Results 41 to 80 of 81
  1. #41
    Dec 05 2010
    Boston, MA
    I have a B6 S4 and will this work? I'm very interested in this upgrade and like to see how I can join for group buy if it is still available?
  2. #42
    Oct 31 2022
    Prescott AZ
    Quote Originally Posted by mug23 View Post
    I sent you a PM I am getting some brackets cut out for a b6 s4 also.
  3. #43
    Dec 05 2010
    Boston, MA
    I'll be interested in using the JHM 2 piece 330x22mm rear rotors and it is stock offset. Can anyone confirm that the JHM 2 piece rotor will work with this bracket?
    https://jhmotorsports.com/products/b...-b6-b7-s4.html
  4. #44
    Senior Member Three Rings a.four's Avatar
    Jun 09 2019
    2023 Jeep Wrangler
    Interested in this as well.
  5. #45
    Oct 31 2022
    Prescott AZ
    Quote Originally Posted by a.four View Post
    Pm you also.
    Let’s get the group buy going and those prices down !
    3 of us so far
  6. #46
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    I've been PM'ing Matt, but the JHM kit all you would use is the rotors themselves. The bracket is to offset the S4 carriers (fit thicker rotors than A4) to fit larger rotors.
    Matt is getting them cut if anyone wants to jump on his order, otherwise let me know and I can reach out to my shop.
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
  7. #47
    Established Member Two Rings Ultrakd's Avatar
    Nov 15 2015
    Florida
    Wondering if anyone has tried on a q5/sq5 yet. I’d assume they all work the same since they are all the same chassis more or less. I have a 2015 b8.5 SQ5 that I would love to upgrade the rears on.
  8. #48
    Oct 31 2022
    Prescott AZ
    Here is the final result.
  9. #49
    Jan 14 2015
    South Dakota
    @ultra, I was working with another guy on his S5 (as I also have a Q5) to make some brackets. I sent him some 3d prints to test since I don't have a 2nd set of rear brembos to use or the Tesla ebrake, but he's been quiet for the month having his car worked on.
    The bolt pattern is vastly different between B7 and B8 hubs and accommodating the electronic parking brake, but I do have a mock up for the B8 chassis that is close, just not tested.
    @matt, good looks. Just need 2 of the small U looking ones for the Wilwoods and threading the holes you'll be set.
    ig 1red_b7
  10. #50
    Jan 14 2015
    South Dakota
    As far as I got for B8s. Trying 330mm and 356mm rotors.
    ig 1red_b7
  11. #51
    Dec 05 2010
    Boston, MA
    I will be getting the brackets from matthewest91 by this coming Thursday and I'm excited. So I can use the JHM 2 piece rotor and it will be centered inside of the 4 pot Brembo calipers with any spacers?
  12. #52
    Jan 14 2015
    South Dakota
    Those 4 circle ones pictured above space the caliper.
    ig 1red_b7
  13. #53
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Any more progress on this for the B8?
  14. #54
    Jan 14 2015
    South Dakota
    Nothing new, if someone with a B8 had all the other necessary parts to test with, calipers + tesla ebrake, i could print them some pieces to test.
    ig 1red_b7
  15. #55
    Jan 14 2015
    South Dakota
    Finally got around to working on the lever for the Wilwoods, just flat bar from the store and angle grinder. E-brake handle is back to OEM distance. Drawings and files added to first post.
    ig 1red_b7
  16. #56
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Got the main calipers(Brembos) finally installed. Still need a bracket for the S4 rear PB. Car is auto, so no real rush..
    Had to grind a little off the knuckles, bolt head was hitting, but no biggie.
    Also made a little "T" bleeder hose, worked great!. Bled them good, drove for a weak(pedal still a bit soft). After a week I cycled the abs on all 4 corners, bled F&R again, and pedal feels awesome!! Absolutely love them now!
    Powerstop Evo Z23(carbon/ceramic) pads, and R1 concepts rotors.
    Sent from my LM-V600 using Audizine Forum mobile app
  17. #57
    Jul 12 2023
    Philly
    I’m really late to the party but I’d love a set of b6 s4 plates if anyone is having them cut out
    - - - Updated - - -
    These still available
  18. #58
    Oct 31 2022
    Prescott AZ
    Quote Originally Posted by D.oxendine01 View Post
    - - - Updated - - -
    I can do that
  19. #59
    Oct 31 2022
    Prescott AZ
    - - - Updated - - -
    I can’t see your picture? Is it the stuff I had cut ?
  20. #60
    Aug 18 2019
    Utah
    I'm interested in the plate for b6 s4 with brembros and the Wilwood ebrake. I'm interested in just getting the file. I'll get them cut myself. Thanks for the hard work!
  21. #61
    Jan 14 2015
    South Dakota
    All files are links in the first post. Ty
  22. #62
    Nov 26 2022
    Texas
    Please let me know, I am interested 100% A5B8 being put together…
  23. #63
    Nov 26 2022
    Texas
    Send me the parts numbers I can see if I can get a hold of them and be the test mule for you on the b8 platform. I have A5B8 Quattro prestige in slowly working on
  24. #64
    Jan 14 2015
    South Dakota
    Quote Originally Posted by BrickA4 View Post
    My signature has a link for B8 parts. I have everything I need, but 3d printer is down for repair at the moment. Should be back to printing and fitment next week.
    https://www.audizine.com/forum/showt...1#post15100991
  25. #65
    Mar 15 2016
    Seabrook(Houston), TX
    I have the rear calipers and can order Tesla rear brake caliper. Wait 3D printer are you printing on?
