Results 1 to 3 of 3
    Dec 18 2021
    Timing advance gauge in OBDevelen
    Is anyone using the timing advance in OBDeleven? It shows -1.5 to 2 degree relative to #1 cylinder at idle, but when I well slowly to about 4k it reads up to 30 degree to #1 cylinder. Is that normal? When I did a light pull in second gear I saw it somewhere 15 to 25 or so.
    Sent from my IN2015 using Audizine Forum mobile app
    Administrator Three Rings oesman's Avatar
    Oct 08 2016
    Houston
    Quote Originally Posted by ontunerow View Post
    Seems fine to me. It's in a closed loop so the ECU will be advancing timing quite a bit in normal driving to be efficient and pulling it back as you bring the load up. There's a variety of reasons ECU may have negative idle timing (i.e. warm up cats on a cold start, manage idle rpm, etc...), not sure what the strategy is for on these cars but I see the same thing with my VADPro gauges.
    Dec 18 2021
    Appreciate the details! Really helps out to learn. In my area it was also 90+ degree outside, one of thoughts was it might be weather related, but I just don't know enough yet to make auch assumption.
