Results 1 to 21 of 21
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    APR tune question
    I've returned back to a B8.5 car after being away from Audi for a few years.
    My other 2 B8-8.5 cars both had the APR stage 2 flashes and bolt on mods.
    My question is, when I did the last car, I was worried about a check engine light because I had a different exhaust setup then the APR kit. At the time, my tuner told me that I should not worry about the CEL, because APR's stage 2 software turns the O2 sensors off to limit the issues with aftermarket exhausts.
    Is this still true?
    Can someone explain exactly what's done in the tune to fix the engine light issue?
    Would a test pipe or high flow cat setup still trigger a CEL, or does the adjustment in the software prevent a light coming on?
    Just looking for the facts to decide the route I am going with the latest car I bought.
    Thanks in advance everyone.
    Established Member Two Rings 18tyweslow's Avatar
    Aug 24 2020
    1997 Miata
    Green Bay, WI
    Not related to your APR question (I had 034 with my S5), but what did you end up picking up? Did you find a Nogaro?
    Weekend: 1997 Turbo Miata - FM Turbo Kit, MS3Pro PNP, ID1050x, Supermiata LWFW & Clutch, tuned to 260whp.
    SOLD! 2017 S5 - 034 Stage 1 w/ DSG Tune | Daytona Grey / Magma Red Nappa
    SOLD! 2013 Subaru WRX STI Hatchback - Stock
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Quote Originally Posted by 18tyweslow View Post
    I am still looking for a Nogaro, but I bought a nice white w black car for the time being until I find the Nogaro.... Whenever that might be.
    Sep 16 2020
    West Michigan
    APR does not disable the secondary O2.
    I currently have a CEL for secondary O2 on APR software with gutted cats.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by sepheroth86 View Post
    stage 1 or stage 2? it’s common for all of the tuners to leave secondary 02 on for stage 1, but disabled for stage 2, since stage 2 is essentially just stage 1 with a downpipe.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    When the APR tunes still had the EMCS (Map switching), they were disabled in the tune. I had 2 other S4's with no light and my tuner told me specifically that APR did this because of the sensitivity of the rear O2's with aftermarket exhausts.
    So they must have more recently changed that if it's true.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Quote Originally Posted by Gunnarrrrr View Post
    Since the whole EPA fiasco for other domestic car tuners a few years ago, it was supposedly changed around where APR went and updated all their files where they don’t disable the CELs for secondary O2 efficiency anymore.
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Quote Originally Posted by SwankPeRFection View Post
    Is there any workaround for this at all that you know of? Thanks for your reply.
    Aug 05 2013
    N/A
    Quote Originally Posted by carguy19 View Post
    If you can get your hands on their test pipe file, if they’ll even still allow that, that’s about it. Other than that, you’re stuck with having to use spacers or actually run CATs. Maybe Evolution can chime in and say what’s up with what files are still available from APR in relation to this.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    034
    Mar 25 2015
    Placer County
    I already was wondering why on earth anyone would still be choosing apr for their tune. Now I really can’t believe someone would still go with them
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    I've had more then 10 cars with APR software, I have never had an issue or problem with them and they have always performed like stock; just as smooth, only faster.
    I have driven S4's with GIAC and 034 stage 2 software, and although they feel almost the same to me at WOT, and just as fast, they are nowhere near as smooth.
    During around town driving, part throttle, and throughout the RPM range (where everyone lives 90% of the time), nothing feels as smooth to me as the APR software. Besides the APR stuff never failing me, It's personal preference.
    Mar 31 2008
    eS-4
    CAL*SO
    Which was the whole point of EA argument. They are, weather you want to admit it still have loyalty customers.
    Just like you guys swing on 034s nuts lol. (And that's ok too)
    Folks who know...know.
    Now I want to know about this emcs tune switching that had deleted 02s because of that was the case, I didn't need to go 034.
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Quote Originally Posted by Fresh.S4 View Post
    This was years ago when I had my last S4.
    I have a call in to my tuner/shop about being able to use an older file, but I dont think that's going to be possible. It's a shot in the dark.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    If you don't want to change software companies, you can try very very shallow 02 spacers. The one's I purchased and ran for years on my APR state 2 Ultra on testpipes were about 3/4" tall spacers, worked 100% fine and set all OBDII readiness and never triggered a CEL. It was just tall enough to remove them from the exhaust stream.
    Note, you'll end up with a CEL if you run too tall of spacers as well. The CEL is due to "slow response" from the O2 signal being fed back to the ECU.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    They won’t let you flash a test pipe file unless you already bought it before the policy change. At least that’s what I’ve been told in the past. People who owned it before are most likely grandfathered in. Or at least that’s my understanding.
    Many people have posted that they’ve had zero issues running test pipes with spacers without having a test file tune with APR.
    Just gotta play the spacer game.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    May 20 2017
    New Hampshire
    Because it just works from day one, is a very impressive tune and they’re the top VAG tuner in the world.
    I have 200+ Dragy or track passes from stage 1 up to dual pulley Ultracharger and I’m running stock cats. I have never had a single issue with my car or tune that needed customer support. Everything just works like it’s suppose to and the car has an OEM feel to it while daily driving and it’s very aggressive when my foot is to the floor.
    That’s why people still run it. Hope that answers your question.
    May 20 2017
    New Hampshire
    You won’t be able to flash older files. Only the most recent software is available.
    Aug 05 2013
    N/A
    Step backwards for APR. Just like the bullshit EPL did where they wouldn’t change their files and forced people to run spacers, which’s isn’t the right way to do this. Me personally, I’d never run anyone’s tune that forced me to run spacers that don’t always work and you could get an occasional CEL for efficiency. I’m tired of staring at it with EPL, so if and when I decide to change, that’s one requirement that will need to be included. The right way is to still allow the car to set readiness but suppress the efficiency range triggers on the rear sensors.
    Mar 31 2008
    eS-4
    CAL*SO
    Spacers aren't that serious lol.
    Inconvenience? Sure.
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Just to follow up with an answer for this thread, there is no way to reference an old file to run from APR, but my tuner said that with the stock cats he’s never seen a CEL with the APR software. Also, he said that many (more then 10-20) 3.0T/SC’d customers with aftermarket cats or test pipes are running the software with no light and it’s an easy fix; in these cases they install “Vibrant O2 spacers” (which have different sized inserts that go into the spacer to vary the amount of exhaust gases that fhe O2 sensors see). With those specific spacers he said that there hasn’t been a single car that they couldn’t fix the CEL with since the tune revisions.
    So it sounds like I have a game plan once I reach that point thankfully.
    I hope this helps someone out there.