  26. #66
    Dec 29 2024
    Romania TM
    Quote Originally Posted by Matthewest91 View Post
    hy @Matthewest91 , I know it's an older post, but I was just curious if the Universal Brackets are the ones confirmed for mounting with the original S4 caliper, because in the files from the first post, the Wilwood Spacer doesn't line up with the holes, it's much smaller! I want to put the files in for processing, but to use only Cayenne/Touareg Calipers and to stay with the S4 caliper used as a handbrake. Thank you
  27. #67
    Jan 14 2015
    South Dakota
    I have files for using the S4 caliper, which was more or less my first iteration.
    The one piece/universal is Brembo/Wilwood only. It does mount to A4 or S4 hubs though.
    To use the S4 caliper as a parking brake (like what Jayz is doing) uses a 2 piece version which puts both calipers on their own bracket.
    ig 1red_b7
  28. #68
    Dec 29 2024
    Romania TM
    Quote Originally Posted by xRenesis View Post
    I'm interested, for my personal car! are they for sale, or how to proceed?
  29. #69
    Jan 14 2015
    South Dakota
    If you intend to use Brembo/Wilwood 1 piece, I have the STEP/3D and DXF files in the first post if you have a local shop with laser or plasma table. Otherwise it was about $300 usd for a single set from the company I work with. Not sure what Matt's cost was.
    If you want to use the S4 caliper as a parking brake, I'll need to send you the appropriate files.
    ig 1red_b7
  30. #70
    Dec 29 2024
    Romania TM
    I just want to be able to use Cayenne/Touareg Calipers and to stay with the S4 caliper used as a handbrake! it is still recommended to switch to a 330X22 disc? I would be grateful if you could send them, PM or email, as you wish! I can process them myself, I have all the necessary equipment
  31. #71
    Jan 14 2015
    South Dakota
    Quote Originally Posted by florincalin View Post
    Your inbox is full, but it'll be something like this, like what you sent me.
    ig 1red_b7
  32. #72
    Dec 29 2024
    Romania TM
    many thanks, I'll keep you updated on the execution/installation process
  33. #73
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Is anyone making these plates/adapters? Maybe powder coated or anodized? Regardless PM me if this is still a thing!
    2018 Q7 Florett Silver/Black Premium Plus, Vision Pack, Cold Weather
    2008 S6 V10 Prestige Brilliant Black/Black - 141 out of 928
    2006 A4 2.0T 6-Spd Quartz Grey Metallic/Ebony - S-Line, Premium Pack, Tech Pack 1, Tech Pack 2, Cold Weather - 725 out of 4,657
  34. #74
    Jan 14 2015
    South Dakota
    All of the needed files are on the first post at the bottom as hyper links. If you have a fab shop near you, some others either know people or have good access to a plas/laser table. Otherwise, my shop was about 300$ for a set in A36 steel, non plated.
    ig 1red_b7
  35. #75
    Oct 09 2015
    Boston
    Ah got it, Ill look into a shop to cut them out. Thanks to all who worked on this!
  36. #76
    Established Member Two Rings Nate_Conner's Avatar
    Apr 08 2015
    Cincinnati Ohio
    Maybe this is a dumb question, but will this work with a A4 and Brembo 18z rear calipers from a Q7? I got super lucky on a junk yard find (all 4 18zs, AND off the car lying on the ground, with no one around) and really would rather mount them then sell them and this seems to be the adaptor needed for them.
    If they work I am interested in a group buy
    JHM Stage 2+ B7 A4 2.0T
    Mods: ECS Cat back exhaust, ECS FMIC, CTS High flow cat, 034 HFP, JHM Stage 2+ Tune, Bilstein shocks w/ HnR Springs, CF trim, wood steering wheel, painted valve cover, and few love dents.
  37. #77
    Jan 14 2015
    South Dakota
    Yes, the Touareg/Cayenne/Q7 rears should all be the same, which is what this is setup to use. Full Q7 set is what I'm running. I've also got the part numbers listed in the first post.
    Just like my B8 S4 brackets, I'll see about getting a couple sets made next week at work. This should help out pricing/availability for others going forward. Things are just slow at the moment.
  38. #78
    Established Member Two Rings Rush's Avatar
    Mar 24 2012
    Cochrane, AB
    Hey, would this also work for the B7 RS4 with the 325mmx22 rear rotors? I want to have send-cut-send make me some brackets. I already have touareg 4 piston rear calipers laying around.
    Sent from my SM-S928W using Tapatalk
  39. #79
    Jan 14 2015
    South Dakota
    Quote Originally Posted by Rush View Post
    The mounting looks the same as the S4. I can't find dimensions for the offset on the RS4 rotor compared to the 330x22, the 4pot spacers would be easy to change and I want to say the wilwood still has room to slide to accommodate. You can print out the pdf in the first post in 1:1 actual size and compare to make sure.
    ig 1red_b7
  40. #80
    Apr 08 2015
    Cincinnati Ohio
    Just a heads up, Send Cut Send now has 8MM (.313") A36 Mild steel, and for both sides, it comes out to $41.58 for each main plate, with no finish. Powder coating adds about $20 a plate, while a black zinc finish adds about $35. No idea if that can beat local shops, but a week or two delivery time it seems like a really good option
