Results 1 to 3 of 3
    Mar 27 2019
    CARMONA
    207mm supercharger pulley upgrade C6?
    Hello
    I am currently on stage 2 single 190mm crank pulley and want to switch to 207mm pulley for stage 2+.
    I have checked various tuning companies like 032 motorsports, ECS, etc and they all have the 207 pulley available except for our C6??
    Did anyone install the bigger crank pulley on there C6 3.0T??
    I currently live in Spain and do not know any sellers in Europe for the pulley. Any recommendations on sellers?
    Thanks and regards.
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Quote Originally Posted by BLUEBAVARIAN View Post
    Hello
    Thanks and regards.
    JHM has a 207mm pulley specific to C6.5. To run it you need the JHM Snub Mount (I'm sure you have that since you're at the 190mm). However, you can run any pulley for a 3.0T. (C6.5, B8, C7) all the crank pulley bolt spacing is the same. Whatever is convenient for you to buy if you want it new.
    Sent from my Pixel 6 using Audizine Forum mobile app
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Mar 27 2019
    CARMONA
    Great to know Lion king!!
    Will check out JHM website!!
    Thank you!
