Car: 2016 Audi SQ5 Premium Plus | Mythos Black Metallic | Black Optics Package | Technology Package | Fine Napa Leather Package | Black Interior with Diamond Stitching | Carbon Atlas Inlays | Red Brake Calipers |
Condition: (Purchased in May 2021, one owner, 25,046mi, completely stock - $34,888)
OEM Specs:
3.0 Supercharged V6
8 Speed ZF 8HP Automatic Transmission (ZF8)
Horsepower: 349hp at 5,500-6,500rpms
Torque: 346lbs-ft at 4,000-4,500rpms
Curb Weight: 4,442lbs
Current Power Numbers:
APR Stage 2+ Redstar Long Tube Headers: 478whp/445wtq (12/23/22)
Brakes:
Brake Calipers:
C7 S6/S7 6 piston Brembo Front Calipers - rebuilt and powder coated Gloss Red
95B Porsche Macan Turbo Rear Calipers - rebuilt and powder coated Gloss Red
Brake Rotors:
034Motorsport C7 S6/S7 2-piece slotted front rotor (400x38 vs 380x36 OEM) (32.4lbs vs. 28.65lbs OEM = 3.75lbs heavier)
034Motorsport C7 S6/S7 2-piece slotted rear rotor (350x22) (13.9lbs vs. 16.65lbs OEM = 2.75lbs savings)
Brake Pads:
Power Stop Z26 Extreme Street Brake Pads (front) - Audi C7 S6/S7
Hawk Performance Ceramic Pads (rear) - Porsche Macan Turbo (95B)
Brake Lines:
034Motorsport C7 S6/S7 Stainless Steel Braided Brake Line Kit
Dust Shields:
OEM SQ5 Front Dust Shields
OEM S6 Rear Dust Shields
Coding:
OBDeleven Pro Ultimate
• Open Door Chime Disabled
• Footwell Lights Activated
• Fog Lights with High Beams
• Scandinavian DRLs Activated
• Soundaktor OFF
• DRL function with Turn Signal - DIMM
• Needle Illumination ON
• Seat Belt Chime OFF
• Side Marker Lights OFF
• Emergency Braking Lights ON
• Comfort Windows ON
• Needle Sweep ON
VCDS & VCDS-Mobile with HEX-NET
• Eurocoded Taillights
Engine:
Jackal Motorsports Stage 3 ECU/TCU Tune
GAS Omega 102mm Intake Kit - 24k Gold Torched Titanium
GAS VDO 80mm Throttle Body
ECS Tuning Kohlefaser Luft - Technique Intake System Airbox
Merc Racing Supercharger MRA1900
034Motorsport Dual Pulley Kit 190mm Crank Pulley,
Merc Racing 2.8” Supercharger Pulley
Bando 7PK1388
Redstar Long Tube Headers with Performance Heat Shielding
300 Cell Gesi Cats welded into the Stock Downpipes
AWE Touring Catback Exhaust - Diamond Black Tips
Integrated Engineering HPFP
NGK 2668 BKR8EIX Iridium IX Spark Plugs - gapped to 0.026
Merc Racing 4.0T High Coolant Capacity Heat Exchanger
Merc Racing B8/B8.5 S4 Divorced Cooling System Reservoir
Merc Racing Divorce Kit DIY Components + ~10ft of 3/4” Coolant Hose
Pierburg CWA100 Pump w/ Audi Harness
034Motorsport Street Density Motor Mounts
Engine Bay Dress Up:
Vast Performance RS4 Red Valve Covers
Audi Black Coolant Cap
ECS Tuning Black Windshield Washer Fluid Reservoir Cap
Dress Up Bolts Strut Brace Hardware - Gold - (M8x1.25 Nut x4, M8x1.25x25 Bolt x2, M8 Washer x6, M10x1.5x30 Motor Head Bolt x2, M10 Washer x2)
Exterior:
RSQ5 Front Bumper - Xenonz UK
RSQ5 Front Grille with Quattro Badge - https://german-car-accessories.com/c...35034397573276
Black Optics Audi Rings Trunk
Black Optics SQ5 Badges Front Grille
Black Optics SQ5 Rear Trunk Badges
Black Optics Supercharged Badges
Ecodes Headlights
Eurocoded Taillights - VCDS long coding
H11 2.5” Projector fog light housings - https://www.aliexpress.us/item/22518...Adapt=Msite2Pc
deAutoLED Switchback Dual Color Pure White/3000k Yellow Plasma Diode Fog LED Kit
Maxton Rear Diffuser
Maxton Rear Steps
Maxton Side Skirts
Painted OEM Rear Diffuser in Gloss Black
Dawn Enterprises Rear Bumper Protector - https://www.amazon.com/dp/B076X5F94Y...m?ie=UTF8&th=1
Front end PPF
Ceramic Coating
Tail Light & Rear Bumper Tint
deAutoLED Reverse Lights (thanks to Bruno! @volcsq5)
OEM Audi Puddle Lights - Four Rings
Interior:
Ceramic Tint - Prime XR Plus 30% front, 70% rear, windshield & sunroof
P3Gauge
deAutoLED Interior Lighting Kit
Footwell Illumination Activated - OBDeleven
STYO Keyfob Trunk Close Module - https://www.aliexpress.us/item/22518...2usa4itemAdapt
Car QI Wireless Phone Charging Pad - https://www.carqiwireless.com/produc...33378696560780
SQ5 Embroidered Premium Floor Mats - Autostyles UK
Carbon Fiber Steering Wheel by @wovenchang
JQ Werks Madtrace Clubsport Magnetic Paddle Shifters
Perforated Leather Wrapped SQ5 Shift Knob
RSNav 8.8” Series 4 Touchscreen MMI Upgrade
RSNav Rear Backup Camera 720p
Blackvue DR900X-2CH Plus
Suspension:
KW V2 Coilovers
SPC Adjustable Upper Control Arms <- these failed after about 10k miles. Replaced with the same part. If they fail again, I’ll be switching to 034 Upper Control Arms
034Motorsport Lower Control Arms
Ultra Racing Strut Brace - Powder coated Desert Nite Wrinkle Black
034Motorsport X-Brace
034Motorsport X-Brace Stretch Bolts
H&R Front Sway Bar
034Motorsport Dynamic+ Front Endlinks
034Motorsport Rear Sway Bar
034Motorsport Dynamic+ Rear Endlinks
Transmission / Rear Differential / Rear Subframe:
034Motorsport Transmission Mount Insert
034Motorsport Street Density Transmission Mount Upgrade
034Motorsport Rear Differential Mount Kit
034Motorsport Rear Differential Carrier Mount Insert Kit
034Motorsport Rear Subframe Mount Insert Kit
Wheels/Tires:
Summer setup:
BC Forged RZ10 21x10.5 +25
Matte Gunmetal
Bead Knurling
Black Ball Seat Lug Bolts
Michelin Pilot Sport 4S - 295/35/21
Winter setup:
BC Forged TD01 21x 10.5 +25
Matte Bronze
Bead Knurling
Continental ExtremeContact DWS06+ - 295/35/21
Satin Black
Vossen Hybrid Forged Satin Black Center Caps
Vossen Black Conical Seat Lug Bolts
Vossen Classic V Valve Stem Caps
Pirelli Scorpion Winter Tires - 265/40/21
21x8.5 +33
Ultra Black Chrome w/ Soft Satin Clear Coat
ECS Tuning Flush Kit - 15mm spacers front/20mm spacers rear
