes to get it in and ready to be bolted up!
    I do wonder if the process is simplified because I have a ZF8 auto - I believe there may be extra steps with a manual. In any event - I’m over my fear of pulling the engine and could do it quickly and easily in the future! I’ll just need some new bolts!
    4C1263A8-E2B4-47A4-95EA-EF1C7AE916D2.jpegE46139BC-7993-4531-B708-2C1548FCC31E.jpeg5540584F-2FE9-4386-9709-07B79678626B.jpgB5F34361-9941-4F2D-A2C2-E1A77E5C77D3.jpegA15C7AD5-0F4C-4B71-91EE-1ED7C36D5658.jpeg
    2002 SV650 - SUZUKI
  7. #127
    Aug 06 2019
    Philadelphia
    Took the opportunity to do some paintwork. In the past, I scratched up my engine bay removing and installing my turbo. A while ago I ordered some spray paint (touch up direct) to fix a few scratches on my bumper. Never did the bumper repair, so I still have the paint. I decided to test it out. It’s a pretty good match - just raw paint - no clear coat.
    Back to getting this engine back in…. I completed the wiring on the lower harness. Got it all back installed.
    Put the coolant back in! No leaks!!!
    Getting closer!!!
    2002 SV650 - SUZUKI
  8. #128
    Aug 06 2019
    Philadelphia
    Did a boost leak test. Found some leaks in my port meth connections on the intake manifold. I tightened them all up and got everything sealed as best as I could. I also found some leaks in my catch can setup. Handled them with some sealant but eventually I think I will need some catch cans that seal a little better. Will detail that in my catch can thread.
    Got everything connected and finalized.
    Disconnected the injectors (8-pin connector under the manifold) and the coils. Also took out the spark plugs. Cranked her over to get oil pressure. Monitored pressure with my oil pressure gauge. The gauge reads off the oil turbo supply. Not ideal placement but it gives me a reading. I was getting worried as it was taking a while to build pressure but once it did - it was all good!
    2002 SV650 - SUZUKI
  9. #129
    Aug 06 2019
    Philadelphia
    Does anyone know what a ratchet sounds like spinning at 3000rpm??? Unfortunately I do!
    The first start almost ended in disaster. I started the car with a ratchet still on the crank. Rookie move. Can’t believe I did that. I was in the zone. Excited, nervous, ready to start - and I got distracted by some traveling salesmen. Smh. In my excitement to get back to the project, I forgot I had a ratchet on the crank.
    Started the car - she started right up! No hesitation. I locked down the accelerator at just under 3000rpm for the initial start procedure. Car is currently filled with amsoil sae 30 break-in oil. Anyway, I hear this rattling. I’m waiting for it to go away. It doesn’t. I get out and go to the front of the car only to discover my 1/2” ratchet spinning on the crank. I almost sh$t my pants and I ran back to the cabin to shut the car off.
    I don’t know how I escaped disaster here -
    But luckily no damage - At all. Radiator and fan were ok. Engine was ok - belt wasn’t touched - Even the ratchet was ok - wasn’t even warm.
    Composed myself. Checked over everything again -
    And started her up again to finish the initial start procedure. Smooth running, no funny noises. Phew. Took the car out for a spin to load up the rings a bit. Car feels great. No leaks so far. Need to get on the highway to complete the break in procedure. I really want to be aggressive with the break in because - remember - I did NOT do any honing to the cylinders. So we shall see how that goes. Need that boost to help seat the rings. So far so good though - no black smoke on acceleration and I’m not smelling weird exhaust fumes. Car is now a bit louder and has more growl.
    Disaster averted…just lucky I didn’t have a breaker bar on there!
    2002 SV650 - SUZUKI
  10. #130
    Jun 12 2013
    Hahhaha a helicopter ratchet! Laugh about it now bud. Nice work! Break it in properly. I do 25%-75% max RPM runs, 8 in a row. Once at 75%, let engine braking bring you back ton25% and repeat. Great final step in the break in process.
    Build Thread
  11. #131
    Aug 06 2019
    Philadelphia
    Thanks! Definitely- now I can laugh about it! Smh. Feels good though.
    On your 25-75% runs are you gradually applying throttle or are you getting into boost?
    Also looking forward to doing some logging so I can see some data!
