    Junior Member Two Rings
    May 22 2022
    Germany
    S5 B8 2007 Manual - Loose shifter, wheres the problem?
    Hello guys, so i have a 2007 S5 Manual (German Model). Sadly the shifter is really wobbly, its possible to shift normally into the gates, but it simply does not FEEL right, its not sharp but really wobbly.
    Does someone know if i need new bearings, or if its a thing of adjusting and tightening? I also wondered if i should get the JHM Shortshifter, but im not sure if i need to remove the engine and gearbox for that?
    Video of the Problem :
    https://www.youtube.com/shorts/_25z1NYl_Mg
    Junior Member Two Rings SlowBlackB8's Avatar
    Jan 14 2022
    Cincinnati
    The bolt is the hinge at the base of the shifter is likely the culprit: https://youtube.com/shorts/uOngQWHeLlk?feature=share
    I installed JXB billet shift plate, JXB solid shift linkage, and ECS Drivetrain insert kit and the shifter slop has been completely eliminated. Video replacing shifter: https://www.youtube.com/watch?v=Ce9nts4v_jI
    Definitely worth the time and effort even if you just get JXB or JHM short shifter.
    08 s5 4.2 6mt | ECS Drivetrain Insert kit | ECS short shifter | JXB billet shifter mount | JXB billet shift linkages | B7 RS4 IM port&polish | Backboxes replaced w/ SpinTech 9k | LYKT adjustable control arms | Solowerks S1 | Jackal Tune | 034 Motor Mounts | Eurocode swaybars
    May 22 2022
    Germany
    Many thanks!
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    You might also want to check the actual shifter itself for a worn out bushing. The stock shifter uses a large plastic bushing that can wear out over time and cause a really sloppy feel.
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    I was going to say check the bushing. Likely the culpprit
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
