Hello all! Been here a few years as a lurker and this is my first post. I have used the forums to do some maintenance on my 2010 S4 in the past, but now I am stuck on my most recent maintenance project and need some help!
I have done all the work to replace the Water Pump, Thermostat, and PCV Valve (supercharger off and all). I am trying to vacuum test my coolant system, but I am experiencing a few problems:
1. The coolant system does not generate a vacuum of any kind (except enough to see some undrained coolant fill the reservoir some from the bottom). The needle on the gauge does not move on the vacuum filler. I have tested the vacuum filler, and it does operate correctly. Obviously I'm sucking in air from some hole somewhere. When I open the pet cock drain valve, while trying to pull a vacuum, it drains a little coolant.
2. Seeing as there is residual coolant in the system (see #1), I am having problems getting anymore to drain out, save from a slow drip out of the pet cock drain. I have disconnected the hoses by the oil cooler on the driver's side and drained most of it. Are there other points I should try?
Here are my thoughts: Problem number 1 with the evidence of the pet cock valve still draining (albeit slowly), makes me think there is a hole (maybe a rather large one) somewhere in the system between the coolant reservoir cap and the pet cock valve. This leads me to believe that maybe I have left a hose disconnected, but I cannot find one. Possibly a hole in the reservoir or the radiator? I am leaving the pet cock valve open over night to hopefully help problem #2.
What is my next play here? There is no (or little rather) coolant in the car, not enough to start it or pressurize. Do I fill it and run it for a few minutes and then try to manually pressurize the system and look for leaks? Would a pressure test kit from a local auto parts store work on this car? I can't find what pressure the system is rated for. Any clues on where to look for a leak based on the info I have given?
I am almost at a loss. I feel like I have put a lot of work in this project just to have to take it to the shop anyways. Any kind help is very much appreciated.