    2002 SV650 - SUZUKI
  12. #132
    Jun 12 2013
    Quote Originally Posted by SNice View Post
    Full throttle up to 75%. Engine brake back down to 25% and slam it back to 75%.
    That's after you do varying loads for like 20ish miles, easing into 4k RPMs as you go deeper in the mileage.
    I do this for all builds, unless it's a race style with very specific rings. Always go by the ring manufacture specs.
    Build Thread
  13. #133
    Aug 06 2019
    Philadelphia
    Didn’t make it too far into the “pulls”. On the second one, I popped a charge pipe off. At first I thought it was catastrophic failure but then I looked at my boost gauge and it wouldn’t go above 0. Didn’t have my wrench to secure the hose back on so I had to limp it home. Car is no fun in NA mode without boost!!! Other than that - so far so good.
    2002 SV650 - SUZUKI
  14. #134
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    The drive home after doing my valve springs, it popped the pcv hose off and did that. Shit my whole pants, do not recommend
    Have also left a ratchet on a crank pulley more times than I'd like, great news as long as it's anything but a Honda it'll just freely ratchet if you were in the tightening position
  15. #135
    Jun 12 2013
    Quote Originally Posted by apeck240 View Post
    Hahahhaha I bet!
    Build Thread
  16. #136
    Aug 06 2019
    Philadelphia
    So far so good. Still in the “break-in” period. Car feels like it’s running better than ever. Did some logging today and captured a quick 3rd gear pull. She didn’t skip a beat. No hesitation. Pulled all the way to redline…. Tyler!!!! Might be time to turn it up!!!!!!?????
    2002 SV650 - SUZUKI
  17. #137
    Veteran Member Three Rings Jason11213's Avatar
    Feb 20 2020
    NC
    Is this with the EFR?
  18. #138
    Apr 01 2021
    Quote Originally Posted by Jason11213 View Post
    270gs at gate pressure, it sure looks like it. For sure ain't stock lol
  19. #139
    Aug 06 2019
    Philadelphia
    Nope! That’s the CTS K04 (1070)!
    2002 SV650 - SUZUKI
  20. #140
    Feb 20 2020
    NC
    Nice! Is the EFR ready to go in? Did you get the actuator bracket fab’d?
  21. #141
    Aug 06 2019
    Philadelphia
    Almost there! I have to weld the seam on the bracket (where I bent it) and add a vband connection to the HFC.
    While I had the engine out, I confirmed all connections and fittings so should be good to go on that front. The last piece of the puzzle will be the final intake connections. I will wait until I get it mounted for that. My goal is to be able to keep my current intake and make adjustments to make it fit.
    Still kicking myself for not grabbing one of those “prototype” iconel APR inlet/manifold kits when they were up for grabs!
    2002 SV650 - SUZUKI
  22. #142
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Says almost 2.4 bar boost. Which even if its includes atmosphere, its like 1.5bar(21-22psi). Not bad, i got 250-255g's with same turbo, on my b7.
    Sent from my LM-V600 using Audizine Forum mobile app
  23. #143
    Apr 01 2021
    Quote Originally Posted by Jayz691 View Post
    Yes that's absolute, and yes yours is also not the stock size turbo
  24. #144
    Aug 06 2019
    Philadelphia
    A few more images of third gear pull logs from today.... I turned off autoshift to get some higher revs...
    2002 SV650 - SUZUKI
  25. #145
    Aug 06 2019
    Philadelphia
    Well, it’s been a while since I checked in here…. In this case, no news is good news!
    I got through the brake in period with the brake in oil. I kept it in for about the first 500 miles. No issues and glad I did it. In all honesty, I was really on the fence about using brake in oil and assembly lube on this build. I ended up using both and very glad I did!
    The first few oil changes came out clean - very clean - the break in oil still had a red color - and no metal chunks or foreign objects!
    My only “issues” appear to be slight oil leaks. I get a few drips of oil at the front of the car. I thought I had a leak at the dipstick tube. Changed out the tube and the leak is still there. I now believe it is coming from the crank seal. I did not check the crank seal on the aftermarket timing cover that I installed - perhaps it wasn’t seated or maybe it was defective.I also installed an aftermarket crank pulley (fluidampr). Maybe the combination of the two has caused a leak. Nevertheless, I have an Audi brand crank seal and crank pulley bolt on the way.
