Results 1 to 11 of 11
Thread: Oil level?
    Jun 19 2018
    Orange County, CA
    Oil level?
    Hello everyone,
    I currently drive a stage 3 TTE777 e85 built motor TTRS. About 7k miles on the build and 16k total miles on the car. I havent done any launches or runs so i havent been pushing the car as much. Now I've been changing my oil every 5000 miles.
    However, it's been about 3300 miles since my last oil change and I got a 'check oil level' light which means I might need to top off my oil. Before this I had to top off my oil again around 3500 before my last oil change.
    My question is, can this be normal for a build like mine or am I burning oil too quickly and is it a sign of my engine going bad in the near future?
    Any insight will be greatly appreciated. Thank you.
    Sent from my SM-G998U using Audizine Forum mobile app
    Aug 31 2021
    Oakland CA
    I add a bit of oil on a regular basis, less than a quart between oil changes.
    That’s said there’s no way in hell I’d go 3k miles plus without checking it
    Mar 09 2018
    2018 RS3
    Maybe give it a good beating and make sure the rings seat. lol
    Honestly it's probably best to contact the shop that built the engine.
    Stock here but I don't see noticeable oil consumption with 5k intervals.
    Florett RS3+DS1+034TCU
    Oct 19 2018
    KCMO
    I go 8 - 9 k between, never lost a drop on the stick.
    May 10 2020
    Virginia
    Quote Originally Posted by Auditude437 View Post
    Hello everyone,
    I go 10k in between my oil changes on stock motor but I see significant oil consumption like you do. I check my oil all the time so I add as necessary. Oil consumption seems to be a hit or miss on these engines. Checking your oil regularly would get around this, sending out your oil to a lab like blackstone oil labs for a check up and talking to your engine builder about oil consumption like suggested seems like a great start.
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    Yes oil consumption is a hit or miss on the RS 3 as our 2019 RS 3 has shown us, during the past
    47,524 miles of which 34,259 miles have been fast country back road runs at speed. Consumption
    has been repeatable with no large consumption increases showing, but several RS 3 friends have
    had very large oil consumption surprises. Time to have it looked at in detail to see what is the
    oil consumption problem being created by.
    Rod RS-3
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    My mileage is at 37,043. Last oil change was 32,375. Oil level has just dropped below the full level.
    I'd be slightly concerned if I were you, but I mean that literally. Only slightly concerned. 3300 miles to drop below the safe level is nothing much to be worried about. On the flip side, you just had the engine rebuilt. It is an annoyance to say the least.
    Funny, my 2000 A4 avant with 352k miles doesn't burn a drop. Original bottom end too. And turbo.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jan 07 2013
    Charlotte, NC
    have you checked your oil pan? pretty common for those to leak
    @tuxedo.ttrs
    Senior Member Two Rings ZTTRS's Avatar
    Jul 26 2018
    TEXAS
    Hello everyone,
    on a build like this, I would perform OC every 3k
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    first of all, I think would be good to figure out how much is this oil consumption (qty/miles), otherwise is impossible to determinate if it's excessive or not... (if I remember well, Audi states that can be considered a normal consumption up to 1 kg/1000 km...)
    on mine (DNWa engine, 25.000 km, stage 2), is around 150 cc/1000 km...
    2020 TT- RS
    ex 2018 TTS
    Senior Member Three Rings sleepy_rs3's Avatar
    Mar 29 2021
    New York, NY
    Chiming in with my personal experience in case it helps anyone: When I was stage 1+ my engine consumed oil, about 1/4 of a quart every 5k miles. After going stage 2 (93) the consumption completely stopped. I think this was a function of the turbo being able to cool more easily with the downpipe and burn less oil. I'm interested to know if this theory makes sense to anyone...
    2019 Glacier White RS3 | Unitronic Stage 2 ECU & TCU | Unitronic Downpipe, Intercooler, & 4" Turbo Inlet | CTS 4" pipe to stock airbox | 034 intake heat shield | DSC Sport Controller | Tyrolsport Deadset Subframe Kit | 034 Street Density dogbone kit | Valentine 1 Gen 2 Radar Detector with JBV1 app
