Results 1 to 4 of 4
    Jun 02 2021
    Los angeles
    2018 rs3 weird clicking noise around exhaust area
    Does anyone know what this clicking noise around the back of the exhaust is? It happens when I lock or unlock the car. Any help is appreciated 🙏
    Thanks
    https://youtube.com/shorts/cEzmDAkQaB8?feature=share4
    Established Member Two Rings 5CYL_BTLSHIP's Avatar
    Dec 18 2018
    Austin TX
    It's the exhaust valve actuator motors. One or both of them. One of mine did that once when it died and I had to buy a new one. They also both did it on mine recently when I swapped them over to a different exhaust. I had to plug in the vcds and run the manual test to open and close them. That reset them and they're good to go. Having them click like that will set soft codes which you'll see in a vcds scan. Those soft codes will limit boost and power until they're fixed and codes cleared.
    Sent from my SM-G990U3 using Audizine Forum mobile app
    2018 RS3 - FBO E85, DS1/DoubleD tuned
    Instagram: 5cyl_btlship
    Active Member One Ring echo38's Avatar
    Mar 03 2025
    Hong Kong
    Lightbulb
    Quote Originally Posted by 5CYL_BTLSHIP View Post
    I am having exact issues I ran VCDS, seems all ok. The exhaust value operate ok too. Door, trunk locks? Petrol cap lock? driving me nuts
    Can any one further verify before i replace the Exhaust flaps x 2? Much appreciated
    https://youtube.com/shorts/RYAM3LqWiGQ
    Nov 25 2013
    Ottawa
    When that happened on my car it needed a new motor on the passenger side (J883 P14AB00). The other side was jammed and needed to be freed up. The car was more quiet with both exhaust valves being faulty. My car pulled power when the exhaust valves were not perfect. Not sure how it is possible for the exhaust valves to operate ok when there are 3 clicks as in the video (I also had 3 clicks).