    Hopefully I can replace the seal without going into service position. I really hope this is the cause of my oil leak! There is also a slight oil moisture where the trans meets the engine. Really hoping that is blowback from the front leak and not a RMS leak! I check in the inspection cover and there is no oil pooling in there.
    Other than the small leaks, car is running beautifully. Tailpipes stay (relatively) clean, no misfires, engine pulls strong, and oil pressures are within spec. No codes, and I haven’t had to reset the check engine light due to heavy pulls since the rebuild! It used to throw a CAT sensor code after a heavy pull/aggressive driving. Looking forward to the weather breaking so I can get back out there and get the EFR installed!
    2002 SV650 - SUZUKI
  26. #146
    Feb 15 2016
    Cambridge,Ontario
    all great news !! . I have zero leaks and my engine looks like crap from rust I vote leave it lol .
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  27. #147
    Jan 18 2022
    2015 A4 Prem. Plus, 1987 Scirocco 16V
    Raleigh, NC
    I ended up with an oil leak after rebuilding my engine from the gasket where the oil filter housing bolts to the block, the part that the alternator and AC compressor bolt to. Did you use a Febi gasket there by chance? Both engines I rebuilt leaked from there and both used a Febi gasket.
    Bought the OE gasket and I'm all good now.
    Hope your leak gets taken care of!
    Just a thought
  28. #148
    Aug 06 2019
    Philadelphia
    Quote Originally Posted by StuckAntichris View Post
    Just a thought
    Before the rebuild, I did have a very slow leak from there. I did replace it with an OE gasket! Ironically, the only non OE gasket/seals I used on the rebuild were on the crankshaft and the RMS. Smh. The crankshaft seal came pre installed on the aftermarket lower timing cover. I should have checked it prior to installation!
    2002 SV650 - SUZUKI
  29. #149
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    You guys were making me question what I used……this is probably not where I would be trying to save money, not worthwhile….although there are worse gaskets to have to replace.
    https://www.fcpeuro.com/products/aud...udi-06j115441a
  30. #150
    Feb 15 2016
    Cambridge,Ontario
    on my build I had no leaks there so didnt touch it
    1976 Yamaha XS 360
  31. #151
    Jun 12 2013
    I only use VW/Audi gaskets. Sure I pay more, but I know what I'm getting each time.
    I run a Fluidampr and have ZERO issues. It MUST be installed properly or it can rip up the seal. Many people over the years (posted on this forum) have torn seals and all blamed the Fluidampr. Hate to say it, it was installer error.
    If you have some oil from the rear of the block, I'm going to ask, how is your PCV setup? What are you using, running?
    Build Thread
  32. #152
    Aug 06 2019
    Philadelphia
    Yeah. Kicking myself. The only non Audi branded seal I used is that crank seal (and the 034 RMS). But I think the oil/wetness at the rear is actually spray/splash from the forward leak and under tray.
    The crank seal was an oversight. I bought the lower timing cover (with seal installed) around early 2020 with all my other timing components. Needless to say, they all sat for a while. But the lower timing cover was aftermarket - and it came with the seal installed. When I finally got around to installing it (the rebuild). I never checked it. Smh.
    So I think it was either unseated or just a bad seal.
    I?ll know soon - today I pulled off the bumper and put the front carrier into service position. Tomorrow I will get to the seal and see what we have!
    My pcv is stock but due for a change. I?ll probably swap in the new one I have while doing the crank seal.
    2002 SV650 - SUZUKI
  33. #153
    Jun 12 2013
    Good to hear on the stock PCV. I support catch cans but everyone but ECS hurts the PCV system on our cars. The line from the PCV valve to the IM must be retained/used. I'm going to figure out a way to get a catch can on that circuit.
    I support the 034 RMS. I was thoroughly impressed when I got it and installed it. As long as you properly follow the directions AND visually check the seal seated properly, by also rotating the crank to verify, you should be good to go. I'm running the 034 RMS on my latest build.
    If it's just your front seal, easy in the grand scheme to fix up; good luck!
    Build Thread
  34. #154
    Aug 06 2019
    Philadelphia
    Completely agree with you on the PCV. Once I found out how it works - I couldn?t understand the benefit to disabling portions of it. So?. I put together a dual catch can setup that retains full function of the PCV and basically pulls more oil out of the passing charge on both sides.
