Results 1 to 3 of 3
    Oct 16 2021
    2010 A6 3.0T Prestige
    Gallitzin
    Adaptive Headlights 02071
    02071 - Local Databus
    004 - No Signal/Communication - MIL
    I have replaced both ballasts and bulbs for each of the lights. I still have the issue of the lights not working. I am not sure if the level sensors are the issue or the lights themselves.
    At this point willing to try anything
    Oct 16 2021
    Gallitzin
    Well now I have made things worse/ or maybe better by re-installing the old ballast on the left side, and then putting the new one back in
    I now get the codes:
    01042 - Control Module; not coded
    01539 - Headlights not adjusted
    I however can not get the module to code with VCDS or ODIS it says that I have not met the requirements, and i cannot do the basic settings either
    Established Member Two Rings Dan McBoost's Avatar
    Jul 31 2004
    A bunch of Audis and Supras
    Supratown NY
    See here:
    https://www.vwvortex.com/threads/hea...odule.7797753/
    Also if you need a set of C6.5 OEM lights I will be selling my used set once they are out. PM me. They are complete.
    Dan McBoost
    FB: Dan McBoost
    IG: Dan McBoost
    McBoost.com
    ______________________
    Own:
    Audis: · 11 Q7 · 09 A6A · 97 A8Q · 90 CQ · 85 4000Q ·
    Supras: · 87T · 87T · 85P ·
    Other: · 14 Sequoia · 06 Sequoia · 04 Evo8 · 91 Celica All-Trac · 90 JDM MR2 GT · 78 Toyota Hilux ·