    I?ve had it in over a year - through winter too - and it works great. I just took my charge pipes off for the crank seal and they are oil free.
    Right now the weak point in the dual catch can system is that the catch can on the IM side sees full boost. I think I can solve that with a check valve.
    I have the metal intake manifold - but the setup would actually be easier for those with the plastic one - you just need to insert the catch can into that hose.
    I?ve detailed my setup here:
    http://Dual Catch Can Experiment…cou...d.php?t=963267
    Dual Catch Can Experiment…couldn??t resist.
    https://www.audizine.com/forum/showthread.php?t=963267
    2002 SV650 - SUZUKI
  35. #155
    Aug 06 2019
    Philadelphia
    This past weekend I dove into the crank seal issue?
    TLDR: That was my issue - crank seal was leaking; also realized it was causing a vacuum leak. Swapped out the crank seal - no more leak and engine is running smoother than ever!
    ?for those that want to dive into the details - continue below!
    First thing I did was put my car into service position. I?ve had the engine out and done a ton of work on this car and this was the first time I have ever put it in service position. I don?t know what I was so afraid of. It was super easy to do and took all of about 10mins.
    After removing my charge pipes from the intercooler - I was very happy to see that my catch cans have been doing their job!
    In the images below, the leak can be seen. The lower timing cover below the crank pulley is wet with oil. I previously thought this was my dipstick tube leaking.
    What keyed me into honing in on the crank seal was that the rest of the lower timing cover was spattered with an oil mist. 5A37575F-B9DF-452B-8234-4E45E8576C08.jpeg
    The back edge of the accessory belt also had some oil residue on it.
    In any event, service position made access a breeze and was definitely worth the effort.
    Got the fluidampr off and revealed the crank seal.
    Pulled the seal out with a seal puller. I was very careful not to destroy the seat in the lower timing cover. 7358E7C0-8F0A-4D75-89CD-42F24EAAB3AC.jpeg
    Comparison of new and old seal. Also pictured is the seal installer out of the timing chain kit I have.
    Installed the new seal (Audi branded) along with a new crank bolt.
    Wiped everything down, put the front end back together and was good to go!
    I definitely had a vacuum leak. Upon startup, engine idles much smoother - no more vibration. I previously thought I needed a new pcv. Over the past few days I?ve been getting into boost - no leaks so far.
    2002 SV650 - SUZUKI
  36. #156
    Feb 15 2016
    Cambridge,Ontario
    getting the torque spec on that crank bolt is a real treat isn't it. lol.
    1976 Yamaha XS 360
  37. #157
    Aug 06 2019
    Philadelphia
    It is! Lol. But it was definitely easier with the engine in the car in service position. I was able to use the frame rail as the hold. It was much harder the first time around when I had the engine on the stand!
    2002 SV650 - SUZUKI
  38. #158
    Feb 15 2016
    Cambridge,Ontario
    agreed I took my engine off the stand strapped it to some 4 by 4s on the ground.
    1976 Yamaha XS 360
  39. #159
    Aug 06 2019
    Philadelphia
    The crankshaft seal replacement solved my leak! Happy to say I am leak free now!
    Weather has gotten warmer so e-85 is back in season. Filled 1/2 tank with e85 and achieved an e45 blend. Engine ran smooth as expected.
    Turned on the water-meth system. Intake temps came down and car felt snappy as ever!
    It seems my engine affairs are all in order - the rebuild went well! I think it is time to get back to making progress on what is next!
    - Need to learn how to tig weld (seriously - committed to DIY) so I can finally get the EFR on.
    - Looking into putting on larger brakes due to a recent rabbit hole I fell in. I’ve got some 4M q7 calipers on the way - will see what I can do with them.
    - Sway bars - would like to upgrade at least the rear.
    Summer’s here so time to open my driveway workshop! :)
    2002 SV650 - SUZUKI
  40. #160
    Jun 12 2013
    I do NOT torque down the crank bolt unless it's in the car. Much more support. Engines I build, I let them know this too and either let them borrow my holder or it goes to the shop that installs them and they know I don't torque it down. Not worth breaking something and having a very nice engine fall on it's face (well, oil pan).
    Build Thread
